Feather M0 sleep/wake up TTN
Hello everyone,
I'm trying to use the sleep mode with the Feather M0. The idea is after send a message to TTN the microcontroller is going in sleep mode and at X minute time the microcontroller goes in wake up mode.
The example code is here.
The code is working fine to TTN. But it can send the data only one time data. I not sure if the sleep mode is working correct or if there are others solutions to sleep the Feather M0 after send the data and wake up every X minutes.
I use the LMIC library for Lorawan. I read some examples code on internet and some one explain that lmic library sleeps automatically after transmission has been completed , but i'm not sure about this.
Thanks for your help.
Post code here and not to temporary storage sites!
Hello Pylon, here the code.
#ifdef SLEEPMODE
  #include <Adafruit_SleepyDog.h>
#endif
#include <lmic.h>
#include <hal/hal.h>
#include <SPI.h>
// For normal use, we require that you edit the sketch to replace FILLMEIN
// with values assigned by the TTN console. However, for regression tests,
// we want to be able to compile these scripts. The regression tests define
// COMPILE_REGRESSION_TEST, and in that case we define FILLMEIN to a non-
// working but innocuous value.
// This EUI must be in little-endian format, so least-significant-byte
// first. When copying an EUI from ttnctl output, this means to reverse
// the bytes. For TTN issued EUIs the last bytes should be 0xD5, 0xB3,
// 0x70.
static const u1_t PROGMEM APPEUI[8]= { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 };
void os_getArtEui (u1_t* buf) { memcpy_P(buf, APPEUI, 8);}
// This should also be in little endian format, see above.
static const u1_t PROGMEM DEVEUI[8]= {  };
void os_getDevEui (u1_t* buf) { memcpy_P(buf, DEVEUI, 8);}
// This key should be in big endian format (or, since it is not really a
// number but a block of memory, endianness does not really apply). In
// practice, a key taken from the TTN console can be copied as-is.
static const u1_t PROGMEM APPKEY[16] = {  };
void os_getDevKey (u1_t* buf) {  memcpy_P(buf, APPKEY, 16);}
static uint8_t mydata[] = "Hello, world!";
static osjob_t sendjob;
// Schedule TX every this many seconds (might become longer due to duty
// cycle limitations).
const unsigned TX_INTERVAL = 60;
const unsigned TX_TIME = 3;             // rough estimate of transmission time of a single packet
const unsigned MEASURE_TIME = 2;        // seconds measuring time
const unsigned SLEEP_TIME = TX_INTERVAL - TX_TIME - MEASURE_TIME;
const unsigned WAIT_TIME = TX_INTERVAL - TX_TIME - MEASURE_TIME;
// Pin mapping
// Adafruit BSPs are not consistent -- m0 express defs ARDUINO_SAMD_FEATHER_M0,
// m0 defs ADAFRUIT_FEATHER_M0
#if defined(ARDUINO_SAMD_FEATHER_M0) || defined(ADAFRUIT_FEATHER_M0)
// Pin mapping for Adafruit Feather M0 LoRa, etc.
// /!\ By default Adafruit Feather M0's pin 6 and DIO1 are not connected.
// Please ensure they are connected.
const lmic_pinmap lmic_pins = {
    .nss = 8,
    .rxtx = LMIC_UNUSED_PIN,
    .rst = 4,
    .dio = {3, 6, LMIC_UNUSED_PIN},
    .rxtx_rx_active = 0,
    .rssi_cal = 8,              // LBT cal for the Adafruit Feather M0 LoRa, in dB
    .spi_freq = 8000000,
#elif defined(ARDUINO_AVR_FEATHER32U4)
// Pin mapping for Adafruit Feather 32u4 LoRa, etc.
// Just like Feather M0 LoRa, but uses SPI at 1MHz; and that's only
// because MCCI doesn't have a test board; probably higher frequencies
// will work.
// /!\ By default Feather 32u4's pin 6 and DIO1 are not connected. Please
// ensure they are connected.
