Failed uploading: uploading error: exit status 2
I was trying to upload a simple dDHT11 example code DHTTester. It shows the error-
Sketch uses 304444 bytes (23%) of program storage space. Maximum is 1310720 bytes.
Global variables use 20072 bytes (6%) of dynamic memory, leaving 307608 bytes for local variables. Maximum is 327680 bytes.
esptool.py v4.8.1
Serial port COM1
Connecting......................................
A fatal error occurred: Failed to connect to ESP32: No serial data received.
For troubleshooting steps visit: Troubleshooting - ESP32 - β€” esptool.py latest documentation
When i switched my PC and try to upload the same program with the same eps32 and wire it works. The uploading seems to work on some pc and doesn't on others. I made sure to check that DHT Sensor Library by Adafruit and Adafruit Unified Sensor libraries are installed on both the systems. The baud rate was set to both115200 and 921600 and resulted in the same outcomes. Every setting under the tools was same for both of the systems with the exception of port.
Is there anything else i need to take care of to make sure my eps32 is properly connected?
I can't help you with the ESP32 stuff. The error indicates an upload problem and hence libraries are not relevant.
  1. Which operating system are you using?
  2. Which ESP32 board package are you using?
  3. Which exact ESP32 board are you using?
  4. Is COM1 indeed the ESP32? Does it disappear from the IDE and Windows device manager when you disconnect the board? If not, it's not your ESP32.
  5. You probably need to install drivers. Do you have any unknown devices in Windows device manager?
  1. Windows 11
  2. ESP32 Dev Module
  3. ESP32 DOIT DevKit V1
  4. yep i checked the com port on device manager.
  5. Yes, i installed CP210x USB to UART Bridge VCP Drivers as that was the chip near my voltage regulator on my board.
I have the same problem.
Hi @blanco. This error might be caused by having the wrong port selected from the Tools > Port menu in Arduino IDE.
Please perform this experiment to verify that the port you have selected is your Arduino board:
  1. Disconnect the USB cable of the Arduino board from your computer.
  2. Select Tools > Port from the Arduino IDE menus.
  3. Take note of the ports (if any) listed in the menu.
  4. Close the Tools menu.
    :red_exclamation_mark: The ports list is only updated when the Tools menu is re-opened, so this step is essential.
  5. Connect the Arduino board to your computer with a USB cable.
  6. Select Tools > Port from the Arduino IDE menus. - If a new port is listed in the menu, that is the port of your Arduino board.
If you saw a new port appear at the last step, select that port from the Tools > Port menu and try uploading again.
If this doesn't solve the problem, please reply here on this forum thread with the answers to the following questions:
  • While following those instructions, did you see a port in the Tools > Port menu at step (6) that was not present at step (3)?
  • If you did see a new port, was the upload successful after you selected that port?
Well I am know able to down load to my esp32 Devkit v1. But I can not find esp32 blue pad in my board manager menu.
Did you add the below in the additional boards manager URLs in file β†’ preferences and install that board package?
https://raw.githubusercontent.com/ricardoquesada/esp32-arduino-lib-builder/master/bluepad32_files/package_esp32_bluepad32_index.json
I was able to get esp 32 bluepad with this URL . I had tried using a like from a different site , but could never get it opened. With your link it came up the first time. Thank You Very Much! Looks like Im going forward slow but moving.
Thank You your URL for the esp32 bluepad worked with no issues. I was able to upload it to my board and made sure I saved the sketch. I'm working on a way to get the MAC address of my controller and I am thinking I need to do some work on the sketch for it to work. Thank You again for your help.
