Other links: GitHub - arduino/WiFi101-FirmwareUpdater-Plugin: WiFi101 Firmware Updater Tool for Arduino IDE contains the source for the new updater.
Pro tip: if you want to add the new updater to an older installation of the IDE without downloading the nightly, download this file and extract it to your sketchbook folder.
After restarting the IDE you can use the new entry under Tools menu to perform the update.
lsaetta65:
I have tried it and it has not worked. See comments on the issue in github
Can you add a link directly to the issue please ?
Also did not work for me either with 1.8.6 - 1.8.7.
Managed to get the FW updater sketch into the 1010 with 1.8.5 after dropping it in as facchinm suggested but still seem to be hitting a stumbling block once I try to TEST CONNECTION.
More info to follow....
SAMD core 1.6.19
IDE 1.8.7
Just sits on uploading with the bar almost finished.
This 1010 had been set for CLOUD use
If I compile only it does so just fine.
If I then try to re-upload the FW update sketch I occasionally get the following.
Arduino: 1.8.7 (Windows 7), Board: "Arduino MKR WiFi 1010"
Sketch uses 13072 bytes (4%) of program storage space. Maximum is 262144 bytes.
Forcing reset using 1200bps open/close on port COM34
processing.app.debug.RunnerException
at cc.arduino.packages.uploaders.SerialUploader.uploadUsingPreferences(SerialUploader.java:160)
at cc.arduino.UploaderUtils.upload(UploaderUtils.java:82)
at processing.app.SketchController.upload(SketchController.java:736)
at processing.app.SketchController.exportApplet(SketchController.java:703)
at processing.app.Editor$DefaultExportHandler.run(Editor.java:2028)
at java.lang.Thread.run(Thread.java:748)
Caused by: processing.app.SerialException: Error touching serial port 'COM34'.
at processing.app.Serial.touchForCDCReset(Serial.java:107)
at cc.arduino.packages.uploaders.SerialUploader.uploadUsingPreferences(SerialUploader.java:144)
... 5 more
Caused by: jssc.SerialPortException: Port name - COM34; Method name - openPort(); Exception type - Port busy.
at jssc.SerialPort.openPort(SerialPort.java:164)
at processing.app.Serial.touchForCDCReset(Serial.java:101)
... 6 more
An error occurred while uploading the sketch
Exception in thread "Thread-18" java.util.ConcurrentModificationException
at java.util.LinkedList$ListItr.checkForComodification(LinkedList.java:966)
at java.util.LinkedList$ListItr.next(LinkedList.java:888)
at processing.app.packages.LibraryList.getByName(LibraryList.java:61)
at cc.arduino.contributions.libraries.LibrariesIndexer.addToInstalledLibraries(LibrariesIndexer.java:130)
at cc.arduino.contributions.libraries.LibrariesIndexer.scanLibrary(LibrariesIndexer.java:229)
at cc.arduino.contributions.libraries.LibrariesIndexer.scanInstalledLibraries(LibrariesIndexer.java:201)
at cc.arduino.contributions.libraries.LibrariesIndexer.rescanLibraries(LibrariesIndexer.java:161)
at cc.arduino.contributions.libraries.LibrariesIndexer.setLibrariesFolders(LibrariesIndexer.java:120)
at processing.app.BaseNoGui.onBoardOrPortChange(BaseNoGui.java:678)
at processing.app.Base.onBoardOrPortChange(Base.java:1313)
at processing.app.Editor$DefaultExportHandler.run(Editor.java:2058)
option enabled in File -> Preferences.
UPDATE.
Sometimes doing the DOUBLE TAP RESET will allow me to get the sketch in using the newer IDE's
The NIGHTLY IDE ?> 1.6.10 <? Gives the following on running it from its extracted folder.
Ok, gentlemen. It has worked for me, thks to kind help from @facchinm. MY problem was that I had upgraded WiFINIna to 1.2 before and therefore I hadn't in Wifinina dir the right firmware updater sketch.
Workaround suggested: delete the directory for WiFINIna under library.
Reinstall the WifiNIna, ver.s 1.2
Install the right (for WifiNIna) Firmware UPgrader Sketch
Upgrade the firmware.
Confirmed. I had the same problem as @Isaetta65. I had previously upgraded to 1.2 and it showed the wrong firmware (winc b something) even though I updated the library manager's wifinina to 1.2 from 1.1.
Removed the libraries\WiFiNINA .... replaced hourly build... downloaded 1.2 again... and the upload of Examples\WiFiNINA\Tools\FirmUpdater ... then ran WiFiNINA Firmware Updater.
I recently bought a MKR1010 and used it successfully with the WifiNina library. Nice board!
When I decided to come to Adafruit IO, I experienced all the problems you had but discovering this post and some others, I was happy to get the solution.
So, I did:
uninstall totally IDE 1.8.7 version
download hourly BUILD 1.8.7
import last 1.2 version of WifiNina library with the library manager
load the Firmware updater sketch
launch the WiFi / WiFiNina Firmware/certificates updater
the COM port is the good one
the Nina Firmware version is 1.1.0
And I have a problem: "Programmer not responding"
I must add that I can successfully load the Blink example before AND after the problem. The COM port is running well.