    .nss = 8,
    .rst = 4,
    .dio = {7, 6, LMIC_UNUSED_PIN},
    .rssi_cal = 8,              // LBT cal for the Adafruit Feather 32U4 LoRa, in dB
    .spi_freq = 1000000,
#elif defined(ARDUINO_CATENA_4551)
// Pin mapping for Murata module / Catena 4551
        .nss = 7,
        .rxtx = 29,
        .rst = 8,
        .dio = { 25,    // DIO0 (IRQ) is D25
                 26,    // DIO1 is D26
                 27,    // DIO2 is D27
        .rxtx_rx_active = 1,
        .rssi_cal = 10,
        .spi_freq = 8000000     // 8MHz
#else
# error "Unknown target"
#endif
void printHex2(unsigned v) {
    v &= 0xff;
    if (v < 16)
        Serial.print('0');
    Serial.print(v, HEX);
void onEvent (ev_t ev) {
    Serial.print(os_getTime());
    Serial.print(": ");
    switch(ev) {
        case EV_SCAN_TIMEOUT:
            Serial.println(F("EV_SCAN_TIMEOUT"));
        case EV_BEACON_FOUND:
            Serial.println(F("EV_BEACON_FOUND"));
        case EV_BEACON_MISSED:
            Serial.println(F("EV_BEACON_MISSED"));
        case EV_BEACON_TRACKED:
            Serial.println(F("EV_BEACON_TRACKED"));
        case EV_JOINING:
            Serial.println(F("EV_JOINING"));
        case EV_JOINED:
            Serial.println(F("EV_JOINED"));
              u4_t netid = 0;
              devaddr_t devaddr = 0;
              u1_t nwkKey[16];
              u1_t artKey[16];
              LMIC_getSessionKeys(&netid, &devaddr, nwkKey, artKey);
              Serial.print("netid: ");
              Serial.println(netid, DEC);
              Serial.print("devaddr: ");
              Serial.println(devaddr, HEX);
              Serial.print("AppSKey: ");
              for (size_t i=0; i<sizeof(artKey); ++i) {
                if (i != 0)
                  Serial.print("-");
                printHex2(artKey[i]);
              Serial.println("");
              Serial.print("NwkSKey: ");
              for (size_t i=0; i<sizeof(nwkKey); ++i) {
                      if (i != 0)
                              Serial.print("-");
                      printHex2(nwkKey[i]);
            // Disable link check validation (automatically enabled
            // during join, but because slow data rates change max TX
	    // size, we don't use it in this example.
            LMIC_setLinkCheckMode(0);
        || This event is defined but not used in the code. No
        || point in wasting codespace on it.
        || case EV_RFU1:
        ||     Serial.println(F("EV_RFU1"));
        ||     break;
        case EV_JOIN_FAILED:
            Serial.println(F("EV_JOIN_FAILED"));
        case EV_REJOIN_FAILED:
            Serial.println(F("EV_REJOIN_FAILED"));
        case EV_TXCOMPLETE:
            Serial.println(F("EV_TXCOMPLETE (includes waiting for RX windows)"));
            if (LMIC.txrxFlags & TXRX_ACK)
              Serial.println(F("Received ack"));
            if (LMIC.dataLen) {
              Serial.println(F("Received "));
              Serial.println(LMIC.dataLen);
              Serial.println(F(" bytes of payload: 0x"));
              for (int i=0; i<LMIC.dataLen; i++) {
                if (LMIC.frame[LMIC.dataBeg + i] < 0x10) {
                  Serial.println(F("0"));
                Serial.println(LMIC.frame[LMIC.dataBeg + i], HEX);
//              Serial.println(F(" bytes of payload"));
#ifdef SLEEPMODE
            // Schedule next transmission in 1ms second after the board returns from sleep mode
            os_setTimedCallback(&sendjob, os_getTime()+ms2osticks(1), do_send);
            Serial.println("going to sleep now ... ");
            // lmic library sleeps automatically after transmission has been completed
            for(int i= 0; i < SLEEP_TIME / 8; i++) {
              Watchdog.sleep(8000); // maximum seems to be 8 seconds
              Serial.println('.');
            if (SLEEP_TIME % 8) {
              Watchdog.sleep((SLEEP_TIME % 8)*1000);
              Serial.println('*');
            Serial.println("... woke up again");
            // We need to reset the duty cycle limits within the LMIC library.
