I keep getting the No such file or directory error, even though my Weather Station sketch compiled before.
In attempts to fix the problem, I have tried moving folders, deleting, reloading.
This is the latest error message:
C:\Users\i5170\OneDrive\Documents\Arduino\WeatherStationDemo\WeatherStn1910\WeatherStn1910.ino:3:10: fatal error: ESPWiFi.h: No such file or directory
3 | #include <ESPWiFi.h>
compilation terminated.
I changed my Sketch preferences to avoid One Drive, and have no idea why the compiler is looking for the library there.
I was not sure about posting the whole sketch and error message, as its quite long.
However here it is: `
#include "Wire.h"
#include <ESP8266WiFi.h>
#include <ESPHTTPClient.h>
#include <JsonListener.h>
// time
#include <time.h> // time() ctime()
#include <sys/time.h> // struct timeval
#include <coredecls.h> // settimeofday_cb()
#include "SSD1306Wire.h"
#include "OLEDDisplayUi.h"
#include "Wire.h"
#include "OpenWeatherMapCurrent.h"
#include "OpenWeatherMapForecast.h"
#include "WeatherStationFonts.h"
#include "WeatherStationImages.h"
#include <Adafruit_BMP085.h>
* WIFI Settings
const char* WIFI_SSID = "insert name";
const char* WIFI_PWD = "pw inserted";
* Begin DHT11 Settings
WiFiClient client;
const char *host = "api.thingspeak.com"; //IP address of the thingspeak server
const char *api_key ="my api key"; //Your own thingspeak api_key
const int httpPort = 80;
#define pin 14 // ESP8266-12E D5 read emperature and Humidity data
int temp = 0; //temperature
int humi = 0; //humidity
void readTemperatureHumidity();
void uploadTemperatureHumidity();
long readTime = 0;
long uploadTime = 0;
* Begin Atmosphere and Light Sensor Settings
void readLight();
void readAtmosphere();
Adafruit_BMP085 bmp;
const int Light_ADDR = 0b0100011; // address:0x23
const int Atom_ADDR = 0b1110111; // address:0x77
int tempLight = 0;
int tempAtom = 0;
* Begin Settings
#define TZ 2 // (utc+) TZ in hours
#define DST_MN 60 // use 60mn for summer time in some countries
// Setup
const int UPDATE_INTERVAL_SECS = 20 * 60; // Update every 20 minutes
// Display Settings
const int I2C_DISPLAY_ADDRESS = 0x3c;
#if defined(ESP8266)
//const int SDA_PIN = D1;
//const int SDC_PIN = D2;
const int SDA_PIN = D3;
const int SDC_PIN = D4;
#else
//const int SDA_PIN = GPIO5;
//const int SDC_PIN = GPIO4
const int SDA_PIN = GPIO0;
const int SDC_PIN = GPIO2
#endif
// OpenWeatherMap Settings
// Sign up here to get an API key:
// https://docs.thingpulse.com/how-tos/openweathermap-key/
const boolean IS_METRIC = true;
// Add your own thingpulse ID
String OPEN_WEATHER_MAP_APP_ID = "my id";
String OPEN_WEATHER_MAP_LOCATION = "Zurich,CH";
// Pick a language code from this list:
// Arabic - ar, Bulgarian - bg, Catalan - ca, Czech - cz, German - de, Greek - el,
// English - en, Persian (Farsi) - fa, Finnish - fi, French - fr, Galician - gl,
// Croatian - hr, Hungarian - hu, Italian - it, Japanese - ja, Korean - kr,
// Latvian - la, Lithuanian - lt, Macedonian - mk, Dutch - nl, Polish - pl,
// Portuguese - pt, Romanian - ro, Russian - ru, Swedish - se, Slovak - sk,
// Slovenian - sl, Spanish - es, Turkish - tr, Ukrainian - ua, Vietnamese - vi,
// Chinese Simplified - zh_cn, Chinese Traditional - zh_tw.
