I was wondering if someone could look over this sketch for me, and let me know if and where I have made any mistakes. It is a hash of a few example sketches. I'm a complete noob to coding and I have no idea where to go from here.
The sketch is currently “running” on a Nano clone, and I am experiencing resetting, freezing when the ScreenSavers exit, and the DisplayClock portion of the code runs. The sketch will usually reset the Nano then display the clock, (PIR sensor is active (HIGH) for 10 seconds). On the odd occasion, it will completely lock up forcing a reset via on-board button.
Serial.print in the sketch is there for debugging porpoises and does not change how the sketch behaves.
I have also ran the three function consecutively with the same behaviour.
Sorry if this is not the correct section.
Much thanks
Code below.
#include <FastLED.h>
#include <Adafruit_GFX.h>
#include <FastLED_NeoMatrix.h>
#include <gamma.h>
#include <Wire.h>
#include "DS3231.h"
DS3231 Clock;
RTClib RTC;
#define PIN_PIX 6 //LED Matrix
#define PIN_PIR 3 //PIR Sensor
#define PIN_BUT_ADJ 10 // Push Button for clock adjustment
#define PIN_BUT_HP 11 // Push button to add hour to clock
#define PIN_BUT_MP 12 // Push button to add minute to clock
#define matrixWidth 32
#define matrixHeight 8
#define NUM_LEDS matrixWidth * matrixHeight
#define FASTLED_ALLOW_INTERRUPTS 0
#define UPDATES_PER_SECOND 100
uint8_t Switcher = 0;
byte bcurHour = 11;
byte bcurMin = 22;
String curTime = "01:02";
//Noise Playgroud default values
uint32_t x, y, v_time, hue_time, hxy;
uint8_t octaves = 1;
uint8_t hue_octaves = 1;
int xscale = 7771;
int yscale = 7771;
uint8_t hue_scale = 4;
uint8_t time_speed = 111;
uint8_t hue_speed = 1;
int x_speed = 331;
int y_speed = 1111;
CRGB leds[NUM_LEDS]; //this value randomly multiplies itself causing arduino to lock up
//FastLED Matrix Configuration
FastLED_NeoMatrix *matrix = new FastLED_NeoMatrix(leds, matrixWidth, matrixHeight, matrixWidth / matrixWidth, 1,
NEO_MATRIX_BOTTOM + NEO_MATRIX_RIGHT +
NEO_MATRIX_COLUMNS + NEO_MATRIX_ZIGZAG );
const uint16_t colors[] = {matrix->Color(240, 255, 255)};
CRGBPalette16 currentPalette( CRGB::Black);
CRGBPalette16 targetPalette( PartyColors_p );
Serial.begin(57600);
Serial.println(F("resetting!"));
delay(4000);
Wire.begin();
pinMode(PIN_BUT_ADJ, INPUT);
pinMode(PIN_BUT_HP, INPUT);
pinMode(PIN_BUT_MP, INPUT);
pinMode(PIN_PIR, INPUT);
FastLED.addLeds<WS2812, PIN_PIX, GRB>(leds, NUM_LEDS);
//Serial.println(NUM_LEDS);
FastLED.setBrightness(50);
FastLED.clear();
matrix->begin();
matrix->setTextWrap(false);
matrix->setBrightness(1);
matrix->setTextColor(colors[0]);
matrix->clear();
//Noise Playgroud more default values
random16_set_seed(3000);
//random16_add_entropy(analogRead(3));
random16_add_entropy(analogRead(1));
hxy = (uint32_t)((uint32_t)random16() << 16) + (uint32_t)random16();
x = (uint32_t)((uint32_t)random16() << 16) + (uint32_t)random16();
v_time = (uint32_t)((uint32_t)random16() << 16) + (uint32_t)random16();
hue_time = (uint32_t)((uint32_t)random16() << 16) + (uint32_t)random16();
if (digitalRead(PIN_PIR) == LOW) {
if (Switcher == 0) {
//Noise Playgroud Randomised values
xscale = random(-8000, 8000);
yscale = xscale;
hue_scale = random(2, 4.1);
octaves = random(1, 3.1);
hue_octaves = random(1, 3.1);
hue_speed = random(1, 3.1);
//Serial.println(F("Start Screensaver!"));*/
ScreenSaver01();
Switcher = 1;
ScreenSaver02();
Switcher = 0;
//Serial.println(F("Start Clock!"));
ClockDisplay();
void ClockDisplay() {
Serial.println(F("Clock Start"));
