Firebeetle 2 ESP32-E, RFID, MicroSD, RTC - RFID scans once
Seem lots of posts and questions about this type of topic but not found a solution that fixes my issue.
I have ESP32 Firebeetle 2 ESP32-E and want to use RFID, microSD and 1307RTC.
When i connect as per circuit diagram the RFID only scans once and doesn't do any further scans of cards etc. but the loop continues to run.
Tried lots of different permutations, adjustments to code but no matter how connect the 3 up it doesn't do more than one RFID scan.
RTC:
MFRC522:
Temp:
Micro SD Card:
#include <MFRC522.h>  // for the RFID
#include <SPI.h>      // for the RFID and SD card module
#include <SD.h>       // for the SD card
#include <DS1307RTC.h>
#include <TimeLib.h>
// define pins for RFID
#define CS_RFID 21
#define RST_RFID 26
// define select pin for SD card module
#define CS_SD 14
// Create a file to store the data
File myFile;
// Instance of the class for RFID
MFRC522 rfid(CS_RFID, RST_RFID);  // Instance of the class
MFRC522::MIFARE_Key key;
// Init array that will store new NUID
byte nuidPICC[4];
  // Init Serial port
  while (!Serial);
  // Init SPI bus
  SPI.begin();
  // Init MFRC522
  rfid.PCD_Init();
  // Setup for the SD card
  Serial.print("Initializing SD card...");
  if (!SD.begin(CS_SD)) {
    Serial.println("initialization failed!");
    return;
  Serial.println("initialization done.");
  testtime();
  //look for new cards
  readRFID();
    delay(100);
    Serial.print(".");
void readRFID() {
  if (!rfid.PICC_IsNewCardPresent())
    return;
  // Verify if the NUID has been readed
  if (!rfid.PICC_ReadCardSerial())
    return;
  Serial.print(F("PICC type: "));
  MFRC522::PICC_Type piccType = rfid.PICC_GetType(rfid.uid.sak);
  Serial.println(rfid.PICC_GetTypeName(piccType));
  // Check is the PICC of Classic MIFARE type
  if (piccType != MFRC522::PICC_TYPE_MIFARE_MINI && piccType != MFRC522::PICC_TYPE_MIFARE_1K && piccType != MFRC522::PICC_TYPE_MIFARE_4K) {
    Serial.println(F("Your tag is not of type MIFARE Classic."));
    return;
  if (rfid.uid.uidByte[0] != nuidPICC[0] || rfid.uid.uidByte[1] != nuidPICC[1] || rfid.uid.uidByte[2] != nuidPICC[2] || rfid.uid.uidByte[3] != nuidPICC[3]) {
    Serial.println(F("A new card has been detected."));
    // Store NUID into nuidPICC array
    for (byte i = 0; i < 4; i++) {
      nuidPICC[i] = rfid.uid.uidByte[i];
    Serial.print(F("In hex: "));
    printHex(rfid.uid.uidByte, rfid.uid.size);
  } else Serial.println(F("Card read previously."));
  // Halt PICC
  rfid.PICC_HaltA();
  // Stop encryption on PCD
  rfid.PCD_StopCrypto1();
  testtime();
void testtime(){
tmElements_t tm;
  String TimeNow;
  if (RTC.read(tm)) {
    //Serial.print("Ok, Time = ");
    print2digits(tm.Hour);
    Serial.write(':');
    print2digits(tm.Minute);
    Serial.write(':');
    print2digits(tm.Second);
    Serial.print(", Date (D/M/Y) = ");
    Serial.print(tm.Day);
    Serial.write('/');
    Serial.print(tm.Month);
    Serial.write('/');
    Serial.print(tmYearToCalendar(tm.Year));
    if (RTC.chipPresent()) {
      Serial.println("The DS1307 is stopped.  Please run the SetTime");
      Serial.println("example to initialize the time and begin running.");
      Serial.println("DS1307 read error!  Please check the circuitry.");
void print2digits(int number) {
  if (number >= 0 && number < 10) {
    Serial.write('0');
  Serial.print(number);
 * Helper routine to dump a byte array as hex values to Serial.
void printHex(byte *buffer, byte bufferSize) {
  for (byte i = 0; i < bufferSize; i++) {
    Serial.print(buffer[i] < 0x10 ? " 0" : " ");
    Serial.print(buffer[i], HEX);
Just kinda' guessing here. But where's the chip select on the FRC522? Also, are you trying to use two different clock lines on a shared SPI Bus? Maybe on the ESP things work differently, but this seems wrong to me.
Suppose i want someone who has done this config before to let me know what to connect to what.