String OPEN_WEATHER_MAP_LANGUAGE = "en";
const uint8_t MAX_FORECASTS = 4;
// Adjust according to your language
const String WDAY_NAMES[] = {"SUN", "MON", "TUE", "WED", "THU", "FRI", "SAT"};
const String MONTH_NAMES[] = {"JAN", "FEB", "MAR", "APR", "MAY", "JUN", "JUL", "AUG", "SEP", "OCT", "NOV", "DEC"};
* End Settings
// Initialize the oled display for address 0x3c
SSD1306Wire display(I2C_DISPLAY_ADDRESS, SDA_PIN, SDC_PIN);
OLEDDisplayUi ui( &display );
OpenWeatherMapCurrentData currentWeather;
OpenWeatherMapCurrent currentWeatherClient;
OpenWeatherMapForecastData forecasts[MAX_FORECASTS];
OpenWeatherMapForecast forecastClient;
#define TZ_MN ((TZ)*60)
#define TZ_SEC ((TZ)*3600)
#define DST_SEC ((DST_MN)*60)
time_t now;
// flag changed in the ticker function every 10 minutes
bool readyForWeatherUpdate = false;
String lastUpdate = "--";
long timeSinceLastWUpdate = 0;
//declaring prototypes
void drawProgress(OLEDDisplay *display, int percentage, String label);
void updateData(OLEDDisplay *display);
void drawDateTime(OLEDDisplay *display, OLEDDisplayUiState* state, int16_t x, int16_t y);
void drawCurrentWeather(OLEDDisplay *display, OLEDDisplayUiState* state, int16_t x, int16_t y);
void drawForecast(OLEDDisplay *display, OLEDDisplayUiState* state, int16_t x, int16_t y);
void drawForecastDetails(OLEDDisplay *display, int x, int y, int dayIndex);
void drawHeaderOverlay(OLEDDisplay *display, OLEDDisplayUiState* state);
void setReadyForWeatherUpdate();
// Add frames
// this array keeps function pointers to all frames
// frames are the single views that slide from right to left
FrameCallback frames[] = { drawDateTime, drawCurrentWeather, drawForecast };
int numberOfFrames = 3;
OverlayCallback overlays[] = { drawHeaderOverlay };
int numberOfOverlays = 1;
Wire.begin(0,2);
Wire.beginTransmission(Atom_ADDR);
//initialize Atmosphere sensor
if (!bmp.begin()) {
Serial.println("Could not find BMP180 or BMP085 sensor at 0x77");
}else{
Serial.println("Find BMP180 or BMP085 sensor at 0x77");
Wire.endTransmission();
//initialize light sensor
Wire.beginTransmission(Light_ADDR);
Wire.write(0b00000001);
// initialize dispaly
display.init();
display.clear();
display.display();
//display.flipScreenVertically();
display.setFont(ArialMT_Plain_10);
display.setTextAlignment(TEXT_ALIGN_CENTER);
display.setContrast(255);
WiFi.begin(WIFI_SSID, WIFI_PWD);
int counter = 0;
Serial.print(".");
display.clear();
display.drawString(64, 10, "Connecting to WiFi");
display.drawXbm(46, 30, 8, 8, counter % 3 == 0 ? activeSymbole : inactiveSymbole);
display.drawXbm(60, 30, 8, 8, counter % 3 == 1 ? activeSymbole : inactiveSymbole);
display.drawXbm(74, 30, 8, 8, counter % 3 == 2 ? activeSymbole : inactiveSymbole);
display.display();
counter++;
// Get time from network time service
configTime(TZ_SEC, DST_SEC, "pool.ntp.org");
ui.setTargetFPS(30);
ui.setActiveSymbol(activeSymbole);
ui.setInactiveSymbol(inactiveSymbole);
// You can change this to
// TOP, LEFT, BOTTOM, RIGHT
ui.setIndicatorPosition(BOTTOM);
// Defines where the first frame is located in the bar.
ui.setIndicatorDirection(LEFT_RIGHT);
// You can change the transition that is used
// SLIDE_LEFT, SLIDE_RIGHT, SLIDE_TOP, SLIDE_DOWN
ui.setFrameAnimation(SLIDE_LEFT);
ui.setFrames(frames, numberOfFrames);
ui.setOverlays(overlays, numberOfOverlays);
// Inital UI takes care of initalising the display too.
ui.init();
Serial.println("");
updateData(&display);
while (!client.connect(host, httpPort)) {
Serial.println("Connection Failed");
//Read Temperature Humidity every 5 seconds
if(millis() - readTime > 5000){
readLight();
readAtmosphere();
readTime = millis();
//Upload Temperature Humidity every 60 seconds
if(millis() - uploadTime > 60000){
uploadTime = millis();
if (millis() - timeSinceLastWUpdate > (1000L*UPDATE_INTERVAL_SECS)) {
timeSinceLastWUpdate = millis();
if (readyForWeatherUpdate && ui.getUiState()->frameState == FIXED) {
int remainingTimeBudget = ui.update();
if (remainingTimeBudget > 0) {
// You can do some work here
// Don't do stuff if you are below your
// time budget.
delay(remainingTimeBudget);
void drawProgress(OLEDDisplay *display, int percentage, String label) {
display->clear();
display->setTextAlignment(TEXT_ALIGN_CENTER);
display->setFont(ArialMT_Plain_10);
display->drawString(64, 10, label);
display->drawProgressBar(2, 28, 124, 10, percentage);
display->display();
void updateData(OLEDDisplay *display) {
drawProgress(display, 10, "Updating time...");
drawProgress(display, 30, "Updating weather...");
currentWeatherClient.setMetric(IS_METRIC);
currentWeatherClient.setLanguage(OPEN_WEATHER_MAP_LANGUAGE);
currentWeatherClient.updateCurrent(¤tWeather, OPEN_WEATHER_MAP_APP_ID, OPEN_WEATHER_MAP_LOCATION);
drawProgress(display, 50, "Updating forecasts...");
forecastClient.setMetric(IS_METRIC);
forecastClient.setLanguage(OPEN_WEATHER_MAP_LANGUAGE);
uint8_t allowedHours[] = {12};
