Float to uint8_t
I have two variables
uint8_t charData[6];
float Fahrenheit = 0;
I need to convert the float value to an uint8_t type. The float value comes from a temp sensor, DS18B20, for example, 74.53
sensors.requestTemperatures();
Celcius = sensors.getTempCByIndex(0);
Fahrenheit = sensors.toFahrenheit(Celcius);
Elsewhere in the code, to convert the float value to uint8_t, among many other things I tried:
dtostrf(Fahrenheit, 0, 5, charData);
also:
String sensorData = String(Fahrenheit);
sensorData.toCharArray(charData, sensorData.length() + 1);
One may think that doing this should be very simple, but I have not been able to figure it out. Can anyone help, please?
What you expect the value 74.53 to be assuming that you manage to convert it into a byte ?
I am sorry, I don't understand the question. However, what I am trying to do is to send the value to the Adafruit IO platform. I included Adafruit's Adafruit_MQTT and Adafruit_MQTT_Client libraries.
I did the setup following the sample code:
Adafruit_MQTT_Client mqtt(&client, AIO_SERVER, AIO_SERVERPORT, AIO_USERNAME, AIO_KEY);
Adafruit_MQTT_Publish publishData = Adafruit_MQTT_Publish(&mqtt, AIO_USERNAME "/feeds/myFirstValue");
and later in the code I am trying to publish the value:
if (! publishData.publish(charData)) {
  Serial.println(F("Failed"));
  Serial.println(F("OK"));
I hope my explanation makes sense.
Thank you,
a uint8_t is a byte - a single value between 0 and 255.
It sounds like you are trying to convert it to a c string (array of characters) - which is an array of characters (int8_t).
This all suggests that there is some confusion on your part about what you have to do. What makes you think it should be a uint8_t? Is there some error message that is suggesting that, or what? A quick look at that library shows that there is no publish() method that takes a uint8_t array like you are attempting to pass it (though you haven't told us what version you are using - popular libraries often have many versions on various peoples' github with significant differences, so you need to specify where you got it from). In fact, the version I am looking at has a publish() method that takes a floating point number....
union data structure could be used to convert a float number into 32-bit (4-byte) binary32/IEEE-754 formatted data and vice versa. For example:
union
    float Fahrenheit;
    uint8_t myData[4];     //low order member holds low order byte (little endianness)
}myTemp;
myTemp.Fahrenheit = 74.53;
carlos14:
Just for starts; code tags are for code, not the whole post.
Your variables tell me you want convert float to text as uint8_t (also named byte). Why not type char, int8_t, since C libraries functions use type char for strings?
Since you know the max temperature will be less than 1000,
char number[ 10 ]; // float may be 7 places plus decimal point plus sign if negative and terminating zero.
But really the only time you convert variable to text is to print to screen or file.
You don't -need- the string at all, it is a waste of RAM since there are numeric ways to pull sign and each digit out of that float.
I'd start by loading 100 x Farenheit into a long which rounds off past 2 places and ends slow sand-and-dirt floating point math.
*//  untested, never compiled but the logic is old hat to me
long X, tmp;
// --- and inside of a printTemperature function
X = (long)( Farenheit * 100.0);
if ( X < 0 )
  Serial.write( '-' );
  X = -X;
if ( X >= 10000 )  // 100F in 100ths of 1F
  tmp = X / 10000;
  Serial.print( tmp );
  X -= tmp * 10000;
if ( X >= 1000 )  // 10F in 100ths of 1F
  tmp = X / 1000;
  X -= tmp * 1000;
if ( X >= 100 )  // 1F in 100ths of 1F
  tmp = X / 100;
  X -= tmp * 100;
  Serial.write( '0' );
Serial.write( '.' );
if ( X >= 10 )  // 0.1F in 100ths of 1F
  tmp = X / 10;
  X -= tmp * 10;
if ( X >= 1 )  // 0.01F in 100ths of 1F
  tmp = X / 10;
  X -= tmp * 10;
It could be shortened with a little trouble but it adds a lot less to the code size than sprintf() and uses very little RAM.
It might even run quicker... there's a fast divide by 10 routine in the Arduino Playground that'd make that pretty certain.
As @DrAzzy suggested, I am trying to convert from float to int8_t. As you may have noticed, I am not very proficient in C or C++. I still don't know how to do the conversion.
Thank you @GoForSmoke for the clarification about code tags.
Thank you everybody else for your comments.
here is a snippet that I use to break down a 32 bit number into 4 bytes (unit8_t)
 rx_frame.data.u8[0] = *item & 0xFF;
          rx_frame.data.u8[1] = (*item >> 8) & 0xFF;
          rx_frame.data.u8[2] = (*item >> 16) & 0xFF;
          rx_frame.data.u8[3] = (*item >> 24) & 0xFF;
Let's try to find out what you really want to do
Given a float, say 1234.56, what do you expect it to look like when converted to uint8_t and how many bytes will be required to hold the result ?