I can get RFID and RTC working but not with SD and can get RFID working with SD but not with RTC. Ideally would like all working together.
for an example of using a SD card and RFID reader on a ESP32 see lora-problem-slow-code-or-error-code
ESP32 example with SD card using VSPI MFRC522 RFID reader using HSPI
// ESP32 - SD card using VSPI MFRC522 RFID reader using HSPI
// see https://forum.arduino.cc/t/esp32-initialize-hspi-as-default-spi/1155093/12
/* original SD code from
  Rui Santos
  Complete project details at https://RandomNerdTutorials.com/esp32-microsd-card-arduino/
#include "FS.h"
#include "SD.h"
#include "SPI.h"
// MFRC522 RFID reader
#include <MFRC522v2.h>
#include <MFRC522DriverSPI.h>
#include <MFRC522DriverPinSimple.h>
#include <MFRC522Debug.h>
// default HSPI pins used by MFRC522 RFID reader
#define HSPI_SCK 14
#define HSPI_MISO 12
#define HSPI_MOSI 13
#define HSPI_CS 15
SPIClass *hspi = new SPIClass(HSPI);      // HSPI object used by MFRC522
MFRC522DriverPinSimple ss_1_pin(HSPI_CS);   // Configurable, take an unused pin, only HIGH/LOW required, must be different to SS 2.
MFRC522DriverSPI driver_1{ ss_1_pin, *hspi };
MFRC522 reader = driver_1;                // Create MFRC522 instance.
// ESP32 RTC
#include <ESP32Time.h>
ESP32Time rtc(3600);  // offset in seconds GMT+1
  delay(2000);
  Serial.println("Read MRFC522 RFID card save time and data to SD card");
  rtc.setTime(1609459200);  // initialise RTC 1st Jan 2021 00:00:00
  // setup SD card reader using VSPI
  if (!SD.begin()) {                       // mount card
    Serial.println("Card Mount Failed");
    return;
  uint8_t cardType = SD.cardType();
  if (cardType == CARD_NONE) {
    Serial.println("No SD card attached");
    return;
  Serial.print("SD Card Type: ");
  if (cardType == CARD_MMC) {
    Serial.println("MMC");
  } else if (cardType == CARD_SD) {
    Serial.println("SDSC");
  } else if (cardType == CARD_SDHC) {
    Serial.println("SDHC");
    Serial.println("UNKNOWN");
  uint64_t cardSize = SD.cardSize() / (1024 * 1024);
  Serial.printf("SD Card Size: %lluMB\n", cardSize);
  listDir(SD, "/", 0);
  Serial.printf("Total space: %lluMB\n", SD.totalBytes() / (1024 * 1024));
  Serial.printf("Used space: %lluMB\n", SD.usedBytes() / (1024 * 1024));
  // setup MRFC522 RFID reader using HSPI
  Serial.print("open MRFC522 RFID reader");
  reader.PCD_Init();  // Init MFRC522 card.
  MFRC522Debug::PCD_DumpVersionToSerial(reader, Serial);
  // check Serial input read or delete data file
  if (Serial.available()) {
    char ch = Serial.read();
    if (ch == 'p')
      readFile(SD, "/data.txt");
    if (ch == 'd')
      deleteFile(SD, "/data.txt");
  // check MFRC522 RFID reader
  if (reader.PICC_IsNewCardPresent() && reader.PICC_ReadCardSerial()) {
    Serial.print("\n");
    Serial.println(rtc.getTime("%A, %B %d %Y %H:%M:%S"));  // (String) returns time with specified format
    // Show some details of the PICC (that is: the tag/card).
    Serial.print(F(" Card UID:"));
    MFRC522Debug::PrintUID(Serial, reader.uid);
    Serial.print("  PICC type: ");
    MFRC522::PICC_Type piccType = reader.PICC_GetType(reader.uid.sak);
    Serial.println(MFRC522Debug::PICC_GetTypeName(piccType));
    // save card details to SD
    String s = rtc.getTime("%A, %d/%m/%Y %H:%M:%S") + " Card UID:";
    for (byte i = 0; i < reader.uid.size; i++) {
      char text[10] = { 0 };
      snprintf(text, 100, " 0x%2X", reader.uid.uidByte[i]);
      s += String(text);
    s += "  PICC type: " + String((const char *)MFRC522Debug::PICC_GetTypeName(piccType)) + "\n";
    appendFile(SD, "/data.txt", s.c_str());
    // Halt PICC.
    reader.PICC_HaltA();
    // Stop encryption on PCD.
