Hi all,
I'm making a wireless timing display for model car racing. It uses 4 7-segment digits, driven by 4 daisy-chained TPIC6B595 shift registers. I've used multiplexing (switching only one digit on in turn so that the duty cycle is 25%) which dims the display down quite nicely - before this the brightness was rather hard on the eyes!
Anyway, I'm getting a faint flickering when feeding it information over nRF24L01+. Note that the flickering is not there if I don't multiplex.
Anyway, here's the code:
Transmitter:
RC Information Board Project
This project reads in RC car race information output from RC-Timing by Dale Burr
(race information such as heat number, round number, time elapsed etc) and also
gantry/start lights information.
Race information is read in via the normal Arduino serial port (USB on an Uno
or pins 0 and 1 on an Uno or Atmega 328P-Pu IC) whilst gantry/start lights
information is read in via 2 Arduino pins after having been converted from RS232
by a MAX232 or similar.
The Arduino then processes the information and transforms it into 7 seperate
integer variables which are then joined using the sprintf function and
transmitted using the TMRh20 nRF24L01+ library from a 2.4GHz nRF24L01+ transceiver
connected to the Arduino
For more information on this project, visit:
https://rcinfoboard.wordpress.com/
Created by Joe Keaveney
April 2016
#include <SoftwareSerial.h>
#include <SPI.h> // Comes with Arduino IDE
#include <RF24.h> // Download and Install (See above)
#include <nRF24L01.h>
RF24 myRadio (7, 8);
byte addresses[6] = {"1Node"};
SoftwareSerial mySerial(5, 6);
char tx_array[63]; // The array of variables that is transmitted
char *rnum; // round number character
char *hnum; // heat number character
char *mnum; // etc
char *snum; // etc
int lstate = 0; // start/gantry lights state integer
int r_int; // round number integer
int h_int; // etc
int m_int; // etc
int s_int; // etc
int timeone; //integer that represents the first number of a 4-digit display
int timetwo; // second number
int timethree; // third number
int timefour; // fourth number
const int dtrPin = 2; // DTR input pin from MAX232/USB
const int rtsPin = 3; // RTS input pin from MAX232/USB
int dtrState = 0; // stores the state of DTR pin when read
int rtsState = 0; // stores the state of RTS pin when read
const byte numChars = 64;
char receivedChars[numChars];
char rideChars[numChars];
boolean stringComplete = false; // whether the string is complete
void setup() { // setup Arduino in it's initial state & start services
pinMode(dtrPin, INPUT); // set input pins for reading RS232 pin states
pinMode(rtsPin, INPUT);
Serial.begin(9600); // initialize serial so we can read in race information
mySerial.begin(9600);
myRadio.begin();
myRadio.setChannel(108);
myRadio.setPALevel(RF24_PA_MAX);
myRadio.setDataRate(RF24_250KBPS);
myRadio.openWritingPipe(addresses[0]);
delay(50);
dtrState = digitalRead(dtrPin); // read the state of the DTR and RTS inputs
rtsState = digitalRead(rtsPin);
if (dtrState == LOW && rtsState == LOW) {
// DTR HIGH and RTS HIGH mean Green Light On
lstate = 2;
} else if (dtrState == LOW && rtsState == HIGH) {
// DTR HIGH and RTS LOW means Red Light On
lstate = 1;
else {
// Any other combination means both lights Off
lstate = 0;
if (stringComplete) {
mySerial.println(rideChars);
rnum = strtok_r(receivedChars,":",&i); // start breaking down the input info
hnum = strtok_r(NULL,":",&i); // from RC-Timing into the data we need
mnum = strtok_r(NULL,":",&i);
snum = strtok_r(NULL,":",&i);
r_int = atoi(rnum); // convert the info into integers
h_int = atoi(hnum);
m_int = atoi(mnum);
s_int = atoi(snum);
if (m_int <= 9) { // break the time info into two integers for use on a
timeone = 0; // 4-digit display
timetwo = m_int;
else {
timeone = m_int / 10;
timetwo = m_int % 10;
if (s_int <= 9) {
timethree = 0;
timefour = s_int;
else {
timethree = s_int / 10;
timefour = s_int % 10;
// the sprintf function consolidates all the integer variables together
// and then myRadio.write sends out the tx_array variable via the 2.4Ghz transceiver
sprintf(tx_array, "%d,%d,%d,%d,%d,%d,%d.",lstate,r_int,h_int,timeone,timetwo,timethree,timefour);
myRadio.write(&tx_array, sizeof(tx_array));
SerialEvent runs between each iteration of the loop() function and
checks for data on the serial buffer
void serialEvent(){
static boolean recvInProgress = false;
static byte ndx = 0;
char startMarker = '[';
char endMarker = ']';
char rc;
while (Serial.available() > 0 && stringComplete == false) {
rc = Serial.read();
if (recvInProgress == true) {
if (rc != endMarker) {
receivedChars[ndx] = rc;
rideChars[(ndx + 1)] = rc;
ndx++;
if (ndx >= numChars) {
ndx = numChars - 1;
else {
receivedChars[ndx] = '\0'; // terminate the string
rideChars[(ndx + 2)] = '\0';
ndx = 0;
stringComplete = true;
else if (rc == startMarker) {
recvInProgress = true;
rideChars[ndx] = rc;
Receiver (Display) code in next post as there's a character limit in the forum.
Hoping you guys may have a few pointers.
