Exit estatus 2 with my ESP32 from AZ-Delivery
I have trouble uploading code to my ESP32. It never connected and now it gives me this error:
Sketch uses 267585 bytes (20%) of program storage space. Maximum is 1310720 bytes.
Global variables use 20224 bytes (6%) of dynamic memory, leaving 307456 bytes for local variables. Maximum is 327680 bytes.
esptool.py v4.6
Serial port COM1
Connecting......................................
A fatal error occurred: Failed to connect to ESP32: No serial data received.
For troubleshooting steps visit: Troubleshooting - ESP32 - — esptool.py latest documentation
Failed uploading: uploading error: exit status 2
What can I do to solve it? Is it a manufacture flaw?
Hi @nylon2006. This error might be caused by having the wrong port selected from the Tools > Port menu in Arduino IDE. I see you have selected the COM1 port, but that port is typically the internal serial port of your computer's motherboard, not the port of the ESP32 board.
Please perform this experiment to verify that the port you have selected is your Arduino board:
  1. Disconnect the USB cable of the Arduino board from your computer.
  2. Select Tools > Port from the Arduino IDE menus.
  3. Take note of the ports (if any) listed in the menu.
  4. Close the Tools menu.
    :exclamation: The ports list is only updated when the Tools menu is re-opened, so this step is essential.
  5. Connect the Arduino board to your computer with a USB cable.
  6. Select Tools > Port from the Arduino IDE menus. - If a new port is listed in the menu, that is the port of your Arduino board.
If you saw a new port appear at the last step, select that port from the Tools > Port menu and try uploading again.
If this doesn't solve the problem, please reply here on this forum thread with the answers to the following questions:
  • While following those instructions, did you see a port in the Tools > Port menu at step (6) that was not present at step (3)?
  • If you did see a new port, was the upload successful after you selected that port?
I didn't see any new port, just the ones that were connected on step (3)
Please try this troubleshooting procedure and then report your results in a reply on this forum thread:
:exclamation: This procedure is not intended to solve the problem. The purpose is to gather more information.
  2. Open the Windows Device Manager.
  3. Select View > Devices by type from the Device Manager menus.
  4. Open the "View" menu.
  5. If there is a to the left of the "Show hidden devices" menu item, click on "Show hidden devices" to disable it.
  6. Take note of the contents of the "Other devices" and "Ports (COM & LPT)" sections of the Device Manager tree.
  7. Connect the Arduino board to your computer with a USB cable.
  8. Select Action > Scan for hardware changes" from the Device Manager menus.
Did you see any new device appear in the Device Manager tree after doing this? If so, please tell us where it is located in the tree and what it is named.
You can repeat steps 5-8 multiple times if you are not sure.
It doesn't change anything
Make sure the USB cable is completely plugged into both the Arduino board and the PC.
If that doesn't help, you may have a damaged/defective or charge-only USB cable. Try a different cable.
Either of the above can result in the power connections being made (and thus LEDs lit on the board), but no data connections (and thus no port for the board).
I changed the USB and now it detects it in "Other Devices" as CP102 USB to UART Bridge Controler. What do I do now?
I've solved. The next step is to install the drivers to acces the board
Swhere do I get the driver for the cp102usb to uart bridge controler?
Hi @blanco. Get them from the official website of the manufacturer of the CP2102 chip (Silicon Labs):
Thank You.