forecastClient.setAllowedHours(allowedHours, sizeof(allowedHours));
forecastClient.updateForecasts(forecasts, OPEN_WEATHER_MAP_APP_ID, OPEN_WEATHER_MAP_LOCATION, MAX_FORECASTS);
drawProgress(display, 100, "Done...");
void drawDateTime(OLEDDisplay *display, OLEDDisplayUiState* state, int16_t x, int16_t y) {
now = time(nullptr);
struct tm* timeInfo;
timeInfo = localtime(&now);
char buff[16];
String date = WDAY_NAMES[timeInfo->tm_wday];
sprintf_P(buff, PSTR("%s, %02d/%02d/%04d"), WDAY_NAMES[timeInfo->tm_wday].c_str(), timeInfo->tm_mday, timeInfo->tm_mon+1, timeInfo->tm_year + 1900);
display->drawString(64 + x, 5 + y, String(buff));
display->setFont(ArialMT_Plain_24);
sprintf_P(buff, PSTR("%02d:%02d:%02d"), timeInfo->tm_hour, timeInfo->tm_min, timeInfo->tm_sec);
display->drawString(64 + x, 15 + y, String(buff));
display->setTextAlignment(TEXT_ALIGN_LEFT);
void drawCurrentWeather(OLEDDisplay *display, OLEDDisplayUiState* state, int16_t x, int16_t y) {
display->drawString(64 + x, 38 + y, currentWeather.description);
String temp = String(currentWeather.temp, 1) + (IS_METRIC ? "°C" : "°F");
display->drawString(60 + x, 5 + y, temp);
display->setFont(Meteocons_Plain_36);
display->drawString(32 + x, 0 + y, currentWeather.iconMeteoCon);
void drawForecast(OLEDDisplay *display, OLEDDisplayUiState* state, int16_t x, int16_t y) {
drawForecastDetails(display, x, y, 0);
drawForecastDetails(display, x + 44, y, 1);
drawForecastDetails(display, x + 88, y, 2);
void drawForecastDetails(OLEDDisplay *display, int x, int y, int dayIndex) {
time_t observationTimestamp = forecasts[dayIndex].observationTime;
timeInfo = localtime(&observationTimestamp);
display->drawString(x + 20, y, WDAY_NAMES[timeInfo->tm_wday]);
display->setFont(Meteocons_Plain_21);
display->drawString(x + 20, y + 12, forecasts[dayIndex].iconMeteoCon);
String temp = String(forecasts[dayIndex].temp, 0) + (IS_METRIC ? "°C" : "°F");
display->drawString(x + 20, y + 34, temp);
void drawHeaderOverlay(OLEDDisplay *display, OLEDDisplayUiState* state) {
char buff[14];
sprintf_P(buff, PSTR("%02d:%02d"), timeInfo->tm_hour, timeInfo->tm_min);
display->setColor(WHITE);
display->drawString(0, 54, String(buff));
display->setTextAlignment(TEXT_ALIGN_RIGHT);
display->drawString(128, 54, temp);
display->drawHorizontalLine(0, 52, 128);
void setReadyForWeatherUpdate() {
Serial.println("Setting readyForUpdate to true");
readyForWeatherUpdate = true;
//read temperature humidity data
void readTemperatureHumidity(){
int j;
unsigned int loopCnt;
int chr[40] = {0};
unsigned long time1;
bgn:
delay(2000);
//Set interface mode 2 to: output
//Output low level 20ms (>18ms)
//Output high level 40μs
pinMode(pin, OUTPUT);
digitalWrite(pin, LOW);
delay(20);
digitalWrite(pin, HIGH);
delayMicroseconds(40);
//Set interface mode 2: input
pinMode(pin, INPUT);
//High level response signal
loopCnt = 10000;
while (digitalRead(pin) != HIGH){
if (loopCnt-- == 0){
//If don't return to high level for a long time, output a prompt and start over
Serial.println("HIGH");
goto bgn;
//Low level response signal
loopCnt = 30000;
while (digitalRead(pin) != LOW){
//If don't return low for a long time, output a prompt and start over
Serial.println("LOW");
goto bgn;
//Start reading the value of bit1-40
for (int i = 0; i < 40; i++){
while (digitalRead(pin) == LOW){}
//When the high level occurs, write down the time "time"
time1 = micros();
while (digitalRead(pin) == HIGH){}
//When there is a low level, write down the time and subtract the time just saved
//If the value obtained is greater than 50μs, it is ‘1’, otherwise it is ‘0’
//And save it in an array
if (micros() - time1 > 50){
chr[i] = 1;
chr[i] = 0;
//Humidity, 8-bit bit, converted to a value
humi = chr[0] * 128 + chr[1] * 64 + chr[2] * 32 + chr[3] * 16 + chr[4] * 8 + chr[5] * 4 + chr[6] * 2 + chr[7];
//Temperature, 8-bit bit, converted to a value
temp = chr[16] * 128 + chr[17] * 64 + chr[18] * 32 + chr[19] * 16 + chr[20] * 8 + chr[21] * 4 + chr[22] * 2 + chr[23];
Serial.print("temp:");
Serial.print(temp);
Serial.print(" humi:");
Serial.println(humi);
void readLight(){
// reset
Wire.write(0b00000111);
Wire.write(0b00100000);
// typical read delay 120ms
delay(120);
Wire.requestFrom(Light_ADDR, 2); // 2byte every time
for (tempLight = 0; Wire.available() >= 1; ) {
char c = Wire.read();
tempLight = (tempLight << 8) + (c & 0xFF);
tempLight = tempLight / 1.2;
Serial.print("light: ");
Serial.println(tempLight);
void readAtmosphere(){
tempAtom = bmp.readPressure();
Serial.print("Pressure = ");
Serial.print(tempAtom);
Serial.println(" Pascal");
//upload temperature humidity data to thinkspak.com
void uploadTemperatureHumidity(){
if(!client.connect(host, httpPort)){
Serial.println("connection failed");
return;
// Three values(field1 field2 field3 field4) have been set in thingspeak.com
