Fingerprint Sensor (R503) not working
Hello
I am having issues with activating adafruit fingerprint sensor
Rugged Panel Mount Fingerprint Sensor with Bi-Color LED Ring (R503) [/b]
Wired as instructed
Red 3v
Black gnd
Green Tx
White Rx
gear:
arduino Uno & R503 fingerprint sensor by adafruit
The sensor doesn't blinks at all at any time
After uploading the adafruit enroll get a message
adafruit did not find fingerprint sensor :(
soldered sensor wires to thicker male pins wires to insert to a board and tested for continuity - rings ok - and the
micro controller is ok as well tried to power cycle by disconnecting / reconnecting the 3v and the arduino as well
what else should I try? or the sensor is defective?
Thank you everybody!
Do you have Green connected to Pin 2 and White connected to Pin 3?
// For UNO and others without hardware serial, we must use software serial...
// pin #2 is IN from sensor (GREEN wire)
// pin #3 is OUT from arduino  (WHITE wire)
// Set up the serial port to use softwareserial..
SoftwareSerial mySerial(2, 3);
yes... same...
when I started I had similar problems with my NodeMCU 8266.
For me it worked after setting the PinMode for the RxD/TxD Pins
pinMode(D2, INPUT);  /* RS232 RxD */
pinMode(D3, OUTPUT); /* RS232 TxD */
Good luck
Frank
