instead of getting 2 values, the order is changed as shown in pic, i am using parseFloat() here, i want to save the float values into a variable with array, how do i do it so that those two values are alone saved in the array?? sometimes 2 values come, sometimes 3 values come,
the first is humidity and the other is temperature.
P.S baud rate is 9600 b/w nodemcu to arduino
parse code
while (NodeSerial.available() > 0)
float val = NodeSerial.parseFloat();
//Data.concat(val);
if (NodeSerial.read() == '\n');
//delay(1000);
#include <ESP8266WiFi.h>
#include <WiFiClient.h>
#include <ThingSpeak.h>
#include <SoftwareSerial.h>
SoftwareSerial NodeSerial(D2, D3); // RX | TX
const char* ssid = "Jerald";
const char* password = "9443110000";
WiFiClient client;
unsigned long myChannelNumber = 441486;
const char * myWriteAPIKey = "5QEPJGGHNVKRGPR6";
uint8_t temperature, humidity;
NodeSerial.begin(9600);
delay(10);
// Connect to WiFi network
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
while (WiFi.status() != WL_CONNECTED)
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
// Print the IP address
ThingSpeak.begin(client);
static boolean data_state = false;
float val1[3]; //char character;
//Data.concat(val);
Serial.println(val);
// Write to ThingSpeak. There are up to 8 fields in a channel, allowing you to store up to 8 different
// pieces of information in a channel. Here, we write to field 1.
if( data_state )
ThingSpeak.writeField(myChannelNumber, 1, temperature, myWriteAPIKey);
data_state = false;
ThingSpeak.writeField(myChannelNumber, 2, humidity, myWriteAPIKey);
data_state = true;
//delay(30000); // ThingSpeak will only accept updates every 15 seconds.
/*NodeSerial.print(10);
NodeSerial.print("\n");
delay(100);*/
arduino send code
#include <dht.h>
#define dht_apin 7
dht DHT;
float temp;
float hum;
SoftwareSerial ArduinoSerial(3, 2); // RX | TX
pinMode(3, INPUT);
pinMode(2, OUTPUT);
ArduinoSerial.begin(9600);
delay(500);//Delay to let system boot
Serial.println("DHT11 Humidity & temperature Sensor\n\n");
delay(1000);//Wait before accessing Sensor
//delay(2000); //sensor boot-up delay
//Read data and store it to variables hum and temp
DHT.read11(dht_apin);
hum = DHT.humidity;
temp = DHT.temperature;
ArduinoSerial.print("Current humidity = ");
ArduinoSerial.print(hum);
ArduinoSerial.print("% ");
Serial.print(DHT.humidity);
ArduinoSerial.print("temperature = ");
ArduinoSerial.print(temp);
ArduinoSerial.println("C ");
Serial.print(DHT.temperature);
ArduinoSerial.print("\n");
It is a waste of time printing the text as you do not use it on the receiving side but it would be a good idea to format the data better so that receiving and parsing it was easier.
You have no delays in the sending loop and " delay(1000);" in the receiving loop. I suspect your inout buffer is overflowing. Try putting the delay in the sending and NOT in the receiving. The "parseFloat()" will wait for the float to arrive.
johnwasser:
thanks much, its working now thanks all guys all your help is implemented
all are working except the below error i want the parsed data to enter the array, but this error happens
char array1[2] = {'0','0'};
delay(1000); // receive delay working as expected
float val = NodeSerial.parseInt();
for(j = 0; j < 2; j++) //// here i get error 'j' was not used in this scope
array1[j] = val;
Serial.println(array1);
omg, yes thanks, another issue is, according my loop code 1st loop gets temperature 2nd loop gets humidity and recurs i need to store temp and humidity in 2 different array(array1[0],array1[1]), how's that possible
current code
for (int i=0; i < 2 ; i++)
array1[i] = val;
Serial.println(array1[0]);
Serial.println(array1[1]);