    reader.PCD_StopCrypto1();
// ************** SD functions **************************
void listDir(fs::FS &fs, const char *dirname, uint8_t levels) {
  Serial.printf("Listing directory: %s\n", dirname);
  File root = fs.open(dirname);
  if (!root) {
    Serial.println("Failed to open directory");
    return;
  if (!root.isDirectory()) {
    Serial.println("Not a directory");
    return;
  File file = root.openNextFile();
  while (file) {
    if (file.isDirectory()) {
      Serial.print("  DIR : ");
      Serial.println(file.name());
      if (levels) {
        listDir(fs, file.name(), levels - 1);
      Serial.print("  FILE: ");
      Serial.print(file.name());
      Serial.print("  SIZE: ");
      Serial.println(file.size());
void createDir(fs::FS &fs, const char *path) {
  Serial.printf("Creating Dir: %s\n", path);
  if (fs.mkdir(path)) {
    Serial.println("Dir created");
    Serial.println("mkdir failed");
void removeDir(fs::FS &fs, const char *path) {
  Serial.printf("Removing Dir: %s\n", path);
  if (fs.rmdir(path)) {
    Serial.println("Dir removed");
    Serial.println("rmdir failed");
void readFile(fs::FS &fs, const char *path) {
  Serial.printf("\nReading file: %s\n", path);
  File file = fs.open(path);
  if (!file) {
    Serial.println("Failed to open file for reading");
    return;
  //Serial.print("Read from file: ");
  while (file.available()) {
    Serial.write(file.read());
  file.close();
void writeFile(fs::FS &fs, const char *path, const char *message) {
  Serial.printf("Writing file: %s\n", path);
  File file = fs.open(path, FILE_WRITE);
  if (!file) {
    Serial.println("Failed to open file for writing");
    return;
  if (file.print(message)) {
    Serial.println("File written");
    Serial.println("Write failed");
  file.close();
void appendFile(fs::FS &fs, const char *path, const char *message) {
  //Serial.printf("Appending to file: %s\n", path);
  File file = fs.open(path, FILE_APPEND);
  if (!file) {
    Serial.println("Failed to open file for appending");
    return;
    //Serial.println("Message appended");
    Serial.println("Append failed");
  file.close();
void renameFile(fs::FS &fs, const char *path1, const char *path2) {
  Serial.printf("Renaming file %s to %s\n", path1, path2);
  if (fs.rename(path1, path2)) {
    Serial.println("File renamed");
    Serial.println("Rename failed");
void deleteFile(fs::FS &fs, const char *path) {
  Serial.printf("Deleting file: %s\n", path);
  if (fs.remove(path)) {
    Serial.println("File deleted");
    Serial.println("Delete failed");
void testFileIO(fs::FS &fs, const char *path) {
  static uint8_t buf[512];
  size_t len = 0;
  uint32_t start = millis();
  uint32_t end = start;
  if (file) {
    len = file.size();
    size_t flen = len;
    start = millis();
    while (len) {
      size_t toRead = len;
      if (toRead > 512) {
        toRead = 512;
      file.read(buf, toRead);
      len -= toRead;
    end = millis() - start;
    Serial.printf("%u bytes read for %u ms\n", flen, end);
    file.close();
  if (!file) {
    return;
  size_t i;
  start = millis();
  for (i = 0; i < 2048; i++) {
    file.write(buf, 512);
  Serial.printf("%u bytes written for %u ms\n", 2048 * 512, end);
  file.close();
test run results
ESP32 SD card test - note VCC to 5V
SD Card Type: SDHC
SD Card Size: 14992MB
Listing directory: /
  DIR : System Volume Information
  FILE: test.txt  SIZE: 1048576
  FILE: data.txt  SIZE: 891
Total space: 14984MB
Used space: 2MB
open MRFC522 RFID readerFirmware Version: 0x92 = v2.0
dDeleting file: /data.txt
File deleted
Friday, January 01 2021 01:00:14
 Card UID: ZZ XX FD C2  PICC type: MIFARE 1KB
Friday, January 01 2021 01:00:18
 Card UID: Z0 XF 62 1A  PICC type: MIFARE 1KB
Friday, January 01 2021 01:00:19
Friday, January 01 2021 01:00:22
Friday, January 01 2021 01:00:23
Friday, January 01 2021 01:02:30
p
Reading file: /data.txt
Friday, 01/01/2021 01:00:14 Card UID: 0xZZ 0xXX 0xFD 0xC2  PICC type: MIFARE 1KB
Friday, 01/01/2021 01:00:18 Card UID: 0xZ0 0xXF 0x62 0x1A  PICC type: MIFARE 1KB
Friday, 01/01/2021 01:00:19 Card UID: 0xZ0 0xXF 0x62 0x1A  PICC type: MIFARE 1KB
Friday, 01/01/2021 01:00:22 Card UID: 0xZZ 0xXX 0xFD 0xC2  PICC type: MIFARE 1KB
Friday, 01/01/2021 01:00:23 Card UID: 0xZZ 0xXX 0xFD 0xC2  PICC type: MIFARE 1KB
Friday, 01/01/2021 01:02:30 Card UID: 0xZ0 0xXF 0x62 0x1A  PICC type: MIFARE 1KB
Friday, January 01 2021 01:03:28
p
Friday, 01/01/2021 01:03:28 Card UID: 0xZZ 0xXX 0xFD 0xC2  PICC type: MIFARE 1KB
Thanks and will have a look...the only missing component is the 1307RTC module.
the 1307RTC uses I2C interface so should be no problem
the code of post 5 used the onboard ESP32 RTC but there is no simple way to battery back it
