FastLED Error
I am trying to use the FastLED library but am having a problem. Here is my code:
#include <Snake.h>
#define LED_PIN 13
#define NUM_LEDS 64
#define GRID_WIDTH 8
CRGB leds[NUM_LEDS];
  FastLED.addLeds<WS2812, LED_PIN>(leds, NUM_LEDS);
void loop() {}
Snake.h is a library that I wrote which has #include <FastLED.h>.
The error I am getting is error: expected initializer before 'leds' on CRGB leds[NUM_LEDS];, but I don't see how I am doing anything wrong. If I don't use the Snake library and directly import FastLED.h, I don't get any error, but I need to use the CRGB type in Snake.
make sure you have the right board, it doesn't work on many.
sevenoutpinball:
I am using an Uno (and have it set correctly in the IDE), but at this point I am just trying to verify/compile the program; I'm not trying to upload it to the board.
You still need to include it in the main sketch also#include <FastLED.h>
Deva_Rishi:
I still get the same error when I include it in the main sketch.
Post your code.
Post the full error message(s)
Do you by any change have something like
#define CRGB whatever
in Snake.h?
edit
More likely you have forgotten the semicon after a class defintion:
class SomeClass {
TheMemberFormerlyKnownAsAWOL:
Post your code.
The error message:
In file included from C:\Users\gabem\Desktop\JonahGift\JonahGift.ino:1:0:
C:\Users\gabem\Documents\Arduino\libraries\FastLED/FastLED.h:14:21: note: #pragma message: FastLED version 3.003.003
 #    pragma message "FastLED version 3.003.003"
JonahGift:10:6: error: expected initializer before 'leds'
C:\Users\gabem\Desktop\JonahGift\JonahGift.ino: In function 'void setup()':
JonahGift:70:36: error: 'leds' was not declared in this scope
C:\Users\gabem\Desktop\JonahGift\JonahGift.ino:70:36: note: suggested alternative: 'gets'
                                    gets
exit status 1
The sketch:
#include <Snake.h>
#define LED_PIN 13
#define NUM_LEDS 64
void loop() {}
The header (Snake.h):
#ifndef Snake_h
#define Snake_h
#include "Arduino.h"
class Snake {
    public:
    Snake(int initial_r, int initial_c, CRGB c_body, CRGB c_body_fade,
    CRGB c_tail, CRGB c_tail_fade, int num_links);
    // Called on the head of the snake, which calls move on itself
    int moveHead(int dir, int width, CRGB* leds);
    // Checks if the head of this snake has intersected the other snake
    // If so, and this snake isn't faded and it intersected the other snake's tail,
    // this player wins. If the snake is faded, keep going. If the snake isn't faded
    // and is not touching the tail, fade it.
    // returns 0 if no collision
    // returns 1 if a body collision or faded tail collision
    // returns 2 if an unfaded tail collision
    int checkCollision(Snake* other_snake);
    // Checks if any links of this snake is intersecting the other snake
    bool checkIntersection(Snake* other_snake);
    void fadeColor(bool fade, int width, CRGB* leds);
    bool isFaded();
    void setColor(int width, CRGB* leds);
    void reset(int reset_r, int reset_c);
    private:
    // checks if any of this snake's links are at location (check_r, check_c)
    // returns 0 if no links are at the location
    // returns 1 if a body link is at the location
    // returns 2 if the tail link is at the location
    int isIntersecting(int check_r, int check_c);
    // moves the link to a new position and sets the color
    int move(int new_r, int new_c, int width, CRGB* leds);
    int r, c;
    int last_move;
    CRGB color_cur, color_reg, color_fade;
    bool faded;
    Snake* next;
#endif
The source:
#include "Snake.h"
Snake::Snake(int initial_r,
             int initial_c,
             CRGB c_body,
             CRGB c_body_fade,
             CRGB c_tail,
             CRGB c_tail_fade,
             int num_links) {
    r = initial_r;
    c = initial_c;
    last_move = -1;
    faded = false;
    if(num_links != 0) {
        color_cur = c_body;
        color_reg = c_body;
        color_fade = c_body_fade;
        next = new Snake(r-1, c, c_body, c_body_fade, c_tail, c_tail_fade, num_links-1);
    else {
        color_cur = c_tail;
        color_reg = c_tail;
        color_fade = c_tail_fade;
        next = nullptr;
void Snake::reset(int reset_r, int reset_c) {
    r = reset_r;
    c = reset_c;
    color_cur = color_reg;
    faded = false;
    last_move = -1;
    if(next != nullptr) {
        next->reset(reset_r-1, reset_c);
int Snake::moveHead(int dir, int width, CRGB* leds) {
    if(dir == last_move) {
        return -1;
    int next_r = r, next_c = c;
    if(dir == 0) { // Up
        if(r == 0) { // loop from the top
            next_r = width-1;
            next_r--;
    else if(dir == 1) { // Right
        if(c == width-1) { // loop from the right
            next_c = 0;
            next_c++;
    else if(dir == 2) { // Down
        if(r == width-1) { // loop from the bottom
            next_r = 0;
            next_r++;
    else if(dir == 3) { // Left
        if(c == 0) {
            next_c = width-1;
            next_c--;
    last_move = dir;
    move(next_r, next_c, leds);
int Snake::checkCollision(Snake* other_snake) {
    int collision = other_snake->isIntersecting(r, c);
    if(collision == 0) {
        return 0;
    if(collision==2 && !faded) {
        return 2;
    if(collision==2 && faded) {
        return 1;
    if(collision==1) {
        if(!faded) {
            fadeColor(true);
        return 1;
    return -1;
bool Snake::checkIntersection(Snake* other_snake) {
    int intersect = other_snake->isIntersecting(r, c);
    if(intersect != 0) {
        return true;
    else {
        if(next == nullptr) {
            return false;
        return next->checkIntersection(other_snake);
void Snake::fadeColor(bool fade, int width, CRGB* leds) {
    if(fade == faded) {
        return;
    color_cur = (fade) ? color_fade : color_reg;
    faded = fade;
    leds[r * width + c] = color_cur;
        next->fadeColor(fade);
bool Snake::isFaded() {
    return faded;
void Snake::setColor(int width, CRGB* leds) {
        next->setColor(width, leds);
int Snake::isIntersecting(int check_r, int check_c) {
    if(check_r == r && check_c == c) {
        return (next != nullptr) ? 1 : 2;
    else {
        return (next != nullptr) ? next->isIntersecting(check_r, check_c) : 0;
int Snake::move(int new_r, int new_c, int width, CRGB* leds) {
        leds[r * width + c] = CRGB::Black;
        r = new_r;
        c = new_c;
        return 0;
    int last_r = r, last_c = c;
    r = new_r;
    c = new_c;
    return next->move(last_r, last_c, width, leds);
    Snake* next;
#endif
Yep, missing semicolon.
And @oqibidipo has it!
See how easy it is when you post code?
oqibidipo:
in Snake.h?
edit
class SomeClass {
You're completely right, I fixed that and am getting a different error, but one that I can handle. Thank you very much!
