[Fixed ?] Arduino Uno "recipe.preproc.macros" error
Arduino specs :
BN: Arduino Uno
VID: 0x2341
PID: 0x0043
SN: 85735313932351519081
Code was provided by the official guide and correctly written. No error on this side.
I think it is on the IDE side but I'm not sure.
When I check or televerse it shows this error :
recipe.preproc.macros est un schéma manquant
Erreur de compilation pour la carte Arduino Uno
Which is the same as :
recipe.preproc.macros pattern is missing
Error compiling for board Arduino Uno
I'm on the 4th project if anyone needs to know.
Blink doesn't work, already uninstalled and reinstalled the Arduino IDE.
I installed the Windows 10 version from Microsoft Store and it looks like it works for now... :shrug: ?
Please do this:
  • (In the Arduino IDE) click File > Preferences
  • Check the box next to "Show verbose output during: > compilation
  • Click "OK"
  • Sketch > Verify/Compile
  • After the compilation fails you'll see a button on the right side of the orange bar "Copy error messages". Click that button.
  • In a forum reply here, click on the reply field.
  • Click the </> button on the forum toolbar. This will add the forum's code tags markup to your reply.
  • Press "Ctrl + V". This will paste the compilation output between the code tags.
  • Move the cursor outside of the code tags before you add any additional text to your reply.
If the length of the output exceeds the forum's 9000 character limit, save it in a .txt file and post it here as an attachment. If you click the "Reply" button you'll see the "Attachments and other options" link.
Weird, usually the app store version is the one that doesn't work.
The error implies that the board package (specifically it's platform.txt) is corrupt somehow, or that something is interfering with access to it in a way that doesn't produce an access denied message. I can't think of any way that either of those things could happen, though. (the above instructions would have shed at least some light on the matter, though).
