fingerprint sensor with AS608
Hi everybody!
I have a problem with my new bought fingerprint sensor. ( this )
Before this I had one with AS606 processor (worked fine), but this has AS608 (doesn't work). The problem is, that a basic example program like enroll or fingerprint doesn't find the fingerprint sensor. (with AS608).
  1. The pinout is absolutely OK (see on the picture) VIN - 5V, GND - GND, RX - TX, TX - RX.
    picture :
    Moderator: Edited imaged with tags.
  2. I think the current and the voltage is enough. (I try more source)
  3. I tried with Arduino UNO and NodeMCU, too.
  4. I tried with HW Serial and with SW Serial, too.
But nothing solved my problem.
Have you got any idea?
I feel, that I'm lost. :frowning:
Thank you very much!
I bought the AS608 chip reader too and have the same problem. It is also marked DY50 on a sticker on the back.
I have verified the pinouts on the 6 red wires using an Ohm-meter between the pins and the circuit board (which is marked DY50-MAN V3). Left pin is Gnd, next two are TX/RX, and 4th pin is Vcc.
Did you find a solution?
No, i am not. :frowning: I
I have the same problem, I´ll be so thankfull if you alredy found a solution you can tell me about it
hello. i got the same problem. i hoppe all of you can give support. thank you ASAP
