hi, the following program ran ok initially.
I changed some of the code but reverted it to as you see it below
tried to run it
I then got the following message "the system cannot find file specified error compiling to Arduino board"
I tried to save the file again but when I clicked on it, it opened up a folder inside itself, and the computer commnented "you cannot save a file inside itself"...which I understand
I copied and pasted the code to a new file, saved it and it ran ok
//led blink sketch
// set pin mode to putput
pinMode(2, OUTPUT);
// apply high voltage on the pin
digitalWrite(2, HIGH);
//delay see led on
// apply low voltage on the pin
digitalWrite(2, LOW);
//delay see led off
delay(2500);
Mfa5Mfa5:
fair comment; why is the file opting to file itself, within itself technically?
I have no idea what OS you are using, what version of the IDE you are using, or what you are doing that makes this happen. Whatever the answers are, you do NOT have a programming issue, so you are posting in the wrong place.
