Complete beginner here and want to know if this project is feasible with the help of Claude.
I want to build two sensors, which attach on my mid and upper back via an adhesive, which measure the bend of the spine, and vibrate or somehow alert me when a certain angle threshold is reached. Basically, they need to measure their position relative to one another.
For someone with no experience in electronics, is this a project worth taking on for me or is it too much?
I'll speculate you wouldn't even need AI. Connect two MPU6050 3 Axis Accelerometers to your controller (I2C) and display the difference in angle between them. Libraries exist for the MPU6050 so 'all ya gotta do is' add some relatively simple code to coordinate things.
Welcome!
Based on your questions so far, I don't think you're ready to build this project; not because it isn't possible, but because it appears you're still missing many of the fundamental electronics and programming skills needed to design it successfully.
I'd suggest getting a copy of the Arduino Cookbook and skimming it from cover to cover. Stop and work through the projects that interest you. Most are well explained and will give you a solid foundation to build on.
At this point, I think a neighbor with some Arduino experience would probably be able to provide more practical help than an AI. A project like this benefits greatly from someone who can look over your shoulder, answer questions as they come up, and help you debug both the hardware and software.
OP isn't building the Space Shuttle. Many people just want to get stuff done and not learn the details of how it all works. I guarantee you that if this level of AI had been around when Arduino started, the combination would have been immediately popular.
There is absolutely nothing about this project that Claude couldn't help with. We're at the point with AI where if a hobbyist wants to do something but not learn the basics, they can get to a solution.
I agree but the complete beginner will need to understand some electronics, sensors, embedded programming, system power, mechanical design, and how to calibrate and validate your measurements. An AI like Claude can certainly answer questions and help write code, but it can't replace the experience needed to recognize when a design is wrong or why it isn't working.