client.print(String("GET ") + "/update?api_key="+api_key+"&field1="+temp+"&field2="+humi + "&field3="+tempLight+"&field4="+tempAtom+" HTTP/1.1\r\n" +"Host: " + host + "\r\n" + "Connection: close\r\n\r\n");
while(client.available()){
String line = client.readStringUntil('\r');
Serial.print(line);
And this is the compiler error message:
Arduino: 1.8.4 (Windows 10), Board: "NodeMCU 1.0 (ESP-12E Module), 80 MHz, Flash, Disabled (new aborts on oom), Disabled, All SSL ciphers (most compatible), 32KB cache + 32KB IRAM (balanced), Use pgm_read macros for IRAM/PROGMEM, 4MB (FS:2MB OTA:~1019KB), 2, v2 Lower Memory, Disabled, None, Only Sketch, 115200"
C:\Users\i5170\OneDrive\Desktop\WeatherNew\arduino-1.8.4\arduino-builder -dump-prefs -logger=machine -hardware C:\Users\i5170\OneDrive\Desktop\WeatherNew\arduino-1.8.4\hardware -hardware C:\Users\i5170\AppData\Local\Arduino15\packages -tools C:\Users\i5170\OneDrive\Desktop\WeatherNew\arduino-1.8.4\tools-builder -tools C:\Users\i5170\OneDrive\Desktop\WeatherNew\arduino-1.8.4\hardware\tools\avr -tools C:\Users\i5170\AppData\Local\Arduino15\packages -built-in-libraries C:\Users\i5170\OneDrive\Desktop\WeatherNew\arduino-1.8.4\libraries -libraries C:\Users\i5170\AppData\Local\Arduino15\libraries -fqbn=esp8266:esp8266:nodemcuv2:xtal=80,vt=flash,exception=disabled,stacksmash=disabled,ssl=all,mmu=3232,non32xfer=fast,eesz=4M2M,led=2,ip=lm2f,dbg=Disabled,lvl=None____,wipe=none,baud=115200 -ide-version=10804 -build-path C:\Users\i5170\AppData\Local\Temp\arduino_build_387509 -warnings=none -build-cache C:\Users\i5170\AppData\Local\Temp\arduino_cache_777374 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.mkspiffs.path=C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.mklittlefs.path=C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\mklittlefs\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.python3.path=C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed -verbose C:\Users\i5170\OneDrive\Documents\Arduino\WeatherStationDemo\WeatherStn1910\WeatherStn1910.ino
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/include" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/lwip2/include" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\i5170\AppData\Local\Temp\arduino_build_665643/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -MMD -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10804 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU_ESP12E" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\variants\nodemcu" "C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266\core_esp8266_wiring_pwm.cpp" -o "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core_esp8266_wiring_pwm.cpp.o"
C:\Users\i5170\OneDrive\Desktop\WeatherNew\arduino-1.8.4\arduino-builder -compile -logger=machine -hardware C:\Users\i5170\OneDrive\Desktop\WeatherNew\arduino-1.8.4\hardware -hardware C:\Users\i5170\AppData\Local\Arduino15\packages -tools C:\Users\i5170\OneDrive\Desktop\WeatherNew\arduino-1.8.4\tools-builder -tools C:\Users\i5170\OneDrive\Desktop\WeatherNew\arduino-1.8.4\hardware\tools\avr -tools C:\Users\i5170\AppData\Local\Arduino15\packages -built-in-libraries C:\Users\i5170\OneDrive\Desktop\WeatherNew\arduino-1.8.4\libraries -libraries C:\Users\i5170\AppData\Local\Arduino15\libraries -fqbn=esp8266:esp8266:nodemcuv2:xtal=80,vt=flash,exception=disabled,stacksmash=disabled,ssl=all,mmu=3232,non32xfer=fast,eesz=4M2M,led=2,ip=lm2f,dbg=Disabled,lvl=None____,wipe=none,baud=115200 -ide-version=10804 -build-path C:\Users\i5170\AppData\Local\Temp\arduino_build_387509 -warnings=none -build-cache C:\Users\i5170\AppData\Local\Temp\arduino_cache_777374 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.mkspiffs.path=C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.mklittlefs.path=C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\mklittlefs\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.python3.path=C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed -verbose C:\Users\i5170\OneDrive\Documents\Arduino\WeatherStationDemo\WeatherStn1910\WeatherStn1910.ino
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/include" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/lwip2/include" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\i5170\AppData\Local\Temp\arduino_build_665643/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -MMD -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10804 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU_ESP12E" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\variants\nodemcu" "C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266\core_esp8266_wiring_shift.cpp" -o "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core_esp8266_wiring_shift.cpp.o"
Using board 'nodemcuv2' from platform in folder: C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2
Using core 'esp8266' from platform in folder: C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2
Detecting libraries used...