            // The reason is that in sleep mode the Arduino system timers millis and micros
            // do not get incremented. However, LMIC monitors the adherence to the
            // LoRaWAN duty cycle limitations using the system timers millis and micros.
            // Since LMIC does not know that we have slept for a long time and duty
            // cycle requirements in fact are met, we must reset the respective LMIC timers
            // in order to prevent the library to wait for some extra time (which would
            // not use sleep mode and, thus, would waste battery energy).
            LMIC.bands[BAND_MILLI].avail = os_getTime();
            LMIC.bands[BAND_CENTI].avail = os_getTime();
            LMIC.bands[BAND_DECI].avail = os_getTime();
#else
            os_setTimedCallback(&sendjob, os_getTime()+sec2osticks(WAIT_TIME), do_send);
#endif
           // os_setTimedCallback(&sendjob, os_getTime()+sec2osticks(TX_INTERVAL), do_send);
        case EV_LOST_TSYNC:
            Serial.println(F("EV_LOST_TSYNC"));
        case EV_RESET:
            Serial.println(F("EV_RESET"));
        case EV_RXCOMPLETE:
            // data received in ping slot
            Serial.println(F("EV_RXCOMPLETE"));
        case EV_LINK_DEAD:
            Serial.println(F("EV_LINK_DEAD"));
        case EV_LINK_ALIVE:
            Serial.println(F("EV_LINK_ALIVE"));
        || case EV_SCAN_FOUND:
        ||    Serial.println(F("EV_SCAN_FOUND"));
        ||    break;
        case EV_TXSTART:
            Serial.println(F("EV_TXSTART"));
        case EV_TXCANCELED:
            Serial.println(F("EV_TXCANCELED"));
        case EV_RXSTART:
            /* do not print anything -- it wrecks timing */
        case EV_JOIN_TXCOMPLETE:
            Serial.println(F("EV_JOIN_TXCOMPLETE: no JoinAccept"));
        default:
            Serial.print(F("Unknown event: "));
            Serial.println((unsigned) ev);
void do_send(osjob_t* j){
    // Check if there is not a current TX/RX job running
    if (LMIC.opmode & OP_TXRXPEND) {
        Serial.println(F("OP_TXRXPEND, not sending"));
        // Prepare upstream data transmission at the next possible time.
        LMIC_setTxData2(1, mydata, sizeof(mydata)-1, 0);
        Serial.println(F("Packet queued"));
    // Next TX is scheduled after TX_COMPLETE event.
#ifdef SLEEPMODE
        Watchdog.sleep(2000);
#else
        delay(2000);
#endif
    delay(5000);
    while (! Serial)
    Serial.println(F("Starting"));
    #ifdef VCC_ENABLE
    // For Pinoccio Scout boards
    pinMode(VCC_ENABLE, OUTPUT);
    digitalWrite(VCC_ENABLE, HIGH);
    #endif
    // LMIC init
    os_init();
    // Reset the MAC state. Session and pending data transfers will be discarded.
    LMIC_reset();
    LMIC_setAdrMode(false);
    LMIC.dn2Dr = DR_SF9;
    LMIC_setDrTxpow(DR_SF7,14);
    LMIC_selectSubBand(1);
    // Start job (sending automatically starts OTAA too)
    do_send(&sendjob);
    os_runloop_once();
8 seconds is the maximum for the ATmega328. The SAMD21 can go up to 16 seconds.
I doubt that because the hardware abstraction layer doesn't have any code for putting the processor to sleep. The LoRa hardware might be put to sleep but that's handled separately.
In contrary the library depends on being called often (once per loop) and won't work otherwise. So if you want the Feather M0 to sleep you might have to initialize the hardware again because you don't know what you might have missed in the meantime.
I get the Solution in this post.
Thanks
