No such file directory even though i have already installed the related library
why doesn't my Arduino work well on my laptop, when I get the same problem on a different laptop, by installing the same library, the compiling code runs fine, but on my Arduino laptop it always shows 'no such file directory' even though the library I have I have installed it using several methods, such as in the file manager or not downloading it manually on GitHub, I assume that the IDE on my laptop does not have permission to access the file, is this possible? Can you help me with a friend? This applies to all libraries that I try to use
Hi @mochadriqfadillah12. I'm going to ask you to provide the full output from a failed compilation on the laptop.
:red_exclamation_mark: This procedure is not intended to solve the problem. The purpose is to gather more information.
Please do this:
  1. Select Sketch > Verify/Compile from the Arduino IDE menus.
  2. Wait for the compilation to fail.
  3. You will see a "Compilation error: ..." notification at the bottom right corner of the Arduino IDE window. Click the "COPY ERROR MESSAGES" button on that notification.
  4. Open a forum reply here by clicking the "Reply" button.
  5. Click the <CODE/> icon on the post composer toolbar.
    This will add the forum's code block markup (```) to your reply to make sure the error messages are correctly formatted.
  6. Press the Ctrl+V keyboard shortcut (Command+V for macOS users).
    This will paste the compilation output into the code block.
  7. Move the cursor outside of the code block markup before you add any additional text to your reply.
  8. Click the "Reply" button to post the output.
In case the output is longer than the forum software will allow to be added to a post, you can instead save it to a .txt file and then attach that file to a reply here.
Click here for attachment instructions
  1. Open any text editor program.
  2. Paste the copied output into the text editor.
  3. Save the file in .txt format.
  5. Click the "Upload" icon (Upload icon) on the post composer toolbar:
    The "Open" dialog will open.
  6. Select the .txt file you saved from the "Open" dialog.
  7. Click the "Open" button.
    The dialog will close.
  8. Click the "Reply" button to publish the post.
Alternatively, instead of using the "Upload" icon on the post composer toolbar as described in steps (5) - (7) above, you can simply drag and drop the .txt file onto the post composer field to attach it.
C:\Users\ASUS VIVOBOOK\OneDrive\ドキュメント\Arduino\HCL_dan_lcd_Projek_UAS_copy_20240612160357\HCL_dan_lcd_Projek_UAS_copy_20240612160357.ino:2:10: fatal error: LiquidCrystal_I2C.h: No such file or directory
compilation terminated.
exit status 1
Compilation error: LiquidCrystal_I2C.h: No such file or directory
It probably happened because your Arduino path contains a non-latin characters and spaces. Try to reinstall the Arduino on another user without national alphabet in the name
You should be able to move the Arduino directory one up.
  1. In the IDE under file preferences, change the sketchbook directory to C:\Users\ASUS VIVOBOOK\OneDrive\Arduino
  2. Close the IDE
  3. Move the Arduino folder from C:\Users\ASUS VIVOBOOK\OneDrive\ドキュメント\ to C:\Users\ASUS VIVOBOOK\OneDrive\
  4. Restart the IDE.
Which version of the IDE are you using?
Note:
This has been reported before, I just can't find an issue report in github.
Hi @mochadriqfadillah12. I just wanted to add a note that the Arduino developers are tracking this bug here:
You can follow the instructions provided by @sterretje as the workaround for the bug.
I had the same problem on my code, and this solution worked. Thank you so much!
I even uninstalled then re-download Arduino IDE and the libraries (using many methods) before (even tried moving some folders in my file manager), but it didn't work. So those non-latin characters in my folder are the reason for my suffering TvT
