I just realized I made an error in my drawing, The 9 volts DC input goes to VIN.
just to update you on the changes I’ve made;
- I am using pin 9 as an output instead of pin 1.
- I am now powering the relay board with its own power supply.
- I am now powering the nano with its own power supply.
- I have gone from external pull up resistors to internal pull up.
- I have changed my code for my outputs to the relays to read the following
digitalWrite(5, HIGH); pinMode(5, OUTPUT);
External strong pullup would be better.
In an industrial-like environment, it is necessary to apply strong filtering to the inputs. With the following circuit, we have:
- Strong pull-down, 645 Ω
- 14 mA of wetting current for the contact
- 33 kΩ isolation between the input pin and the external world
- RF bypass capacitor and debounce with a time constant > 3 ms.
- 9 V for the contacts to minimize interference with the 5 V logic section.
NOTE: in this case, configure the pin as INPUT, not INPUT_PULLUP
Have your changes fixed the problem or do you still have interference from the AC?
What steps have you taken, if any, to help reduce the AC interference?
