Fingerprint sensor JM 201b 1737C not working but showing light
I am working on a project using fingerprint sensor JM 201b 1737C and Arduino Nano. I have trying to get it to work for some days without success. The fingerprint sensor is not detected by the Arduino Nano.
Here is the way I connected them:
Arduino Nano. Fingerprint sensor
3.3v Red wire
GND. black wire
Tx. Yellow wire
Rx Blue
I even interchanged the Tx and Rx wires, but it still does not work.
Code:
  This is an example sketch for our optical Fingerprint sensor
  Designed specifically to work with the Adafruit BMP085 Breakout
  ----> http://www.adafruit.com/products/751
  These displays use TTL Serial to communicate, 2 pins are required to
  interface
  Adafruit invests time and resources providing this open source code,
  please support Adafruit and open-source hardware by purchasing
  products from Adafruit!
  Written by Limor Fried/Ladyada for Adafruit Industries.
  BSD license, all text above must be included in any redistribution
#include <Adafruit_Fingerprint.h>
#if (defined(__AVR__) || defined(ESP8266)) && !defined(__AVR_ATmega2560__)
// For UNO and others without hardware serial, we must use software serial...
// pin #2 is IN from sensor (GREEN wire)
// pin #3 is OUT from arduino  (WHITE wire)
// Set up the serial port to use softwareserial..
SoftwareSerial mySerial(2, 3);
#else
// On Leonardo/M0/etc, others with hardware serial, use hardware serial!
// #0 is green wire, #1 is white
#define mySerial Serial1
#endif
Adafruit_Fingerprint finger = Adafruit_Fingerprint(&mySerial);
  while (!Serial);  // For Yun/Leo/Micro/Zero/...
  delay(100);
  Serial.println("\n\nAdafruit finger detect test");
  // set the data rate for the sensor serial port
  finger.begin(57600);
  delay(5);
  if (finger.verifyPassword()) {
    Serial.println("Found fingerprint sensor!");
    Serial.println("Did not find fingerprint sensor :(");
    while (1) { delay(1); }
  Serial.println(F("Reading sensor parameters"));
  finger.getParameters();
  Serial.print(F("Status: 0x")); Serial.println(finger.status_reg, HEX);
  Serial.print(F("Sys ID: 0x")); Serial.println(finger.system_id, HEX);
  Serial.print(F("Capacity: ")); Serial.println(finger.capacity);
  Serial.print(F("Security level: ")); Serial.println(finger.security_level);
  Serial.print(F("Device address: ")); Serial.println(finger.device_addr, HEX);
  Serial.print(F("Packet len: ")); Serial.println(finger.packet_len);
  Serial.print(F("Baud rate: ")); Serial.println(finger.baud_rate);
  finger.getTemplateCount();
  if (finger.templateCount == 0) {
    Serial.print("Sensor doesn't contain any fingerprint data. Please run the 'enroll' example.");
  else {
    Serial.println("Waiting for valid finger...");
      Serial.print("Sensor contains "); Serial.print(finger.templateCount); Serial.println(" templates");
void loop()                     // run over and over again
  getFingerprintID();
  delay(50);            //don't ned to run this at full speed.
uint8_t getFingerprintID() {
  uint8_t p = finger.getImage();
  switch (p) {
    case FINGERPRINT_OK:
      Serial.println("Image taken");
    case FINGERPRINT_NOFINGER:
      Serial.println("No finger detected");
      return p;
    case FINGERPRINT_PACKETRECIEVEERR:
      Serial.println("Communication error");
      return p;
    case FINGERPRINT_IMAGEFAIL:
      Serial.println("Imaging error");
      return p;
    default:
      Serial.println("Unknown error");
      return p;
  // OK success!
  p = finger.image2Tz();
  switch (p) {
      Serial.println("Image converted");
    case FINGERPRINT_IMAGEMESS:
      Serial.println("Image too messy");
      return p;
      return p;
    case FINGERPRINT_FEATUREFAIL:
      Serial.println("Could not find fingerprint features");
      return p;
    case FINGERPRINT_INVALIDIMAGE:
      return p;
    default:
      return p;
  // OK converted!
  p = finger.fingerSearch();
  if (p == FINGERPRINT_OK) {
    Serial.println("Found a print match!");
  } else if (p == FINGERPRINT_PACKETRECIEVEERR) {
    return p;
  } else if (p == FINGERPRINT_NOTFOUND) {
    Serial.println("Did not find a match");
    return p;
    return p;
  // found a match!
  Serial.print("Found ID #"); Serial.print(finger.fingerID);
  Serial.print(" with confidence of "); Serial.println(finger.confidence);
  return finger.fingerID;
// returns -1 if failed, otherwise returns ID #
int getFingerprintIDez() {
  if (p != FINGERPRINT_OK)  return -1;
  p = finger.fingerFastSearch();
  // found a match!
Here is the picture of the sensor.
What is that? Link?
I personally would connect the sensor directly with dupont wires to nano, without intermittent connections and breadboard.
Also the baud rate is at the high end for software serial.
it seems to be a 3.3V module. Are you sending 5V over Tx ? did you kill it... ?
also the 3.3V pin of the Nano delivers 50mA if I remember correctly. Your device might require more than that...
I tried both 5v and 3.3V for the Vcc. I do not know if I had destroyed it in the process.
do you have a datasheet ?
I do not have. I bought it from a local store, and what they provided is not specific to this particular model.
Does the board have any marking ?
I also bought this exact same Fingerprint scanner (JM-201B 1737C) from a local store. It didn't come with any pin labelling, neither did it come with any data sheet or any information regarding the pin connections.
I'm trying to interface mine with an ESP32 module. It doesn't respond at all. Even after interchanging the suspected TX and RX pins.
If it is the exact same one and it does not work in the exact same way then it’s either not the same, or you did not use it the same way or it’s broken…
Describe this.
Your code does not test if the fingerprint reader is communicating, it tests for a password. The if() conditional should test if finger.begin() gives a good return.
Where did you get this code?
The Adafruit_fingerprint.h library has examples in IDE >> FILE >> EXAMPLES >> ADAFRUIT FINGERPRINT >> (examples here)
Or, here... Adafruit-Fingerprint-Sensor-Library/examples at master · adafruit/Adafruit-Fingerprint-Sensor-Library · GitHub
I have this same issue too. I used 5v though. It seems the problem is that arduino fingerprint library is not compatible with this sensor. It was made for a custom library which we dont have access to
The OP and the other user never responded. Did you try the suggestions?
