I have 3 questions
Hi, i am trying to do a fall detection device using NodeMCU and MPU-9250 module. For a start I am trying to print out the acceleration values from each axis.
This is the code I programmed into the NodeMCU.
IMU.readSensor();
//Accelerometer data code
Serial.print("Accelerometer X axis: ");
accex = IMU.getAccelX_mss();
Serial.print(accex, 3); // to get the accelerometer value from the data buffer in the X direction, these values are in meter per second square
Serial.print(" Accelerometer Y axis: ");
accey = IMU.getAccelY_mss();
Serial.print(accey, 3);
accez = IMU.getAccelZ_mss();
Serial.print(" Accelerometer Z axis: ");
Serial.println(accez, 3);
After I programmed this into the NodeMCU, I was able to get the acceleration values of each axis. as shown below.
- Why is the z axis acceleration -8, shouldn't it be 0 as well?
Another thing I noticed that, when hold the circuit upside down, the z axis acceleration becomes 11 as shown below.
2)Why did it go high?
3)Similarly, when I tilt it 90 degrees to left and hold it still the x axis acceleration went up to 11 as well. Shouln't it be 0 as well if I hold it still, why is it 11?
Please enlighten me on this. I am new to this MPU-9250 module.