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/include" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/lwip2/include" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\i5170\AppData\Local\Temp\arduino_build_387509/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10804 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU_ESP12E" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\variants\nodemcu" "C:\Users\i5170\AppData\Local\Temp\arduino_build_387509\sketch\WeatherStn1910.ino.cpp" -o "nul"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/include" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/lwip2/include" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\i5170\AppData\Local\Temp\arduino_build_387509/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10804 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU_ESP12E" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\variants\nodemcu" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\Wire" "C:\Users\i5170\AppData\Local\Temp\arduino_build_387509\sketch\WeatherStn1910.ino.cpp" -o "nul"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/include" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/lwip2/include" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\i5170\AppData\Local\Temp\arduino_build_665643/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -MMD -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10804 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU_ESP12E" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\variants\nodemcu" "C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266\crc32.cpp" -o "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\crc32.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/include" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/lwip2/include" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\i5170\AppData\Local\Temp\arduino_build_387509/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10804 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU_ESP12E" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\variants\nodemcu" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\Wire" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WiFi\src" "C:\Users\i5170\AppData\Local\Temp\arduino_build_387509\sketch\WeatherStn1910.ino.cpp" -o "nul"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/include" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/lwip2/include" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\i5170\AppData\Local\Temp\arduino_build_665643/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -MMD -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10804 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU_ESP12E" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\variants\nodemcu" "C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266\debug.cpp" -o "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\debug.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/include" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/lwip2/include" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\i5170\AppData\Local\Temp\arduino_build_665643/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -MMD -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10804 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU_ESP12E" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\variants\nodemcu" "C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266\exc-sethandler.cpp" -o "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\exc-sethandler.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/include" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/lwip2/include" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\i5170\AppData\Local\Temp\arduino_build_387509/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10804 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU_ESP12E" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\variants\nodemcu" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\Wire" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WiFi\src" "C:\Users\i5170\AppData\Local\Temp\arduino_build_387509\sketch\WeatherStn1910.ino.cpp" -o "C:\Users\i5170\AppData\Local\Temp\arduino_build_387509\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/include" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/lwip2/include" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\i5170\AppData\Local\Temp\arduino_build_665643/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -MMD -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10804 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU_ESP12E" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\variants\nodemcu" "C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266\flash_hal.cpp" -o "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\flash_hal.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/include" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/lwip2/include" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\i5170\AppData\Local\Temp\arduino_build_665643/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -MMD -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10804 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU_ESP12E" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\variants\nodemcu" "C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266\gdb_hooks.cpp" -o "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\gdb_hooks.cpp.o"
Using library Wire at version 1.0 in folder: C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\Wire
Using library ESP8266WiFi at version 1.0 in folder: C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WiFi
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/include" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/lwip2/include" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\i5170\AppData\Local\Temp\arduino_build_665643/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -MMD -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10804 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU_ESP12E" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\variants\nodemcu" "C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266\heap.cpp" -o "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\heap.cpp.o"
exit status 1"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/include" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/lwip2/include" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\i5170\AppData\Local\Temp\arduino_build_665643/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -MMD -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10804 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU_ESP12E" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\variants\nodemcu" "C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266\hwdt_app_entry.cpp" -o "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\hwdt_app_entry.cpp.o"
Error compiling for board NodeMCU 1.0 (ESP-12E Module).
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/include" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/lwip2/include" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\i5170\AppData\Local\Temp\arduino_build_665643/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -MMD -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10804 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU_ESP12E" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\variants\nodemcu" "C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266\libc_replacements.cpp" -o "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\libc_replacements.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/include" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/lwip2/include" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\i5170\AppData\Local\Temp\arduino_build_665643/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -MMD -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10804 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU_ESP12E" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\variants\nodemcu" "C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266\mmu_iram.cpp" -o "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\mmu_iram.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/include" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/lwip2/include" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\i5170\AppData\Local\Temp\arduino_build_665643/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -MMD -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10804 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU_ESP12E" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\variants\nodemcu" "C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266\reboot_uart_dwnld.cpp" -o "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\reboot_uart_dwnld.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/include" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/lwip2/include" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\i5170\AppData\Local\Temp\arduino_build_665643/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -MMD -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10804 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU_ESP12E" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\variants\nodemcu" "C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266\spiffs_api.cpp" -o "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\spiffs_api.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/include" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/lwip2/include" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\i5170\AppData\Local\Temp\arduino_build_665643/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -MMD -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10804 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU_ESP12E" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\variants\nodemcu" "C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266\sqrt32.cpp" -o "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\sqrt32.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/include" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/lwip2/include" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\i5170\AppData\Local\Temp\arduino_build_665643/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -MMD -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10804 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU_ESP12E" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\variants\nodemcu" "C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266\stdlib_noniso.cpp" -o "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\stdlib_noniso.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/include" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/lwip2/include" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\i5170\AppData\Local\Temp\arduino_build_665643/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -MMD -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10804 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU_ESP12E" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\variants\nodemcu" "C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266\time.cpp" -o "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\time.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/include" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/lwip2/include" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\i5170\AppData\Local\Temp\arduino_build_665643/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -MMD -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10804 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU_ESP12E" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\variants\nodemcu" "C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266\uart.cpp" -o "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\uart.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/include" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/lwip2/include" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\i5170\AppData\Local\Temp\arduino_build_665643/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -MMD -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10804 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU_ESP12E" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\variants\nodemcu" "C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266\libb64\cdecode.cpp" -o "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\libb64\cdecode.