Failed chip erase: uploading error: exit status 1
Not happening bootloading........Arduino Uno
"C:\Users\HP\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude" "-CC:\Users\HP\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf" -v -patmega328p -cstk500v1 -PCOM3 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0xFD:m -Uhfuse:w:0xDE:m -Ulfuse:w:0xFF:m
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
     System wide configuration file is "C:\Users\HP\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
     Using Port                    : COM3
     Using Programmer              : stk500v1
     Overriding Baud Rate          : 19200
     AVR Part                      : ATmega328P
     Chip Erase delay              : 9000 us
     PAGEL                         : PD7
     BS2                           : PC2
     RESET disposition             : dedicated
     RETRY pulse                   : SCK
     serial program mode           : yes
     parallel program mode         : yes
     Timeout                       : 200
     StabDelay                     : 100
     CmdexeDelay                   : 25
     SyncLoops                     : 32
     ByteDelay                     : 0
     PollIndex                     : 3
     PollValue                     : 0x53
     Memory Detail                 :
                              Block Poll               Page                       Polled
       Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
       eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
       flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
       lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
       hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
       efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
       lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
       calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
       signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
     Programmer Type : STK500
     Description     : Atmel STK500 Version 1.x firmware
     Hardware Version: 2
     Firmware Version: 1.18
     Topcard         : Unknown
     Vtarget         : 0.0 V
     Varef           : 0.0 V
     Oscillator      : Off
     SCK period      : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0x1e9307 (probably m8)
avrdude: Expected signature for ATmega328P is 1E 95 0F
Double check chip, or use -F to override this check.
avrdude done. Thank you.
This part of the output is indicating the you are wanting to program an ATMEGA328P chip but the programmer has detected that the chip is actually an ATMEGA8.
Which Arduino or clone board are you using?
Yes I am programming Atmega8A -PU with already bootloaded(came with UNO atmega 328P-U
You need to install minicore if you want to program an ATmega8
Thankyou for your response but I have already installed it but not worked, circuit correct.
I need to know can I put atmega 8a directly to uno dev board and bootload it
Yes but apparently you did not select the ATmega8 from the board manager.
Have fun with the ATmega8!
oh thats appealing as i was just wasting time making bootloader ckt and trying to bootload
Not wasted. I think you learned a few things.
"C:\Users\HP\AppData\Local\Arduino15\packages\MiniCore\tools\avrdude\7.2-arduino.1/bin/avrdude" "-CC:\Users\HP\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\3.0.2/avrdude.conf" -v -patmega8 -cstk500v1 -PCOM3 -b19200 -e -Ulock:w:0xff:m -Uefuse:w:{bootloader.extended_fuses}:m -Uhfuse:w:0b11000111:m -Ulfuse:w:0b10111111:m
avrdude: Version 7.2-arduino.1
Copyright the AVRDUDE authors;
see avrdude/AUTHORS at main · avrdudes/avrdude · GitHub
     System wide configuration file is C:\Users\HP\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\3.0.2\avrdude.conf
     Using Port                    : COM3
avrdude ser_open() error: cannot open port \.\COM3: Access is denied.
avrdude main() error: unable to open programmer stk500v1 on port COM3
I would start with this error. Does COM3 exist in your device manager? More likely that another application is using COM3. Also, is COM3 the correct port for your MEGA8?
