Now i want to find out how often the sketch has written into the File. Ok i will make in a Loop. But after 24 times i want to rename the file from xxxxxx.txt in xxxxxx.si1 and so on and so on.
I cant find a discription for Fileio.h with a rename class.
Thanks for your Solution. But for me it doesn't work, becauce the current Filename must be always the same. If i would find a command to rename the file, it would work mutch better, because if the fileio Function write with append and the file doesn't exist, it will be created.
Can anybody help me please?
::::SNIP::::
@Perseus01,
FileIO is a very simple library. There is NO rename. However, the filesystem is Linux you can make copy, or move. Use Process like this:
// Fake code only
Process.runShellCommand("cp filename.txt filename.si1")
// _OR_
Process p; // Create a process and call it "p"
p.begin("mv");
p.addParameter("filename.txt");
p.addParameter("filename.si1");
p.run(); // Run the process and wait for its termination
