I connected the TX wire (green wire) connected to pin 3 and RX wire (white wire) connected to pin 2. The Power wire (red wire) is connected to 5V and the GND wire (black wire) is connected to GND on the Arduino. I am using Arduino UNO and the Adafruit Fingerprint sensor Product 751. I have tried using multiple different pins and have switched the TX and RX wires. I have confirmed that the connections are good using a multimeter and have even re-soldered the RX and TX wires to make sure it wasn't a connectivity issue. The fingerprint sensor's LED lights up but when I open the Serial Monitor and it runs the "fingertest", it always shows "Did not find fingerprint sensor : (". I have looked at many other forums and tried to change the code to SoftwareSerial myserial(8,3); however, it still does not detect the fingerprint sensor. Can someone explain why this might be happening and how I can fix it?
#include <Adafruit_Fingerprint.h>
#include <SoftwareSerial.h>
int getFingerprintIDez();
SoftwareSerial mySerial(2, 3);
Adafruit_Fingerprint finger = Adafruit_Fingerprint(&mySerial);
Serial.println("fingertest");
pinMode(13, OUTPUT);
digitalWrite(13, LOW);
// set the data rate for the sensor serial port
finger.begin(9600);
if (finger.verifyPassword()) {
Serial.println("Found fingerprint sensor!");
Serial.println("Did not find fingerprint sensor : (");
while (1) {delay(1);}
finger.getTemplateCount();
Serial.print("Sensor contains ");
Serial.print(finger.templateCount);
Serial.println(" templates");
Serial.println("Waiting for valid finger…");
void loop() // run over and over again
delay(50); //don’t ned to run this at full speed.
uint8_t getFingerprintID() {
uint8_t p = finger.getImage();
switch (p) {
case FINGERPRINT_OK:
Serial.println("Image taken");
case FINGERPRINT_NOFINGER:
Serial.println("No finger detected");
return p;
case FINGERPRINT_PACKETRECIEVEERR:
Serial.println("Communication error");
return p;
case FINGERPRINT_IMAGEFAIL:
Serial.println("Imaging error");
return p;
default:
Serial.println("Unknown error");
return p;
// OK success!
p = finger.image2Tz();
switch (p) {
Serial.println("Image converted");
case FINGERPRINT_IMAGEMESS:
Serial.println("Image too messy");
return p;
return p;
case FINGERPRINT_FEATUREFAIL:
Serial.println("Could not find fingerprint features");
return p;
case FINGERPRINT_INVALIDIMAGE:
return p;
default:
return p;
// OK converted!
p = finger.fingerFastSearch();
if (p == FINGERPRINT_OK) {
Serial.println("Found a print match!");
} else if (p == FINGERPRINT_PACKETRECIEVEERR) {
return p;
} else if (p == FINGERPRINT_NOTFOUND) {
Serial.println("Did not find a match");
return p;
return p;
// found a match!
Serial.print("Found ID #"); Serial.print(finger.fingerID);
Serial.print(" with confidence of "); Serial.println(finger.confidence);
// returns -1 if failed, otherwise returns ID #
int getFingerprintIDez() {
if (p != FINGERPRINT_OK) return -1;
// found a match!
digitalWrite(13, HIGH);
delay(3000);
return finger.fingerID;
