Hello! Im trying to use FFT on my Arduino Uno, using the arduinofft by kosme.
however when im using the serial plotter it will only show me a very short graph of the signal.
setting the code to run every 1 second will only result in showing the same thing every second.
Im putting a 1kHz sinus on the A0 port but it will only give me as shown in the Naamloos.jpg file.
does anybody have an idea why this is showing up like this?
Any help appreciated. Thanks.
In this example, the Arduino simulates the sampling of a sinusoidal 1000 Hz
signal with an amplitude of 100, sampled at 5000 Hz. Samples are stored
inside the vReal array. The samples are windowed according to Hamming
function. The FFT is computed using the windowed samples. Then the magnitudes
of each of the frequencies that compose the signal are calculated. Finally,
the frequency spectrum magnitudes are printed. If you use the Arduino IDE
serial plotter, you will see a single spike corresponding to the 1000 Hz
frecuency.
#include "arduinoFFT.h"
arduinoFFT FFT = arduinoFFT(); /* Create FFT object */
These values can be changed in order to evaluate the functions
const uint16_t samples = 64; //This value MUST ALWAYS be a power of 2
const double signalFrequency = 1000;
const double samplingFrequency = 5000;
const uint8_t amplitude = 100;
These are the input and output vectors
Input vectors receive computed results from FFT
double vReal[samples];
double vImag[samples];
#define SCL_INDEX 0x00
#define SCL_TIME 0x01
#define SCL_FREQUENCY 0x02
#define SCL_PLOT 0x03
/* Build raw data */
double cycles = (((samples-1) * signalFrequency) / samplingFrequency); //Number of signal cycles that the sampling will read
for (uint16_t i = 0; i < samples; i++)
vReal[i] = analogRead(0);
//int8_t((amplitude * (sin((i * (twoPi * cycles)) / samples))) / 2.0);/* Build data with positive and negative values*/
//vReal[i] = uint8_t((amplitude * (sin((i * (twoPi * cycles)) / samples) + 1.0)) / 2.0);/* Build data displaced on the Y axis to include only positive values*/
vImag[i] = 0.0; //Imaginary part must be zeroed in case of looping to avoid wrong calculations and overflows
FFT.Windowing(vReal, samples, FFT_WIN_TYP_HAMMING, FFT_FORWARD); /* Weigh data */
FFT.Compute(vReal, vImag, samples, FFT_FORWARD); /* Compute FFT */
FFT.ComplexToMagnitude(vReal, vImag, samples); /* Compute magnitudes */
PrintVector(vReal, samples>>1, SCL_PLOT);
double x = FFT.MajorPeak(vReal, samples, samplingFrequency);
while(1); /* Run Once */
// delay(2000); /* Repeat after delay */
void PrintVector(double *vData, uint16_t bufferSize, uint8_t scaleType)
for (uint16_t i = 0; i < bufferSize; i++)
double abscissa;
/* Print abscissa value */
switch (scaleType)
case SCL_INDEX:
abscissa = (i * 1.0);
case SCL_TIME:
abscissa = ((i * 1.0) / samplingFrequency);
case SCL_FREQUENCY:
abscissa = ((i * 1.0 * samplingFrequency) / samples);
if(scaleType!=SCL_PLOT)
Serial.print(abscissa, 6);
if(scaleType==SCL_FREQUENCY)
Serial.print("Hz");
Serial.print(" ");
Serial.println(vData[i], 4);
