I am getting this message while i connect and trying compliling via IDE.
WARNING: library LiquidCrystal_I2C claims to run on all architecture(s) and may be incompatible with your current board which runs on avr architecture(s). Sketch uses 6528 bytes (20%) of program storage space. Maximum is 32256 bytes. Global variables use 517 bytes (25%) of dynamic memory, leaving 1531 bytes for local variables. Maximum is 2048 bytes.
Failed uploading: no upload port provided
What could be the root cause? How to sort this out?
HI @noufal986. This error occurs if you attempt to perform an upload when you don't have anything selected from Arduino IDE"s Tools > Port menu.
Select the port of your Arduino board from the Tools > Port menu and then try uploading again. Hopefully this time everything will work as expected.
If the Tools > Port menu is disabled, or if you don't see the port of the Arduino board listed in that menu, just add a reply here on this forum topic to let us know and we'll provide further assistance.
