Leider kommt es zu dem gleichen Fehler ....
liegt wohl an was Grundlegendem
Fehler beim Herunterladen von http://downloads.arduino.cc/packages/package_index.json
java.lang.RuntimeException: java.lang.Exception: Fehler beim Herunterladen von http://downloads.arduino.cc/packages/package_index.json
at cc.arduino.contributions.packages.ui.ContributionManagerUI.lambda$onUpdatePressed$1(ContributionManagerUI.java:150)
at java.lang.Thread.run(Thread.java:748)
Caused by: java.lang.Exception: Fehler beim Herunterladen von http://downloads.arduino.cc/packages/package_index.json
at cc.arduino.contributions.DownloadableContributionsDownloader.download(DownloadableContributionsDownloader.java:139)
at cc.arduino.contributions.packages.ContributionInstaller.download(ContributionInstaller.java:333)
at cc.arduino.contributions.packages.ContributionInstaller.downloadIndexAndSignature(ContributionInstaller.java:307)
at cc.arduino.contributions.packages.ContributionInstaller.updateIndex(ContributionInstaller.java:285)
at cc.arduino.contributions.packages.ui.ContributionManagerUI.lambda$onUpdatePressed$1(ContributionManagerUI.java:146)
... 1 more
Caused by: java.nio.file.FileSystemException: C:\ProgramData\MATLAB\SupportPackages\R2018a\3P.instrset\arduinoide.instrset\idepkgs\package_index.json.tmp: Der Prozess kann nicht auf die Datei zugreifen, da sie von einem anderen Prozess verwendet wird.
at sun.nio.fs.WindowsException.translateToIOException(WindowsException.java:86)
at sun.nio.fs.WindowsException.rethrowAsIOException(WindowsException.java:97)
at sun.nio.fs.WindowsException.rethrowAsIOException(WindowsException.java:102)
at sun.nio.fs.WindowsFileSystemProvider.implDelete(WindowsFileSystemProvider.java:269)
at sun.nio.fs.AbstractFileSystemProvider.delete(AbstractFileSystemProvider.java:103)
at java.nio.file.Files.delete(Files.java:1126)
at cc.arduino.utils.network.FileDownloader.downloadFile(FileDownloader.java:156)
at cc.arduino.utils.network.FileDownloader.download(FileDownloader.java:132)
at cc.arduino.contributions.DownloadableContributionsDownloader.download(DownloadableContributionsDownloader.java:137)
... 5 more
Mit der Installationsanleitung aus dem Beitrag von HotSystems kann ich die Attiny problemlos installieren (IDE 1.8.7 portable). Wenn das bei Dir nicht funktioniert, liegt das an Deinem System.
