Yes, it can, but the crystal arrangement I find much more worrying because it's overall a much more sensitive circuit.
I don't think the programming error you're getting is due to the PCB layout. It likely relates to a RST pulse not making it through to the uC.
Mind you, I'm assuming that you have programmed the microcontroller with the bootloader and have set the fuses, yes? Can you confirm that ISP programming works?
For the next/improved version of this board. You'll have to order a new version anyway to fix the oscillator circuit because that's just a problem waiting to happen.
You're also missing a ground plane and your power traces are thin, the lack of a copper pour around the linear regulators is a missed opportunity from a thermal management perspective (also no copper pour on the backside or thermal vias), there are no pullups on the I2C lines so you just have to keep fingers crossed that the ones on the BN0008 module are sufficient...but these are 'survivable' mistakes for this board (probably...).
It's not awfully bad for a first try but if you had taken the time to post this here for a quick review, you would have been able to prevent some of the more obvious errors in your first manufactured board.
PS: again, your board looks really really tidy - just not in a functional way.
I understand, but it works on the arduino mega somehow?
Ah, ok, I have tried to manually connect the GND to RST on my pin header for the ISP when starting an upload to the uC, but that doesnt seem to make a difference.
This seems to work I believe, here is the output I get from verbose arduino IDE when I burn the bootloader:
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\lordmax2\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
Using Port : COM4
Using Programmer : stk500v1
Overriding Baud Rate : 19200
AVR Part : ATmega2560
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 10 8 0 no 4096 8 0 9000 9000 0x00 0x00
flash 65 10 256 0 yes 262144 256 1024 4500 4500 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : STK500
Description : Atmel STK500 Version 1.x firmware
Hardware Version: 2
Firmware Version: 1.18
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.03s
avrdude: Device signature = 0x1e9801 (probably m2560)
avrdude: erasing chip
avrdude: reading input file "0x3F"
avrdude: writing lock (1 bytes):
Writing | ################################################## | 100% 0.01s
avrdude: 1 bytes of lock written
avrdude: verifying lock memory against 0x3F:
avrdude: load data lock data from input file 0x3F:
avrdude: input file 0x3F contains 1 bytes
avrdude: reading on-chip lock data:
Reading | ################################################## | 100% 0.01s
avrdude: verifying ...
avrdude: 1 bytes of lock verified
avrdude: reading input file "0xFD"
avrdude: writing efuse (1 bytes):
avrdude: 1 bytes of efuse written
avrdude: verifying efuse memory against 0xFD:
avrdude: load data efuse data from input file 0xFD:
avrdude: input file 0xFD contains 1 bytes
avrdude: reading on-chip efuse data:
avrdude: 1 bytes of efuse verified
avrdude: reading input file "0xD8"
avrdude: writing hfuse (1 bytes):
avrdude: 1 bytes of hfuse written
avrdude: verifying hfuse memory against 0xD8:
avrdude: load data hfuse data from input file 0xD8:
avrdude: input file 0xD8 contains 1 bytes
avrdude: reading on-chip hfuse data:
avrdude: 1 bytes of hfuse verified
avrdude: reading input file "0xFF"
avrdude: writing lfuse (1 bytes):
avrdude: 1 bytes of lfuse written
avrdude: verifying lfuse memory against 0xFF:
avrdude: load data lfuse data from input file 0xFF:
avrdude: input file 0xFF contains 1 bytes
avrdude: reading on-chip lfuse data:
avrdude: 1 bytes of lfuse verified
avrdude done. Thank you.
"C:\Users\lordmax2\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude" "-CC:\Users\lordmax2\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf" -v -patmega2560 -cstk500v1 -PCOM4 -b19200 "-Uflash:w:C:\Users\lordmax2\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6/bootloaders/stk500v2/stk500boot_v2_mega2560.hex:i" -Ulock:w:0x0F:m
Using Port : COM4
PAGEL : PD7
BS2 : PA0
RETRY pulse : SCK
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Hardware Version: 2
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
Reading | ################################################## | 100% 0.02s
avrdude: NOTE: "flash" memory has been specified, an erase cycle will be performed
To disable this feature, specify the -D option.
avrdude: reading input file "C:\Users\lordmax2\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6/bootloaders/stk500v2/stk500boot_v2_mega2560.hex"
avrdude: writing flash (261406 bytes):
Writing | ################################################## | 100% 0.00s
avrdude: 261406 bytes of flash written
avrdude: verifying flash memory against C:\Users\lordmax2\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6/bootloaders/stk500v2/stk500boot_v2_mega2560.hex:
avrdude: load data flash data from input file C:\Users\lordmax2\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6/bootloaders/stk500v2/stk500boot_v2_mega2560.hex:
avrdude: input file C:\Users\lordmax2\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6/bootloaders/stk500v2/stk500boot_v2_mega2560.hex contains 261406 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 0.00s
avrdude: 261406 bytes of flash verified
avrdude: reading input file "0x0F"
Writing | ################################################## | 100% 0.02s
avrdude: verifying lock memory against 0x0F:
avrdude: load data lock data from input file 0x0F:
avrdude: input file 0x0F contains 1 bytes
It was pretty difficult to get it routed good this small, I will try to have a better layout for the next version!
Thank you so much for your feedback! It is very appreciated!
No.
Note the much shorter traces, and in particular how they're surrounded by a GND guard area. You'll likely see a GND pour on the underside as well.
Your ISP programming for the bootloader seems OK. Try to upload a LED blink sketch through the same interface and observe whether it works. I assume you've set the fuses correctly, but I did not verify it. You should do this to ensure e.g. clock configuration is correct.
I have done some more testing and it seems like if I try to upload a larger sketch, I still get the timeout error.
I tried to upload a small Servo test sketch, but that doesnt seem to work, but I can upload small "Serial.begin" and serial.print sketches. So smoething is definatley not right
I guest maybe some of my 1kOhm resistors can cause some trouble. Or is it also maybe a cosequence of PCB placement?
Like each resistor and capacitor and every component to each other?
Another question, the sizes of each "cable" or connection (I dont know what it is named in circuit boards, but the "line" that connects the components), can you adjust them in EasyEDA?
How do I know if so, how large they should be?
I tried to make an aesthetically for the eye good looking board, but I realize that that isnt the optimal solution, its great to get tips and help from smart people like you! Sorry if I ask stupid questions
No; in general, the higher the frequency of the signal and/or the higher the anticipated currents, the shorter the distance. So the oscillator circuit needs to be closely packed (16MHz) just like USB (12MHz and higher) but the UART components are much less critical (dozens to hundreds of kHz).
Yes. Refer to the EasyEDA manual.
Tools like these also help: https://www.advancedpcb.com/en-us/tools/trace-width-calculator/
Finally, keep an eye on the manufacturing tolerances; the PCB manufacturer (e.g. JLCPCB) will have a list of critical dimensions you should not go under.
And you succeeded! So next time, ensure it's functionally sound first, and within the constraints that arise from this, feel free to make it look good.
Your schematic shows DP1, DP2 and DN1, DN2 connected together by virtue of the net names D11 and D12 even though you don't show a connection via a line on your schematic. Normally you would connect A6 to B6 and A7 to B7 right at the USB-C connector and then proceed with the differential pair traces to their destination.
