Hello, I am trying to enroll a fingerprint in my Fingerprint sensor but it always seems to not able to store the data. I used the code from the example in Arduino. How can I resolve my problem?
Please post your code, using code tags when you do
Which Arduino board are you using and how is it connected to the fingerprint sensor ?
----------Code---------------
This is an example sketch for our optical Fingerprint sensor
Designed specifically to work with the Adafruit BMP085 Breakout
----> http://www.adafruit.com/products/751
These displays use TTL Serial to communicate, 2 pins are required to
interface
Adafruit invests time and resources providing this open source code,
please support Adafruit and open-source hardware by purchasing
products from Adafruit!
Written by Limor Fried/Ladyada for Adafruit Industries.
BSD license, all text above must be included in any redistribution
#include <Adafruit_Fingerprint.h>
#include <SoftwareSerial.h>
uint8_t id;
uint8_t getFingerprintEnroll();
// Software serial for when you dont have a hardware serial port
// pin #2 is IN from sensor (GREEN wire)
// pin #3 is OUT from arduino (WHITE wire)
// On Leonardo/Micro/Yun, use pins 8 & 9. On Mega, just grab a hardware serialport
SoftwareSerial mySerial(2, 3);
Adafruit_Fingerprint finger = Adafruit_Fingerprint(&mySerial);
// On Leonardo/Micro or others with hardware serial, use those! #0 is green wire, #1 is white
//Adafruit_Fingerprint finger = Adafruit_Fingerprint(&Serial1);
while (!Serial); // For Yun/Leo/Micro/Zero/...
Serial.println("Adafruit Fingerprint sensor enrollment");
// set the data rate for the sensor serial port
finger.begin(57600);
if (finger.verifyPassword()) {
Serial.println("Found fingerprint sensor!");
Serial.println("Did not find fingerprint sensor :(");
while (1);
uint8_t readnumber(void) {
uint8_t num = 0;
boolean validnum = false;
while (1) {
while (! Serial.available());
char c = Serial.read();
if (isdigit(c)) {
num *= 10;
num += c - '0';
validnum = true;
} else if (validnum) {
return num;
void loop() // run over and over again
Serial.println("Ready to enroll a fingerprint! Please Type in the ID # you want to save this finger as...");
id = readnumber();
Serial.print("Enrolling ID #");
Serial.println(id);
while (! getFingerprintEnroll() );
uint8_t getFingerprintEnroll() {
int p = -1;
Serial.print("Waiting for valid finger to enroll as #"); Serial.println(id);
while (p != FINGERPRINT_OK) {
p = finger.getImage();
switch (p) {
case FINGERPRINT_OK:
Serial.println("Image taken");
case FINGERPRINT_NOFINGER:
Serial.println(".");
case FINGERPRINT_PACKETRECIEVEERR:
Serial.println("Communication error");
case FINGERPRINT_IMAGEFAIL:
Serial.println("Imaging error");
default:
Serial.println("Unknown error");
// OK success!
p = finger.image2Tz(1);
switch (p) {
Serial.println("Image converted");
case FINGERPRINT_IMAGEMESS:
Serial.println("Image too messy");
return p;
return p;
case FINGERPRINT_FEATUREFAIL:
Serial.println("Could not find fingerprint features");
return p;
case FINGERPRINT_INVALIDIMAGE:
return p;
default:
return p;
Serial.println("Remove finger");
delay(2000);
p = 0;
while (p != FINGERPRINT_NOFINGER) {
Serial.print("ID "); Serial.println(id);
p = -1;
Serial.println("Place same finger again");
switch (p) {
Serial.print(".");
default:
// OK success!
p = finger.image2Tz(2);
switch (p) {
return p;
return p;
return p;
return p;
default:
return p;
// OK converted!
Serial.print("Creating model for #"); Serial.println(id);
p = finger.createModel();
if (p == FINGERPRINT_OK) {
Serial.println("Prints matched!");
} else if (p == FINGERPRINT_PACKETRECIEVEERR) {
return p;
} else if (p == FINGERPRINT_ENROLLMISMATCH) {
Serial.println("Fingerprints did not match");
return p;
return p;
p = finger.storeModel(id);
Serial.println("Stored!");
return p;
} else if (p == FINGERPRINT_BADLOCATION) {
Serial.println("Could not store in that location");
return p;
} else if (p == FINGERPRINT_FLASHERR) {
Serial.println("Error writing to flash");
return p;
return p;
I am using [AS608] fingerprint scanner here is the picture of it:
So wiring:
3.3 V to 3.3V
GND to GND
TX to D2
RX to D3
Arduino UNO
What do you see on the Serial monitor when you start the sketch and when you try to save a fingerprint ?
What makes you think that the data is not being stored ?
"Error Writing to flash" and I watched some YT vids and when the enroll a fingerprint the serial monitor usually tell "Stored" but mine isn't.
A comment in the code says
But you say
That may be the problem
Hmmm then how can I enroll fingerprints then?
Google has plenty of information on the AS608 interfaced with Arduino
For instance Interfacing AS608 Optical Fingerprint Sensor Module with Arduino
I still have the same problem ![]()
I am sorry but I don't have the hardware to test this so can offer little or no further help except to suggest that you check your wiring very carefully
Thank you for the Help, I'll look into it more deeply
I got it!!; it was the hardware; I changed the fingerprint scanner but same model and it stored my fingerprint!
