Fauxmo/ESP8266 device to send messages to Alexa?
I've been tinkering with the Fauxmo sketch on my Lolin D1 Mini Pro ESP8266. I got it to connect to wifi and it is discoverable in the Alexa app. So, I see it can act essentially as a slave unit and receive messages from Alexa and turn on/off pins.
Can I have it send Alexa Commands such as "Alexa, Turn off Office light"? I did a search here and Googled it. Nothing in the direction of sending commands from the ESP to Alexa.
TIA
A few days ago, I got an Alexa Echo 4th gen, which has temp and motion sensor. I'm trying to replicate that with Arduino.IDE Just because!!!
Don't expect helpers to know what it is. It looks like one on a million question.
You can tell how it developes, if You want.
#include <Arduino.h>
#ifdef ESP32
#include <WiFi.h>
#else
#include <ESP8266WiFi.h>
#endif
#include "fauxmoESP.h"
#include "credentials.h"
fauxmoESP fauxmo;
#define SERIAL_BAUDRATE 115200
#define WEMOS 4
#define ID_WEMOS "WEMOS"
// Wifi
void wifiSetup() {
  // Set WIFI module to STA mode
  WiFi.mode(WIFI_STA);
  // Connect
  Serial.printf("[WIFI] Connecting to %s ", WIFI_SSID);
  WiFi.begin(WIFI_SSID, WIFI_PASS);
  // Wait
    Serial.print(".");
    delay(100);
  // Connected!
  Serial.printf("[WIFI] STATION Mode, SSID: %s, IP address: %s\n", WiFi.SSID().c_str(), WiFi.localIP().toString().c_str());
  //  Prints out: MODE, SSID Connected to, Assigned IP address by Server/Router.
  // Init serial port and clean garbage
  Serial.begin(SERIAL_BAUDRATE);
  // LEDs
  pinMode(WEMOS, OUTPUT);
  digitalWrite(WEMOS, LOW);
  // Wifi
  wifiSetup();
  // By default, fauxmoESP creates it's own webserver on the defined port
  // The TCP port must be 80 for gen3 devices (default is 1901)
  // This has to be done before the call to enable()
  fauxmo.createServer(true);  // not needed, this is the default value
  fauxmo.setPort(80);         // This is required for gen3 devices
  // You have to call enable(true) once you have a WiFi connection
  // You can enable or disable the library at any moment
  // Disabling it will prevent the devices from being discovered and switched
  fauxmo.enable(true);
  // You can use different ways to invoke alexa to modify the devices state:
  // "Alexa, turn WEMOS on"
  // "Alexa, turn on WEMOS
  // "Alexa, set WEMOS to fifty" (50 means 50% of brightness, note, this example does not use this functionality)
  // Add virtual devices
  fauxmo.addDevice(ID_WEMOS);
  fauxmo.onSetState([](unsigned char device_id, const char* device_name, bool state, unsigned char value) {
    // Callback when a command from Alexa is received.
    // You can use device_id or device_name to choose the element to perform an action onto (relay, LED,...)
    // State is a boolean (ON/OFF) and value a number from 0 to 255 (if you say "set kitchen light to 50%" you will receive a 128 here).
    // Just remember not to delay too much here, this is a callback, exit as soon as possible.
    // If you have to do something more involved here set a flag and process it in your main loop.
    Serial.printf("[MAIN] Device #%d (%s) state: %s value: %d\n", device_id, device_name, state ? "ON" : "OFF", value);
    // Checking for device_id is simpler if you are certain about the order they are loaded and it does not change.
    // Otherwise comparing the device_name is safer.
    if (strcmp(device_name, ID_WEMOS) == 0) {
      digitalWrite(WEMOS, state ? HIGH : LOW);
  // fauxmoESP uses an async TCP server but a sync UDP server
  // Therefore, we have to manually poll for UDP packets
  fauxmo.handle();
  // This is a sample code to output free heap every 5 seconds
  // This is a cheap way to detect memory leaks
  static unsigned long last = millis();
  if (millis() - last > 5000) {
    last = millis();
    Serial.printf("[MAIN] Free heap: %d bytes\n", ESP.getFreeHeap());
  // If your device state is changed by any other means (MQTT, physical button,...)
  // you can instruct the library to report the new state to Alexa on next request:
  // fauxmo.setState(ID_WEMOS, true, 255);
Please read the sticky post "How to get the best out of this forum" and use it.