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/include" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/lwip2/include" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\i5170\AppData\Local\Temp\arduino_build_665643/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -MMD -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10804 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU_ESP12E" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\variants\nodemcu" "C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266\libb64\cencode.cpp" -o "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\libb64\cencode.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/include" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/lwip2/include" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\i5170\AppData\Local\Temp\arduino_build_665643/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -MMD -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10804 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU_ESP12E" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\variants\nodemcu" "C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266\spiffs\spiffs_cache.cpp" -o "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\spiffs\spiffs_cache.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/include" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/lwip2/include" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\i5170\AppData\Local\Temp\arduino_build_665643/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -MMD -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10804 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU_ESP12E" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\variants\nodemcu" "C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266\spiffs\spiffs_check.cpp" -o "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\spiffs\spiffs_check.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/include" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/lwip2/include" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\i5170\AppData\Local\Temp\arduino_build_665643/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -MMD -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10804 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU_ESP12E" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\variants\nodemcu" "C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266\spiffs\spiffs_gc.cpp" -o "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\spiffs\spiffs_gc.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/include" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/lwip2/include" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\i5170\AppData\Local\Temp\arduino_build_665643/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -MMD -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10804 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU_ESP12E" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\variants\nodemcu" "C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266\spiffs\spiffs_hydrogen.cpp" -o "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\spiffs\spiffs_hydrogen.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/include" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/lwip2/include" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\i5170\AppData\Local\Temp\arduino_build_665643/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -MMD -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10804 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU_ESP12E" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\variants\nodemcu" "C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266\spiffs\spiffs_nucleus.cpp" -o "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\spiffs\spiffs_nucleus.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/include" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/lwip2/include" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\i5170\AppData\Local\Temp\arduino_build_665643/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -MMD -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10804 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU_ESP12E" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266" "-IC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\variants\nodemcu" "C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266\umm_malloc\umm_malloc.cpp" -o "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\umm_malloc\umm_malloc.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-ar" cru "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core.a" "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\cont.S.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-ar" cru "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core.a" "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\exc-c-wrapper-handler.S.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-ar" cru "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core.a" "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\umm_malloc\umm_info.c.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-ar" cru "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core.a" "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\umm_malloc\umm_integrity.c.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-ar" cru "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core.a" "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\umm_malloc\umm_local.c.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-ar" cru "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core.a" "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\umm_malloc\umm_poison.c.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-ar" cru "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core.a" "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\Crypto.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-ar" cru "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core.a" "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\Esp-frag.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-ar" cru "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core.a" "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\Esp-version.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-ar" cru "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core.a" "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\Esp.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-ar" cru "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core.a" "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\FS.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-ar" cru "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core.a" "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\FSnoop.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-ar" cru "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core.a" "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\FunctionalInterrupt.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-ar" cru "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core.a" "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\HardwareSerial.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-ar" cru "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core.a" "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\IPAddress.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-ar" cru "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core.a" "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\LwipDhcpServer-NonOS.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-ar" cru "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core.a" "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\LwipDhcpServer.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-ar" cru "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core.a" "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\LwipIntf.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-ar" cru "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core.a" "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\LwipIntfCB.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-ar" cru "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core.a" "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\MD5Builder.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-ar" cru "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core.a" "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\Print.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-ar" cru "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core.a" "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\Schedule.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-ar" cru "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core.a" "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\StackThunk.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-ar" cru "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core.a" "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\Stream.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-ar" cru "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core.a" "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\StreamSend.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-ar" cru "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core.a" "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\Tone.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-ar" cru "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core.a" "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\TypeConversion.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-ar" cru "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core.a" "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\Updater.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-ar" cru "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core.a" "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\WMath.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-ar" cru "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core.a" "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\WString.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-ar" cru "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core.a" "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\abi.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-ar" cru "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core.a" "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\aes_unwrap.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-ar" cru "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core.a" "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\base64.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-ar" cru "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core.a" "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\cbuf.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-ar" cru "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core.a" "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\cont_util.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-ar" cru "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core.a" "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core_esp8266_app_entry_noextra4k.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-ar" cru "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core.a" "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core_esp8266_eboot_command.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-ar" cru "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core.a" "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core_esp8266_features.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-ar" cru "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core.a" "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core_esp8266_flash_quirks.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-ar" cru "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core.a" "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core_esp8266_flash_utils.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-ar" cru "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core.a" "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core_esp8266_i2s.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-ar" cru "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core.a" "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core_esp8266_main.