ballscrewbob:
This is the lower console output from the sketch UPLOAD.
Atmel SMART device 0x10010005 found
Device : ATSAMD21G18A
Chip ID : 10010005
Version : v2.0 [Arduino:XYZ] Mar 19 2018 09:45:14
Address : 8192
Pages : 3968
Page Size : 64 bytes
Total Size : 248KB
Planes : 1
Lock Regions : 16
Locked : none
Security : false
Boot Flash : true
BOD : true
BOR : true
Arduino : FAST_CHIP_ERASE
Arduino : FAST_MULTI_PAGE_WRITE
Arduino : CAN_CHECKSUM_MEMORY_BUFFER
Erase flash
done in 0.826 seconds
Write 13344 bytes to flash (209 pages)
[========= ] 30% (64/209 pages)
[================== ] 61% (128/209 pages)
[=========================== ] 91% (192/209 pages)
[==============================] 100% (209/209 pages)
done in 0.092 seconds
Verify 13344 bytes of flash with checksum.
Verify successful
done in 0.022 seconds
CPU reset.
That step must be done BEFORE the firmware update.
That DOES NOT UPDATE THE FIRMWARE !
It only prepares the board itself for the update.
Once that is done then you would select WiFi101/WiFiNINA Firmware Updater from the TOOLS menu.
A new panel will open up and this is where you actually start the update process.
Ensure you can see your board and select it in that new panel.
Do a Test Connection to make sure the updater can see and talk to your board.
Now select the correct firmware as indicated by Sandeep.
Hit the Update Firmware button and wait for it to complete.
It might be better if you are on a USB 2.0 port and have any security turned off for the process but I did not need to. and my ports are all USB 2.0 anyway.
Yes, I know all this and it is spelled out quite well in the instructions. I can also differentiate between different library examples. Here is my analogous output.
Set binary mode
readWord(addr=0)=0x20007ffc
readWord(addr=0xe000ed00)=0x410cc601
readWord(addr=0x41002018)=0x10010305
version()=v2.0 [Arduino:XYZ] Mar 19 2018 09:45:14
chipId=0x10010005
Connected at 921600 baud
write(addr=0x20004000,size=0x34)
writeWord(addr=0x20004030,value=0x10)
writeWord(addr=0x20004020,value=0x20008000)
Chip ID : 10010005
Address : 8192
Pages : 3968
Total Size : 248KB
Planes : 1
Lock Regions : 16
Locked : readWord(addr=0x41004020)=0xffff
none
readWord(addr=0x41004018)=0
Security : false
Boot Flash : true
readWord(addr=0x40000834)=0
BOD : false
BOR : false
Erase flash
chipErase(addr=0x2000)
done in 0.611 seconds
write(addr=0x20005000,size=0x1000)
writeBuffer(scr_addr=0x20005000, dst_addr=0x2000, size=0x1000)
[========= ] 30% (64/209 pages)write(addr=0x20005000,size=0x1000)
writeBuffer(scr_addr=0x20005000, dst_addr=0x3000, size=0x1000)
[================== ] 61% (128/209 pages)write(addr=0x20005000,size=0x1000)
writeBuffer(scr_addr=0x20005000, dst_addr=0x4000, size=0x1000)
[=========================== ] 91% (192/209 pages)write(addr=0x20005000,size=0x440)
writeBuffer(scr_addr=0x20005000, dst_addr=0x5000, size=0x440)
done in 0.078 seconds
checksumBuffer(start_addr=0x2000, size=0x1000) = eca4
checksumBuffer(start_addr=0x3000, size=0x1000) = 58ac
checksumBuffer(start_addr=0x4000, size=0x1000) = ec41
checksumBuffer(start_addr=0x5000, size=0x420) = dd3a
Verify successful
done in 0.013 seconds
CPU reset.
writeWord(addr=0xe000ed0c,value=0x5fa0004)
Now, I only see ONE option on the tools menu (see pic) - are you saying that you see more than one?.
