Flashing a Atmega 328PB: Mismatched Bytes
I have been trying to flash my Atmega328PB today.
I am using an off-brand Arduino Uno (the AZ-Delivery one, since real ones are hard to get) as my ISP. I have connected the UNOs pins 10-13 to the Atmegas PB3-5 and PC6. I have also connected VCC and AVCC to +5V and GND to GND. I have an external 16MHz Crystal with two 22pF Capacitors.
I have uploaded the Arduino as ISP sketch on the Uno and am now trying to burn the Bootloader on the Atmega, using this MiniCore Board.
I've changed the Variant to 328PB and tried both the UART0 and 1 Bootloader option.
However I get this Error Code when I try to burn the boot loader:
avrdude: verification error, first mismatch at byte 0x7e00
         0x00 != 0x01
avrdude: verification error; content mismatch
avrdude done.  Thank you.
What can I do to change this? Or even before that: What causes this issue? I've tried searching for it, but sadly most Information is only on the 328P Variant.
Full Console Log:
avrdude: Version 6.3-20201216
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "/Users/user/Library/Arduino15/packages/MiniCore/hardware/avr/2.1.3/avrdude.conf"
         User configuration file is "/Users/user/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : /dev/cu.usbserial-1440
         Using Programmer              : stk500v1
         Overriding Baud Rate          : 19200
         AVR Part                      : ATmega328PB
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
         Programmer Type : STK500
         Description     : Atmel STK500 Version 1.x firmware
         Hardware Version: 2
         Firmware Version: 1.18
         Topcard         : Unknown
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0x1e9516 (probably m328pb)
avrdude: erasing chip
avrdude: reading input file "0x3f"
avrdude: writing lock (1 bytes):
Writing | ################################################## | 100% 0.01s
avrdude: 1 bytes of lock written
avrdude: verifying lock memory against 0x3f:
avrdude: load data lock data from input file 0x3f:
avrdude: input file 0x3f contains 1 bytes
avrdude: reading on-chip lock data:
Reading | ################################################## | 100% 0.01s
avrdude: verifying ...
avrdude: 1 bytes of lock verified
avrdude: reading input file "0b11110101"
avrdude: writing efuse (1 bytes):
avrdude: 1 bytes of efuse written
avrdude: verifying efuse memory against 0b11110101:
avrdude: load data efuse data from input file 0b11110101:
avrdude: input file 0b11110101 contains 1 bytes
avrdude: reading on-chip efuse data:
avrdude: 1 bytes of efuse verified
avrdude: reading input file "0b11010110"
avrdude: writing hfuse (1 bytes):
avrdude: 1 bytes of hfuse written
avrdude: verifying hfuse memory against 0b11010110:
avrdude: load data hfuse data from input file 0b11010110:
avrdude: input file 0b11010110 contains 1 bytes
avrdude: reading on-chip hfuse data:
avrdude: 1 bytes of hfuse verified
avrdude: reading input file "0b11111111"
avrdude: writing lfuse (1 bytes):
Writing | "/Users/user/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino18/bin/avrdude" "-C/Users/user/Library/Arduino15/packages/MiniCore/hardware/avr/2.1.3/avrdude.conf" -v -patmega328pb -cstk500v1 -P/dev/cu.usbserial-1440 -b19200 "-Uflash:w:/Users/user/Library/Arduino15/packages/MiniCore/hardware/avr/2.1.3/bootloaders/optiboot_flash/bootloaders/atmega328pb/16000000L/optiboot_flash_atmega328pb_UART0_115200_16000000L_B5.hex:i" -Ulock:w:0x0f:m
avrdude: 1 bytes of lfuse written
avrdude: verifying lfuse memory against 0b11111111:
avrdude: load data lfuse data from input file 0b11111111:
avrdude: input file 0b11111111 contains 1 bytes
avrdude: reading on-chip lfuse data:
avrdude: 1 bytes of lfuse verified
         PAGEL                         : PD7
         BS2                           : PC2
         RETRY pulse                   : SCK
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
         Hardware Version: 2
         Topcard         : Unknown
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: NOTE: "flash" memory has been specified, an erase cycle will be performed
         To disable this feature, specify the -D option.
avrdude: reading input file "/Users/user/Library/Arduino15/packages/MiniCore/hardware/avr/2.1.3/bootloaders/optiboot_flash/bootloaders/atmega328pb/16000000L/optiboot_flash_atmega328pb_UART0_115200_16000000L_B5.hex"
avrdude: writing flash (32768 bytes):
Writing | ################################################## | 100% 0.00s
avrdude: 32768 bytes of flash written
avrdude: verifying flash memory against /Users/user/Library/Arduino15/packages/MiniCore/hardware/avr/2.1.3/bootloaders/optiboot_flash/bootloaders/atmega328pb/16000000L/optiboot_flash_atmega328pb_UART0_115200_16000000L_B5.hex:
avrdude: load data flash data from input file /Users/user/Library/Arduino15/packages/MiniCore/hardware/avr/2.1.3/bootloaders/optiboot_flash/bootloaders/atmega328pb/16000000L/optiboot_flash_atmega328pb_UART0_115200_16000000L_B5.hex:
avrdude: input file /Users/user/Library/Arduino15/packages/MiniCore/hardware/avr/2.1.3/bootloaders/optiboot_flash/bootloaders/atmega328pb/16000000L/optiboot_flash_atmega328pb_UART0_115200_16000000L_B5.hex contains 32768 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 0.00s
         0x00 != 0x01
Failed to burn bootloader: uploading error: exit status 1
Decoupling capacitor is missing. Depending on the power source additional capacitors may be needed.
To let it run, you have to pull RESET HIGH.
I guess you tried that several times. Was the mismatch always at the exact same address?