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-ar" cru "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core.a" "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core_esp8266_non32xfer.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-ar" cru "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core.a" "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core_esp8266_noniso.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-ar" cru "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core.a" "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core_esp8266_phy.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-ar" cru "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core.a" "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core_esp8266_postmortem.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-ar" cru "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core.a" "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core_esp8266_si2c.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-ar" cru "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core.a" "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core_esp8266_sigma_delta.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-ar" cru "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core.a" "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core_esp8266_spi_utils.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-ar" cru "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core.a" "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core_esp8266_timer.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-ar" cru "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core.a" "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core_esp8266_vm.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-ar" cru "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core.a" "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core_esp8266_waveform_phase.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-ar" cru "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core.a" "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core_esp8266_waveform_pwm.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-ar" cru "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core.a" "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core_esp8266_wiring.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-ar" cru "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core.a" "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core_esp8266_wiring_analog.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-ar" cru "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core.a" "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core_esp8266_wiring_digital.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-ar" cru "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core.a" "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core_esp8266_wiring_pulse.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-ar" cru "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core.a" "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core_esp8266_wiring_pwm.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-ar" cru "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core.a" "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core_esp8266_wiring_shift.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-ar" cru "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core.a" "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\crc32.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-ar" cru "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core.a" "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\debug.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-ar" cru "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core.a" "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\exc-sethandler.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-ar" cru "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core.a" "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\flash_hal.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-ar" cru "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core.a" "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\gdb_hooks.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-ar" cru "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core.a" "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\heap.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-ar" cru "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core.a" "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\hwdt_app_entry.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-ar" cru "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core.a" "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\libc_replacements.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-ar" cru "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core.a" "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\mmu_iram.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-ar" cru "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core.a" "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\reboot_uart_dwnld.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-ar" cru "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core.a" "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\spiffs_api.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-ar" cru "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core.a" "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\sqrt32.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-ar" cru "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core.a" "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\stdlib_noniso.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-ar" cru "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core.a" "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\time.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-ar" cru "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core.a" "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\uart.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-ar" cru "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core.a" "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\libb64\cdecode.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-ar" cru "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core.a" "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\libb64\cencode.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-ar" cru "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core.a" "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\spiffs\spiffs_cache.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-ar" cru "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core.a" "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\spiffs\spiffs_check.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-ar" cru "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core.a" "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\spiffs\spiffs_gc.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-ar" cru "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core.a" "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\spiffs\spiffs_hydrogen.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-ar" cru "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core.a" "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\spiffs\spiffs_nucleus.cpp.o"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-ar" cru "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core.a" "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\umm_malloc\umm_malloc.cpp.o"
Archiving built core (caching) in: C:\Users\i5170\AppData\Local\Temp\arduino_cache_777374\core\core_esp8266_esp8266_nodemcuv2_xtal_80,vt_flash,exception_disabled,stacksmash_disabled,ssl_all,mmu_3232,non32xfer_fast,eesz_4M2M,led_2,ip_lm2f,dbg_Disabled,lvl_None____,wipe_none,baud_115200_58a026cdab0180388b2da1533df19fd0.a
Linking everything together...
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1/python3" -I "C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/mkdir.py" -p "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643/ld_h/"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1/python3" -I "C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/cp.py" "C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/ld/eagle.flash.4m2m.ld" "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643/ld_h/local.eagle.flash.ld.h"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-gcc" -CC -E -P -DVTABLES_IN_FLASH -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643/ld_h/local.eagle.flash.ld.h" -o "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643/local.eagle.flash.ld"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-gcc" -CC -E -P -DVTABLES_IN_FLASH -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 "C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/ld/eagle.app.v6.common.ld.h" -o "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643/local.eagle.app.v6.common.ld"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-gcc" -fno-exceptions -Wl,-Map "-Wl,C:\Users\i5170\AppData\Local\Temp\arduino_build_665643/sketch_oct22a.ino.map" -g -w -Werror=return-type -Os -nostdlib -Wl,--no-check-sections -u app_entry -u _printf_float -u _scanf_float -Wl,-static "-LC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/lib" "-LC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/lib/NONOSDK22x_190703" "-LC:\Users\i5170\AppData\Local\Temp\arduino_build_665643" "-LC:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/libc/xtensa-lx106-elf/lib" "-Tlocal.eagle.flash.ld" -Wl,--gc-sections -Wl,-wrap,system_restart_local -Wl,-wrap,spi_flash_read -o "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643/sketch_oct22a.ino.elf" -Wl,--start-group "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\sketch\sketch_oct22a.ino.cpp.o" "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643\core\core.a" -lhal -lphy -lpp -lnet80211 -llwip2-536-feat -lwpa -lcrypto -lmain -lwps -lbearssl -lespnow -lsmartconfig -lairkiss -lwpa2 -lstdc++ -lm -lc -lgcc -Wl,--end-group "-LC:\Users\i5170\AppData\Local\Temp\arduino_build_665643"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1/python3" -I "C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/elf2bin.py" --eboot "C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/bootloaders/eboot/eboot.elf" --app "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643/sketch_oct22a.ino.elf" --flash_mode dio --flash_freq 40 --flash_size 4M --path "C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin" --out "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643/sketch_oct22a.ino.bin"
Creating BIN file "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643/sketch_oct22a.ino.bin" using "C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/bootloaders/eboot/eboot.elf" and "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643/sketch_oct22a.ino.elf"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1/python3" -I "C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/signing.py" --mode sign --privatekey "C:\Users\i5170\AppData\Local\Temp\untitled1176385640.tmp\sketch_oct22a/private.key" --bin "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643/sketch_oct22a.ino.bin" --out "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643/sketch_oct22a.ino.bin.signed" --legacy "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643/sketch_oct22a.ino.bin.legacy_sig"
"C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1/python3" -I "C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sizes.py" --elf "C:\Users\i5170\AppData\Local\Temp\arduino_build_665643/sketch_oct22a.ino.elf" --path "C:\Users\i5170\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin" --mmu "-DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000"
Executable segment sizes:
ICACHE : 32768 - flash instruction cache
IROM : 231500 - code in flash (default or ICACHE_FLASH_ATTR)
IRAM : 26217 / 32768 - code in IRAM (IRAM_ATTR, ISRs...)
DATA : 1496 ) - initialized variables (global, static) in RAM/HEAP
RODATA : 876 ) / 81920 - constants (global, static) in RAM/HEAP
BSS : 25520 ) - zeroed variables (global, static) in RAM/HEAP
Sketch uses 260089 bytes (24%) of program storage space. Maximum is 1044464 bytes.
