I am attempting to read a flow meter from a nodemcu. I got the code to work with a nano but when I attempt to upload to a nodemcu I am not getting any measurements. I have the power attached to Vin, ground to ground and the data wire to D2. In the serial monitor it just repeats "Flow rate: 0.0L/min Current Liquid Flowing: 0mL/Sec Output Liquid Quantity: 0mL
Here is the code
Liquid flow rate sensor -DIYhacking.com Arvind Sanjeev
Measure the liquid/water flow rate using this code.
Connect Vcc and Gnd of sensor to arduino, and the
signal line to arduino digital pin 2.
byte statusLed = 13;
byte sensorInterrupt = 0; // 0 = digital pin 2
byte sensorPin = 4;
// The hall-effect flow sensor outputs approximately 4.5 pulses per second per
// litre/minute of flow.
float calibrationFactor = 4.5;
volatile byte pulseCount;
float flowRate;
unsigned int flowMilliLitres;
unsigned long totalMilliLitres;
unsigned long oldTime;
// Initialize a serial connection for reporting values to the host
// Set up the status LED line as an output
pinMode(statusLed, OUTPUT);
digitalWrite(statusLed, HIGH); // We have an active-low LED attached
pinMode(sensorPin, INPUT);
digitalWrite(sensorPin, HIGH);
pulseCount = 0;
flowRate = 0.0;
flowMilliLitres = 0;
totalMilliLitres = 0;
oldTime = 0;
// The Hall-effect sensor is connected to pin 2 which uses interrupt 0.
// Configured to trigger on a FALLING state change (transition from HIGH
// state to LOW state)
attachInterrupt(sensorInterrupt, pulseCounter, FALLING);
* Main program loop
if((millis() - oldTime) > 1000) // Only process counters once per second
// Disable the interrupt while calculating flow rate and sending the value to
// the host
detachInterrupt(sensorInterrupt);
// Because this loop may not complete in exactly 1 second intervals we calculate
// the number of milliseconds that have passed since the last execution and use
// that to scale the output. We also apply the calibrationFactor to scale the output
// based on the number of pulses per second per units of measure (litres/minute in
// this case) coming from the sensor.
flowRate = ((1000.0 / (millis() - oldTime)) * pulseCount) / calibrationFactor;
// Note the time this processing pass was executed. Note that because we've
// disabled interrupts the millis() function won't actually be incrementing right
// at this point, but it will still return the value it was set to just before
// interrupts went away.
oldTime = millis();
// Divide the flow rate in litres/minute by 60 to determine how many litres have
// passed through the sensor in this 1 second interval, then multiply by 1000 to
// convert to millilitres.
flowMilliLitres = (flowRate / 60) * 1000;
// Add the millilitres passed in this second to the cumulative total
totalMilliLitres += flowMilliLitres;
unsigned int frac;
// Print the flow rate for this second in litres / minute
Serial.print("Flow rate: ");
Serial.print(int(flowRate)); // Print the integer part of the variable
Serial.print("."); // Print the decimal point
// Determine the fractional part. The 10 multiplier gives us 1 decimal place.
frac = (flowRate - int(flowRate)) * 10;
Serial.print(frac, DEC) ; // Print the fractional part of the variable
Serial.print("L/min");
// Print the number of litres flowed in this second
Serial.print(" Current Liquid Flowing: "); // Output separator
Serial.print(flowMilliLitres);
Serial.print("mL/Sec");
// Print the cumulative total of litres flowed since starting
Serial.print(" Output Liquid Quantity: "); // Output separator
Serial.print(totalMilliLitres);
Serial.println("mL");
// Reset the pulse counter so we can start incrementing again
pulseCount = 0;
// Enable the interrupt again now that we've finished sending output
Insterrupt Service Routine
void pulseCounter()
// Increment the pulse counter
pulseCount++;
Interrupts on NodeMCU work different from interrupts on Arduino (no pin change interrupts; all pins have their own interrupt).
When you set the IDE to compile for NodeMCU you can use D2 as pin designator. There is no obvious relationship between the D numbering as chosen by the NodeMCU developer and the actual GPIO numbers of the ESP8266 processor.
D2 is indeed GPIO4.
D3 is GPIO0, which is also used in the boot process (it may have a fixed pull-up resistor in place for that).
wvmarle:
D2 is indeed GPIO4.
Thank you, so how would I alter the code to reflect the differences in interrupts?
wvmarle:
You'll have to check the ESP8266 documentation.
The ISR will remain the same but setting interrupts is different. I forgot how it goes exactly.
OK so if each pin has access to the interrupt I decided to try and make the interrupt variable the same as the data pin and it solved the issue. I did also change the physical pin I was using and reflected that in the code. Here is the basic example that works with the nodemcu:
WIRING:
Sensor red wire -----> Vin
Sensor black wire -----> Grnd
Sensor yellow wire (data) -----> D4
byte sensorInterrupt = D4;
byte sensorPin = D4;
float flowRate;
pulseCount = 0;
flowRate = 0.0;
oldTime = 0;
* Main program loop
// the host
oldTime = millis();
unsigned int frac;
pulseCount = 0;
void pulseCounter()
pulseCount++;
For 4.5 pulses per second you don't need an interrupt. Polling should be plenty fast enough.
Also you detach your interrupt for quite a long time as you're sending out your data. There is a risk of losing pulses during that time. You best detach the interrupt, copy the value, and reattach it.
That at least would be the regular Arduino approach (well, you'd use noInterrupts() and interrupts() instead of detaching and attaching the interrupt) for values that are larger than 1 byte so you can't get an interrupt while the value is being copied, but I don't know if this is also necessary for an ESP8266 as it's a 32-bit processor, so a single register is 32 bits rather than 8 bits on the AVR processors.
