I am trying to incorporate this sketch into the second one. Both sketches work as expected, until I added the first to the second.
/// @file RGBSetDemo.ino
/// @brief Demonstrates how to create an LED group with CRGBArray
/// @example RGBSetDemo.ino
#include <FastLED.h>
#define NUM_LEDS 120
CRGBArray<NUM_LEDS> leds;
FastLED.addLeds<NEOPIXEL,3>(leds, NUM_LEDS);
randomSeed(analogRead(A0));
void loop(){
int myVar=random(0,3);
switch (myVar) {
case 0:
red();
case 1:
blue();
case 2:
white();
void red(){
//static uint8_t hue;
for(int i = 0; i < NUM_LEDS/2; i++) {
// fade everything out
leds.fadeToBlackBy(random(10,25));
// let's set an led value
leds[i] = CRGB(250,0,0);
// now, let's first 20 leds to the top 20 leds,
leds(NUM_LEDS/2,NUM_LEDS-1) = leds(NUM_LEDS/2 - 1 ,0);
FastLED.delay(random (2,30));
void blue(){
leds[i] = CRGB(0,0,250);
FastLED.delay(random(2,30));
void white(){
leds[i] = CRGB(250,250,250);
#define LED_PIN 3
CRGB leds[NUM_LEDS];
uint8_t data[ NUM_LEDS];
delay(3000);
FastLED.addLeds<WS2812B, LED_PIN, GRB>(leds, NUM_LEDS).setCorrection(TypicalLEDStrip);
FastLED.setBrightness(100);
FastLED.setMaxPowerInVoltsAndMilliamps(5, 1000);
int seqVar = random(0, 9);
//uint32_t period2 = .2 * 60000L; // X minutes
uint32_t period2 = random(10,20) * 1000L; // X seconds
for ( uint32_t tStart = millis(); (millis() - tStart) < period2; )
switch (seqVar) {
case 0:
//uint32_t period2 = .1 * 60000L; // X minutes
//for ( uint32_t tStart = millis(); (millis() - tStart) < period2; )
movingDotred();
case 1:
movingDotwhite();
case 2:
movingDotblue();
case 3:
//uint32_t period3 = .3 * 60000L; // X minutes
phaseBeat();
case 4:
redwhitebluestripeswithglitter();
case 5:
RWBFadeInandOut();
case 6:
NewKITT(0xff, 0, 0, 35, 2, 50);
NewKITT(0, 0, 0xff, 35, 2, 50);
NewKITT(0xff, 0xff, 0xff, 35, 2, 50);
case 7:
theaterChase(0xff, 0, 0, 70);
theaterChase(0xff, 0xff, 0xff, 70);
theaterChase(0, 0, 0xff, 70);
case 8:
outsideinmeteors;
void movingDotred() {
uint16_t sinBeat = beatsin16(20, 0, NUM_LEDS - 1, 0, 0);
leds[sinBeat] = CRGB::Red;
fadeToBlackBy(leds, NUM_LEDS, 10);
FastLED.show();
void movingDotwhite() {
leds[sinBeat] = CRGB::White;
FastLED.show();
void movingDotblue() {
leds[sinBeat] = CRGB::Blue;
FastLED.show();
void phaseBeat() {
// uint8_t sinBeat = beatsin8(15, 0, NUM_LEDS - 1, 0, 0);
// uint8_t sinBeat2 = beatsin8(15, 0, NUM_LEDS - 1, 0, 85);
// uint8_t sinBeat3 = beatsin8(15, 0, NUM_LEDS - 1, 0, 170);
// If you notice that your pattern is missing out certain LEDs, you
// will need to use the higher resolution beatsin16 instead. In this
// case remove the 3 lines above and replace them with the following:
uint16_t sinBeat = beatsin16(15, 0, NUM_LEDS - 1, 0, 0);
uint16_t sinBeat2 = beatsin16(15, 0, NUM_LEDS - 1, 0, 21845);
uint16_t sinBeat3 = beatsin16(15, 0, NUM_LEDS - 1, 0, 43690);
leds[sinBeat2] = CRGB::Red;
leds[sinBeat3] = CRGB::White;
FastLED.show();
void redwhitebluestripeswithglitter() {
fill_data_array();
render_data_with_palette();
add_glitter();
FastLED.show();
FastLED.delay(20);
void fill_data_array()
static uint8_t startValue = 0;
startValue = startValue + 2;
uint8_t value = startValue;
for ( int i = 0; i < NUM_LEDS; i++) {
data[i] = triwave8( value); // convert value to an up-and-down wave
value += 3;
CRGBPalette16 gPalette (
CRGB::Black, CRGB::Black,
CRGB::Red, CRGB::Red, CRGB::Red, CRGB::Red,
CRGB::Gray, CRGB::Gray, CRGB::Gray, CRGB::Gray,
CRGB::Blue, CRGB::Blue, CRGB::Blue, CRGB::Blue,
void render_data_with_palette()
leds[i] = ColorFromPalette( gPalette, data[i], 128, LINEARBLEND);
void add_glitter()
int chance_of_glitter = 10; // percent of the time that we add glitter
int number_of_glitters = 10; // number of glitter sparkles to add
int r = random8(100);
