Fatal error : EEPROMex.h: No such file or directory (Need Help NOOB)
Hello my friends. I'll start by saying this is my very first use of arduino so I'm learning all that I can but it is quite overwhelming and I have tried to look up this error already but couldn't make much sense out of it.
I am using IDE 1.8.19 on Windows 10 and I believe my board is a chinese clone. I have uploaded 'blink' and 'fade' test sketches and they work just fine.
It appears my Arduino is working just fine and when I uploade 'fade' sketch one of the LEDs on the device I built which is connected to the Arduino fades in and out so I think my device is working too so any help would be great as I am a complete noob at this and am already really happy I have made it this far. Thanks in advance my friends.
Welcome to the forum
Use code tags (the </> icon above the compose window) to make it easier to read and copy for examination
  MIDI_PsychoGalvanometer v021
  Accepts pulse inputs from a Galvanic Conductance sensor
  consisting of a 555 timer set as an astablemultivibrator and two electrodes.
  Through sampling pulse widths and identifying fluctuations, MIDI note and control messages
  are generated.  Features include Threshold, Scaling, Control Number, and Control Voltage
  using PWM through an RC Low Pass filter.
  MIDIsprout.com
#include <EEPROMex.h> //store and read variables to nonvolitle memory
#include <Bounce2.h> //https://github.com/thomasfredericks/Bounce-Arduino-Wiring
#include <LEDFader.h> //manage LEDs without delay() jgillick/arduino-LEDFader https://github.com/jgillick/arduino-LEDFader.git
int maxBrightness = 190;
//set scaled values, sorted array, first element scale length
const int scaleCount = 5;
const int scaleLen = 13; //maximum scale length plus 1 for 'used length'
int currScale = 0; //current scale, default Chrom
int scale[scaleCount][scaleLen] = {
  {12, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12}, //Chromatic
  {7, 1, 3, 5, 6, 8, 10, 12}, //Major
  {7, 1, 3, 4, 6, 8, 9, 11}, //DiaMinor
  {7, 1, 2, 2, 5, 6, 9, 11}, //Indian
  {7, 1, 3, 4, 6, 8, 9, 11} //Minor
int root = 0; //initialize for root, pitch shifting
const byte interruptPin = INT0; //galvanometer input
const byte knobPin = A0; //knob analog input
Bounce button = Bounce(); //debounce button using Bounce2
const byte buttonPin = A1; //tact button input
int menus = 5; //number of main menus
int mode = 0; //0 = Threshold, 1 = Scale, 2 = Brightness
int currMenu = 0;
const byte samplesize = 10; //set sample array size
const byte analysize = samplesize - 1;  //trim for analysis array
const byte polyphony = 5; //above 8 notes may run out of ram
int channel = 1;  //setting channel to 11 or 12 often helps simply computer midi routing setups
int noteMin = 36; //C2  - keyboard note minimum
int noteMax = 96; //C7  - keyboard note maximum
byte QY8 = 0; //sends each note out chan 1-4, for use with General MIDI like Yamaha QY8 sequencer
byte controlNumber = 80; //set to mappable control, low values may interfere with other soft synth controls!!
byte controlVoltage = 1; //output PWM CV on controlLED, pin 17, PB3, digital 11 *lowpass filter
long batteryLimit = 3000; //voltage check minimum, 3.0~2.7V under load; causes lightshow to turn off (save power)
byte checkBat = 1;
byte timeout = 0;
int value = 0;
int prevValue = 0;
volatile unsigned long microseconds; //sampling timer
volatile byte index = 0;
volatile unsigned long samples[samplesize];
float threshold = 1.7;   //2.3;  //change threshold multiplier
float threshMin = 1.61; //scaling threshold min
float threshMax = 3.71; //scaling threshold max
float knobMin = 1;
float knobMax = 1024;
unsigned long previousMillis = 0;
unsigned long currentMillis = 1;
unsigned long batteryCheck = 0; //battery check delay timer
unsigned long menuTimeout = 5000; //5 seconds timeout in menu mode
#define LED_NUM 6
LEDFader leds[LED_NUM] = { // 6 LEDs (perhaps 2 RGB LEDs)
  LEDFader(3),
  LEDFader(5),
  LEDFader(6),
  LEDFader(9),
  LEDFader(10),
  LEDFader(11)  //Control Voltage output or controlLED
int ledNums[LED_NUM] = {3, 5, 6, 9, 10, 11};
byte controlLED = 5; //array index of control LED (CV out)
byte noteLEDs = 1;  //performs lightshow set at noteOn event
typedef struct _MIDImessage { //build structure for Note and Control MIDImessages
  unsigned int type;
  int value;
  int velocity;
  long duration;
  long period;
  int channel;
MIDImessage;
MIDImessage noteArray[polyphony]; //manage MIDImessage data as an array with size polyphony
int noteIndex = 0;
MIDImessage controlMessage; //manage MIDImessage data for Control Message (CV out)
  pinMode(knobPin, INPUT);
  pinMode(buttonPin, INPUT_PULLUP);
  button.attach(buttonPin);
  button.interval(5);
  randomSeed(analogRead(0)); //seed for QY8 4 channel mode
  Serial.begin(31250);  //initialize at MIDI rate
  //Serial.begin(9600); //for debugging
  controlMessage.value = 0;  //begin CV at 0
  //MIDIpanic(); //dont panic, unless you are sure it is nessisary
  checkBattery(); // shut off lightshow if power is too low
  if (noteLEDs) bootLightshow(); //a light show to display on system boot
  attachInterrupt(interruptPin, sample, RISING);  //begin sampling from interrupt
  currentMillis = millis();   //manage time
  //checkBattery(); //on low power, shutoff lightShow, continue MIDI operation
  checkButton();  //its about to get really funky in here
  if (index >= samplesize)  {
    analyzeSample();  //if samples array full, also checked in analyzeSample(), call sample analysis
  checkNote();  //turn off expired notes
  checkControl();  //update control value
  checkLED();  //LED management without delay()
  if (currMenu > 0) checkMenu(); //allow main loop by checking current menu mode, and updating millis
I didn't initially post the sketch as it isn't one I wrote so it shouldn't have any errors. It's one that has been used by others many times but hopefully I have uploaded it properly now. Thanks again.
The error message tells you exactly what the problem is as does the title that you gave this topic
Have you got the EEPROMex library installed on your PC ?
Note that the library has been made redundant by changes made to the EEPROM library but to use that you would need to make changes to the sketch
Hold on a minute, does the sketch even use the EEPROM ?
If not, then why #include the library ?
In any case, there are other problems with the sketch such as missing functions such as checkButton()
Please post the full error message, copied with teh "Copy error message" button in the IDE and post them here in code tags
Based on the image of post1, I believe that there are additional files on tabs for the Biosonification program.
Can you please post the code in all the tabs.
