I am doing some vibration analysis, an accelerometer is attached to the object. I am also using the Telnetstream library with the mpu6050 using WiFi. The data from the accelerometer is viewed on putty.
Can I get tips or advice on how to get the FFT of the data from putty in real-time?
A memory-mapped file contains the contents of a file in virtual memory. This mapping between a file and memory space enables an application, including multiple processes, to modify the file by reading and writing directly to the memory. You can use managed code to access memory-mapped files in the same way that native Windows functions access memory-mapped files, as described in Managing Memory-Mapped Files.
Obviously, one may need to create these two utility programs.
