Fatal error: No such file or directory
Hello,
I have this error on compilation. The library is in the same folder with the project.
personal library arduino ide created in edge impulse
C:\sketchtest_car_sep23a\sketchtest_car_sep23a.ino:1:10: fatal error: car1_inferencing.h: No such file or directory
1 | #include <car1_inferencing.h>
compilation terminated.
Welcome to the forum
As your topic does not relate directly to the installation or operation of the IDE it has been moved to the Programming Questions category of the forum
This style of #include expects to find the library file in one of the standard library locations. If the library file is in the same folder as the sketch file then use this style instead
#include "car1_inferencing.h"
The compiler will then look for the file in the sketch folder before looking elsewhere
already tried that and it did not work
Your folder organization is weird. Where is your library folder that gets created at install? Maybe if you followed the usual rules it would work.
Absolute Path #include "C:/Users/torna/OneDrive/Έγγραφα/Arduino/libraries/car1_inferencing.h"
is OneDrive creating the problem?
Maybe, but the cyrillic is for sure if my memory serves.
I use onedrive but I have all the /root/Arduino set to 'Always Keep on this device'
It maybe OneDrive or it maybe the extended ASCII characters in the path to the Libraries folder
Either way the library file is not
unless you have got the sketch in a very unusual place, ie the libraries folder of the sketchbook
this fixes the problem moved the Arduino folder to C:\Arduino
  • Open Arduino IDE.
  • Go to File > Preferences.
  • Under Sketchbook location, change the path to a local directory, such as C:\Arduino, that doesn’t sync with OneDrive or contain special characters.
It looks like his library and sketch folders are far apart and unrelated, BUT I know from experience OneDrive can make things look weird if you do not practice good habits.
Hi @usernamear1s. The Arduino developers are tracking the bug of non-ASCII characters in the library's path causing a spurious "No such file or directory" error here:
As you already discovered, the workaround for the bug is to use a sketchbook location that doesn't contain any non-ASCII characters.
