How to convert uin8_t data type to float?
Hi kindly guide me How to convert uin8_t data type to float ?
uint8_t a = 20;
float b =a;
this method is not working kindly me about it
Your method should work...
What makes you think it does not work?
what's not working?
why do you think you need to explicitly cast it to float? float can hold uint8_t easily
was a mistake. post deleted.
its not working showing wrong values
i am using sensor which gives precise value in float becoz i need to fetch data in ponters and array
uint8_t a = 20;
float b =a;
Oh look you can copy paste your own posts! Cool, good luck with your thread
If the sensor already gives you the value as a float, what is the requirement for converting a value into a float?
sensor just gives the hexa values
Hello AliGul1234567890
Post your sketch, well formated, with comments and in so called code tags "</>" and a none-Fritzing schematic to see how we can help.
