Hi all,
My library is currently using the Base64 library. There are several lines of code inside Base64 library:
#include "Base64.h"
#include <Arduino.h>
#if (defined(__AVR__))
#include <avr/pgmspace.h>
#else
#include <pgmspace.h>
#endif
If I use the board Arduino Uno WiFi Rev2 then, everything is fine. However, if I use the arduino board MKR wifi 1010 then it shows that
fatal error: pgmspace.h: No such file or directory
I commented out these two lines
and
Everything will work again.
My question is, can I do something on my own library so that the users of my library don't have to do such kind of manually process?
Thanks a lot!
BRs,
