iam steering and Servo with a Potentiometer. But when i move the Poti to fast the Servo stucks or will not reach the final Position. Is there a Way to fix this ?
#include <Servo.h>
Servo myservo; // create servo object to control a servo
int potpin = 0; // analog pin used to connect the potentiometer
int val; // variable to read the value from the analog pin
myservo.attach(8); // attaches the servo on pin 9 to the servo object
val = analogRead(potpin); // reads the value of the potentiometer (value between 0 and 1023)
val = map(val, 0, 1023, 0, 180); // scale it to use it with the servo (value between 0 and 180)
myservo.write(val); // sets the servo position according to the scaled value
delay(15); // waits for the servo to get there
hegi:
Avoid poor power supply for the servo (i.e. do not use Arduino board 5V pin for servo power supply)!
Use only good and adequate power supply for the servo!
