Hello everybody,
A few weeks ago I started making a quadcopter. I've got all the pieces that I need, that is not a problem. The main problem that I'm actually facing is that when I use pulseIn function (to read values from my Rx) and send them to my motors, values are fluctuating .
My code is (for now) quite simple:
SETUP:
I attatch my 4 servos (they are callibrated)
LOOP:
I read the value from my Rx (pulseIn)
I restrict it to a specific domain (1050-1900)
I write them to my 4 ESCs (using servo.writeMicroseconds())
#include <Servo.h>
//connection to the ESCs' pins
#define PIN_ESC_ARG 10
#define PIN_ESC_ARD 11
#define PIN_ESC_AVD 9
#define PIN_ESC_AVG 6
//connection to the Rx
#define THROTTLE_PIN A0
//declaration des differents esc
Servo ESC_ARG; //Back-left
Servo ESC_ARD; //Back-Right
Servo ESC_AVD; //Front-Right
Servo ESC_AVG; //Front-Left
int time_high;
pinMode(THROTTLE_PIN,INPUT);
//On lie les servos aux pins corrects et definition des intervalles de temps passé haut
//Linking the Servos to the correct pins and definitions for the time_high interval
ESC_ARG.attach(PIN_ESC_ARG,1060,1895);
ESC_ARD.attach(PIN_ESC_ARD,1060,1895);
ESC_AVD.attach(PIN_ESC_AVD,1060,1895);
ESC_AVG.attach(PIN_ESC_AVG,1060,1895);
//Recuperation du temps passé haut du signal recu (tant que maintenant, juste le THROTTLE)
//getting the time_high of the signal from the Rx (for now, only reading THROTTLE line)
time_high=pulseIn(THROTTLE_PIN,HIGH);
//Forces the time_high to be in interval [1050-1900]
time_high=constrain(time_high,1050,1900);
Serial.println("Time_high: ");
Serial.println(time_high);
ESC_ARG.writeMicroseconds(time_high);
ESC_ARD.writeMicroseconds(time_high);
ESC_AVD.writeMicroseconds(time_high);
ESC_AVG.writeMicroseconds(time_high);
The results in the serial console are:
time_high:
1461
(60ish times)
time_high:
1443
time_high:
1443
time_high:
1444
time_high:
1443
time_high:
1443
time_high:
1432
time_high:
1434
time_high:
1433
time_high:
1433
time_high:
1432
time_high:
1434
time_high:
1440
time_high:
1432
time_high:
1434
time_high:
1434
time_high:
1433
time_high:
1433
time_high:
1435
time_high:
1434
time_high:
1434
time_high:
1433
time_high:
1443
time_high:
1450
time_high:
1442
time_high:
1437
time_high:
1444
time_high:
1445
time_high:
1460 (and back to the beginning, it's always the same ;) )
I should say that I tried to disable interrupts before reading values then re-enabling them, but the motors do not rotate at all. >:(
Here we go, that's all I have got here and so I'm I Calling for some help because even if I can code in C, I'm not that familiar with Arduino and do not know what to do (even after weeks of researches on the subject! )
Thank you for having read and thank you in advance for your help