Global variables use 27892 bytes (34%) of dynamic memory, leaving 54028 bytes for local variables. Maximum is 81920 bytes.
Invalid library found in C:\Users\i5170\AppData\Local\Arduino15\libraries\bootloaders: C:\Users\i5170\AppData\Local\Arduino15\libraries\bootloaders
Invalid library found in C:\Users\i5170\AppData\Local\Arduino15\libraries\cores: C:\Users\i5170\AppData\Local\Arduino15\libraries\cores
Invalid library found in C:\Users\i5170\AppData\Local\Arduino15\libraries\doc: C:\Users\i5170\AppData\Local\Arduino15\libraries\doc
Invalid library found in C:\Users\i5170\AppData\Local\Arduino15\libraries\libraries: C:\Users\i5170\AppData\Local\Arduino15\libraries\libraries
Invalid library found in C:\Users\i5170\AppData\Local\Arduino15\libraries\package: C:\Users\i5170\AppData\Local\Arduino15\libraries\package
Invalid library found in C:\Users\i5170\AppData\Local\Arduino15\libraries\tests: C:\Users\i5170\AppData\Local\Arduino15\libraries\tests
Invalid library found in C:\Users\i5170\AppData\Local\Arduino15\libraries\tools: C:\Users\i5170\AppData\Local\Arduino15\libraries\tools
Invalid library found in C:\Users\i5170\AppData\Local\Arduino15\libraries\variants: C:\Users\i5170\AppData\Local\Arduino15\libraries\variants
Why is the OP trying to load 2 WiFi libraries onto a ESP8266? I think it would be best to stick with ESP8266WiFi.h and drop the ESPWiFi.h library.
Not sure why or how that happened. I got the code from Github.
I commented out the ESPWiFi.h.
Now the error is`
C:\Users\i5170\OneDrive\Documents\Arduino\WeatherStationDemo\WeatherStn1910\WeatherStn1910.ino:4:10: fatal error: ESPHTTPClient.h: No such file or directory
4 | #include <ESPHTTPClient.h>
compilation terminated.
As a general hint:
if you are using source-code that is online available you should provide the link to your source.
What is really strange about the compiler-log you posted is that the lines that you posted have these lines
Archiving built core (caching) in: C:\Users\i5170\AppData\Local\Temp\arduino_cache_777374....
Which indicates a successfull compiling
in combination with
So my questions are:
1.) why do you use Arduino-Ide-Version 1.8.4 instead of Version 1.8.19?
2.) is it possible that you combined two different clipboard-contents
- one from a possible compiling
- one from a error-terminated compiling?
I have never seen such a combination of a message
"linking everything together..." in combination with error-aborted compilation
linking everything together... only is printed if compiling was successfull.
The ESPWifi.h-library is for ESp32 and NOT for ESP8266!
As you get the error
I did googling for exact this library
It seems that you used this project
The following is a guess. I have not tested if this is the correct library
The documentation of this project does not tell that you have to install a esphttpclient- library
just a guiessing it might be this one
In such a case open an issue inside the GitHub-project.
If GitHub-uploaders are too lazy to provide sufficient information they should receive feedback about this insufficiency.
best regards Stefan
I did some more research. Some ,ore inlcude-files were missing which lead me to install this GitHub-code
Installing libraries from a ZIP-file is described here
if you are an unexperienced Arduino-User you should start from a working demo-code
If you have installed the ZIP-library there is a demo-code
....libraries\esp8266-weather-station-master\examples\WeatherStationDemo\WeatherStationDemo.ino
before doing anything else try to compile this demo.
Then change one single small thing and compile new
If it does compile
repeat
This way you will know quickly WHAT is causing the error: the last thing you did change
As more as you change and as longer as you wait with the next compiling
trying to save time
the looonger it will take to find the error eating up more time than the repeated compiling
best regards Stefan
Thanks, for your assistance.
So, much has happened since I began this project, its very likely that things are all messed up.
I began with code from Banggood where I purchased the weather station kit:
https://view.officeapps.live.com/op/view.aspx?src=http%3A%2F%2Fmyosuploads3.banggood.com%2Fproducts%2F20210218%2F20210218233653esp8266.docx&wdOrigin=BROWSELINK
Due to compiler errors I started an earlier thread here:
and it was suggested to obtain a library from here:
ThingPulse/esp8266-weather-station/blob/master/src/AerisForecasts.cpp
The sketch then compiled and was working. However the Barometric Sensor was not working and in trying to fix that the IDE got changed and libararies moved around and sketch versions got mixed up and resulted in the current errors!
Initially I think I had Ver 2.0 of the IDE. Then, trying to get libraries sorted out and deleting and moving folders I tried uninstall to clear out unnecessary folders and I must have downloaded a fresh IDe and it was 1.8.4 so I deleted ver 2.0 as all the libraries were getting very confusing.
Its quite possible that two clipboard contents got posted as I was trying to paste
in the preformatted text window.
I think I may need to start afresh. Should I just keep my current sketch reinstall the IDE? There seem to be too many libraries.
Anyway, I will now try to follow the instructions in your second reply.
you can try including the library via zip manually.
in arduino ide go to > sketch > include library > add .zip library
and then select the library file
hello Dolon, Maybe it's been a long time since your post, but I wanted to ask you how you solved the problem with the "49 | http.begin(url);" instruction. My email is luma1816@gmail.com