if ( r < chance_of_glitter ) {
for ( int j = 0; j < number_of_glitters; j++) {
int pos = random16( NUM_LEDS);
leds[pos] = CRGB::White; // very bright glitter
void RWBFadeInandOut() {
FadeInOut(0xff, 0x00, 0x00); // red
FadeInOut(0xff, 0xff, 0xff); // white
FadeInOut(0x00, 0x00, 0xff); // blue
void setAll(byte red, byte white, byte blue) {
for (int i = 0; i < NUM_LEDS; i++ ) {
setPixel(i, red, white, blue);
FastLED.show();
void setPixel(int Pixel, byte red, byte white, byte blue) {
leds[Pixel].r = red;
leds[Pixel].g = white;
leds[Pixel].b = blue;
void FadeInOut(byte red, byte green, byte blue) {
float r, g, b;
for (int k = 0; k < 256; k = k + 5) {
r = (k / 256.0) * red;
g = (k / 256.0) * green;
b = (k / 256.0) * blue;
setAll(r, g, b);
FastLED.show();
for (int k = 255; k >= 0; k = k - 5) {
setAll(r, g, b);
FastLED.show();
void NewKITT(byte red, byte green, byte blue, int EyeSize, int SpeedDelay, int ReturnDelay) {
RightToLeft(red, green, blue, EyeSize, SpeedDelay, ReturnDelay);
LeftToRight(red, green, blue, EyeSize, SpeedDelay, ReturnDelay);
OutsideToCenter(red, green, blue, EyeSize, SpeedDelay, ReturnDelay);
CenterToOutside(red, green, blue, EyeSize, SpeedDelay, ReturnDelay);
// LeftToRight(red, green, blue, EyeSize, SpeedDelay, ReturnDelay);
// RightToLeft(red, green, blue, EyeSize, SpeedDelay, ReturnDelay);
// OutsideToCenter(red, green, blue, EyeSize, SpeedDelay, ReturnDelay);
// CenterToOutside(red, green, blue, EyeSize, SpeedDelay, ReturnDelay);
void CenterToOutside(byte red, byte green, byte blue, int EyeSize, int SpeedDelay, int ReturnDelay) {
for (int i = ((NUM_LEDS - EyeSize) / 2); i >= 0; i--) {
setAll(0, 0, 0);
setPixel(i, red / 10, green / 10, blue / 10);
for (int j = 1; j <= EyeSize; j++) {
setPixel(i + j, red, green, blue);
setPixel(i + EyeSize + 1, red / 10, green / 10, blue / 10);
setPixel(NUM_LEDS - i, red / 10, green / 10, blue / 10);
setPixel(NUM_LEDS - i - j, red, green, blue);
setPixel(NUM_LEDS - i - EyeSize - 1, red / 10, green / 10, blue / 10);
FastLED.show();
delay(SpeedDelay);
delay(ReturnDelay);
void OutsideToCenter(byte red, byte green, byte blue, int EyeSize, int SpeedDelay, int ReturnDelay) {
for (int i = 0; i <= ((NUM_LEDS - EyeSize) / 2); i++) {
setAll(0, 0, 0);
FastLED.show();
delay(SpeedDelay);
delay(ReturnDelay);
void LeftToRight(byte red, byte green, byte blue, int EyeSize, int SpeedDelay, int ReturnDelay) {
for (int i = 0; i < NUM_LEDS - EyeSize - 2; i++) {
setAll(0, 0, 0);
FastLED.show();
delay(SpeedDelay);
delay(ReturnDelay);
void RightToLeft(byte red, byte green, byte blue, int EyeSize, int SpeedDelay, int ReturnDelay) {
for (int i = NUM_LEDS - EyeSize - 2; i > 0; i--) {
setAll(0, 0, 0);
FastLED.show();
delay(SpeedDelay);
delay(ReturnDelay);
void theaterChase(byte red, byte green, byte blue, int SpeedDelay) {
for (int j = 0; j < 10; j++) { //do 10 cycles of chasing
for (int q = 0; q < 3; q++) {
for (int i = 0; i < NUM_LEDS; i = i + 3) {
setPixel(i + q, red, green, blue); //turn every third pixel on
FastLED.show();
delay(SpeedDelay);
setPixel(i + q, 0, 0, 0); //turn every third pixel off
void outsideinmeteors(){
switch (myVar) {
case 0:
red();
case 1:
blue();
case 2:
white();
void red(){
void blue(){
void white(){
I am getting errors relating to my two ways of calling fadeToBlackBy. I think it relates to how I am defining my array - I am stretching my knowledge here.
I have tried changing the first sketch to more closely match the second - just in terms of CRGBArray definition but i am falling down a rabbit hole. I have watched few fadeToBlack vids but they shed no light.
Can someone suggest a way to go? Should I try to change the first sketch to be compatible with the second - how, or modify the second sketch?
Thanks -
