Flow meter Keg
I seen a lot of old post on this but nothing recent. I was thinking about using a Liquid Flow Meter from adafruit for my kegerator to measure how much beer is left in the keg. I would be using an LCD, breadboard and also a Arduino Uno R3 to put this together.
I will modify the Adafruit liquid flow meters sample code.
This is example code for using the Adafruit liquid flow meters.
Tested and works great with the Adafruit plastic and brass meters
    ------> http://www.adafruit.com/products/828
    ------> http://www.adafruit.com/products/833
Connect the red wire to +5V,
the black wire to common ground
and the yellow sensor wire to pin #2
Adafruit invests time and resources providing this open source code,
please support Adafruit and open-source hardware by purchasing
products from Adafruit!
Written by Limor Fried/Ladyada  for Adafruit Industries.
BSD license, check license.txt for more information
All text above must be included in any redistribution
#include "LiquidCrystal.h"
LiquidCrystal lcd(7, 8, 9, 10, 11, 12);
// which pin to use for reading the sensor? can use any pin!
#define FLOWSENSORPIN 2
// count how many pulses!
volatile uint16_t pulses = 0;
// track the state of the pulse pin
volatile uint8_t lastflowpinstate;
// you can try to keep time of how long it is between pulses
volatile uint32_t lastflowratetimer = 0;
// and use that to calculate a flow rate
volatile float flowrate;
// Interrupt is called once a millisecond, looks for any pulses from the sensor!
SIGNAL(TIMER0_COMPA_vect) {
  uint8_t x = digitalRead(FLOWSENSORPIN);
  if (x == lastflowpinstate) {
    lastflowratetimer++;
    return; // nothing changed!
  if (x == HIGH) {
    //low to high transition!
    pulses++;
  lastflowpinstate = x;
  flowrate = 1000.0;
  flowrate /= lastflowratetimer;  // in hertz
void useInterrupt(boolean v) {
  if (v) {
    // Timer0 is already used for millis() - we'll just interrupt somewhere
    // in the middle and call the "Compare A" function above
    OCR0A = 0xAF;
    TIMSK0 |= _BV(OCIE0A);
    // do not call the interrupt function COMPA anymore
    TIMSK0 &= ~_BV(OCIE0A);
   Serial.print("Flow sensor test!");
   lcd.begin(16, 2);
   pinMode(FLOWSENSORPIN, INPUT);
   digitalWrite(FLOWSENSORPIN, HIGH);
   lastflowpinstate = digitalRead(FLOWSENSORPIN);
   useInterrupt(true);
void loop()                     // run over and over again
  lcd.setCursor(0, 0);
  lcd.print("Pulses:"); lcd.print(pulses, DEC);
  lcd.print(" Hz:");
  lcd.print(flowrate);
  //lcd.print(flowrate);
  Serial.print("Freq: "); Serial.println(flowrate);
  Serial.print("Pulses: "); Serial.println(pulses, DEC);
  // if a plastic sensor use the following calculation
  // Sensor Frequency (Hz) = 7.5 * Q (Liters/min)
  // Liters = Q * time elapsed (seconds) / 60 (seconds/minute)
  // Liters = (Frequency (Pulses/second) / 7.5) * time elapsed (seconds) / 60
  // Liters = Pulses / (7.5 * 60)
  float liters = pulses;
  liters /= 7.5;
  liters /= 60.0;
  // if a brass sensor use the following calculation
  liters /= 8.1;
  liters -= 6;
  liters /= 60.0;
  Serial.print(liters); Serial.println(" Liters");
  lcd.setCursor(0, 1);
  lcd.print(liters); lcd.print(" Liters        ");
  delay(100);
What do you guys think about this idea? Will this work?
My concern is that what is flowing through the meter in this case won't
always be a consistent liquid.
i.e. what happens when foam or gas flows through the meter?
Foam should not be forming in the line. The co2 pushes the beer through the line. Should be a solid flow of beer. Should not be gas pockets.
