As my first arduino project I am building a climate-controlled cage for my pet dinosaur. I am totally new to this and would like it if someone could make sure sure that my plans will work before I try to buy anything!
I have soldered my Bare Bones Board together and gotten the Blink sketch to work.
I need to control temperature (90F - 95F daytime, >78F nighttime) and humidity (65%-75%). I also need to turn the light on/off every 12 hours.
My plan is to place the BBB near the basking spot, in such a way that it is covered and the iguana is unable to obscure line-of-sight with the heating element (and so that he is unable to mess with it at all).
I plan to power my BBB with a wall power adapter ($10) and use a SHT15 ($29) to test the temperature and humidity.
To display the current temperature, humidity, and time I will include a 2x16 LCD display ($11). To change the time and month (to simulate seasonal changes) I will use three push buttons.
To turn my light and heat on and off I will use two relays (2x $9) (note: I am on US power, that is an Italian company, and have zero experience).
To increase the humidity.. I'm not certain what I will do. I have a spray bottle (similar design as this) and thought about using a motor to drive the plunger down but am afraid that even if I could figure out a way to rig it, there would be too much resistance. Any ideas?
Is there a way to add back-up battery power? I am cautious of power outages resetting my cage's cycle inopportunely.
Do I have enough pins to run all of this? The LCD is 7 pins, and I presume 1 per button, relay, and motor... by my count that is 13, and the BBB has "20 general purpose I/O pins".
Thank you in advance, and of course any general advice you could offer a cost-conscious newcomer would be greatly appreciated!