FastLED.clear();
//FastLED.show();
matrix->clear();
matrix->show();
delay(20);
bool h12;
bool PM;
for (int i = 0; i <= 10; i++) {
DateTime now = RTC.now();
if (Clock.getHour(h12, PM) < 10)
bcurHour = '0', Clock.getHour(h12, PM);
bcurHour = Clock.getHour(h12, PM);
if (Clock.getMinute() < 10)
bcurMin = '0', Clock.getMinute();
bcurMin = Clock.getMinute();
Serial.println(F("Set Time"));
delay(100);
//String cDiv = ":";
String cDiv = "|";
String cSpa = " ";
curTime = bcurHour + cDiv + bcurMin;
Serial.println(F("Print Time"));
delay(100);
matrix->setBrightness(((500 - (analogRead(1) / 2)) / 20));
Serial.println(F("setBrightness"));
delay(100);
//matrix->fillScreen(0);
matrix->clear();
Serial.println(F("fillScreen"));
delay(100);
matrix->show();
Serial.println(F("Show"));
delay(100);
matrix->setCursor(1, 0);
Serial.println(F("setCursor")); //usually the last line printed in serial interface before reset
delay(100);
matrix->print(curTime);
Serial.println(F("Print"));
delay(100);
matrix->show();
delay(100);
Serial.println(F("Half Time"));
matrix->clear();
curTime = bcurHour + cSpa + bcurMin;
matrix->show();
Serial.println(F("Displayed Time"));
matrix->clear();
matrix->show();
Serial.println(F("ClockMain!EXIT"));
delay(2000);
void ScreenSaver01() {
Serial.println(F("Screen Saver 01!"));
delay(10);
for (int i = 0; i <= 200; i++) {
fill_2dnoise16(FastLED.leds(), 32, 8, false,
octaves, x, xscale, y, yscale, v_time,
hue_octaves, hxy, hue_scale, hxy, hue_scale, hue_time, false);
FastLED.setBrightness(220 - (analogRead(1) / 4));
FastLED.show();
Serial.print(F("SS01-"));
Serial.println(i);
// adjust the intra-frame time values
x += x_speed;
y += y_speed;
v_time += time_speed;
hue_time += hue_speed;
//FastLED.clear();
//FastLED.show();
Serial.println(F("Screen Saver01! BREAK"));
//delay(1000);
//ClockDisplay(); // loop change here seems to reset arduino or crash sketch
FastLED.clear();
FastLED.show();
Serial.println(F("Main Loop SS01! EXIT"));
void ScreenSaver02() {
Serial.println(F("Screen Saver 02!"));
ChangePalettePeriodically();
uint8_t maxChanges = 24;
nblendPaletteTowardPalette( currentPalette, targetPalette, maxChanges);
static uint8_t startIndex = 0;
startIndex = startIndex + 1; /* motion speed */
FillLEDsFromPaletteColors( startIndex);
Serial.print(F("SS02-"));
Serial.println(i);
FastLED.show();
FastLED.delay(1000 / UPDATES_PER_SECOND);
//FastLED.clear();
//FastLED.show();
Serial.println(F("Main Loop SS02! BREAK"));
//delay(2000);
FastLED.clear();
FastLED.show();
Serial.println(F("Screen Saver 02!EXIT"));
delay(2000);
void FillLEDsFromPaletteColors( uint8_t colorIndex) {
uint8_t brightness = (220 - (analogRead(1) / 4));
for ( int i = 0; i < NUM_LEDS; i++) {
leds[i] = ColorFromPalette( currentPalette, colorIndex + sin8(i * 16), brightness);
colorIndex += 3;
void ChangePalettePeriodically() {
uint8_t secondHand = (millis() / 1000) % 60;
static uint8_t lastSecond = 99;
if ( lastSecond != secondHand) {
lastSecond = secondHand;
CRGB p = CHSV( HUE_PURPLE, 255, 255);
CRGB g = CHSV( HUE_GREEN, 255, 255);
CRGB b = CRGB::Black;
CRGB w = CRGB::White;
if ( secondHand == 0) {
targetPalette = RainbowColors_p;
if ( secondHand == 10) {
targetPalette = CRGBPalette16( g, g, b, b, p, p, b, b, g, g, b, b, p, p, b, b);
if ( secondHand == 20) {
targetPalette = CRGBPalette16( b, b, b, w, b, b, b, w, b, b, b, w, b, b, b, w);
if ( secondHand == 30) {
targetPalette = LavaColors_p;
if ( secondHand == 40) {
targetPalette = CloudColors_p;
if ( secondHand == 50) {
targetPalette = PartyColors_p;
