Noob in the noob-class here, and I've researched and tried different code for about a week now.
I'm trying to get a I2C 20x4 LCD display (PCF8574T) to display a count up timer using an UNO, in the 00:00:00:00 format, rather than 0:0:0:0. I'm doing a biltong box (drying box) (and will add 12V fan and 12V bulbs later on and some if statements to control them) and need a timer to know how long the meat has been in.
I found code that does what I want it to do, without any issues such as the second counter moving one place to the left, leaving the digit on the right (in the 'one's' place) and doing silly things like displaying 19,29,39,49,59,69,79 etc). Dealing with the problem by using lcd.print(" ") and lcd.clear caused issues such as bad flickering and the digits to disappear.
Only problem with the code is that it doesn't include 'days'. Only hh:mm:ss, so I've adapted it to what I think it should be. Testing it involves waiting at least 24 hours for every test.
So I'm basically just asking if I'm doing over flow from the hours to days right. Sorry for being long-winded.
#include <dht11.h>
#include <Wire.h>
/*-----( Declare objects )-----*/
// set the LCD address to 0x27 for a 20 chars 4 line display
// Set the pins on the I2C chip used for LCD connections:
// addr, en,rw,rs,d4,d5,d6,d7,bl,blpol
LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE); // Set the LCD I2C address
dht11 DHT11;
/*-----( Declare Constants, Pin Numbers )-----*/
#define DHT11PIN 2
void setup() /*----( SETUP: RUNS ONCE )----*/
Serial.begin(9600); //(Remove all 'Serial' commands if not needed)
lcd.begin(20,4); // initialize the lcd for 20 chars 4 lines, turn on backlight
lcd.backlight();
lcd.print("Biltong Box");
}/*--(end setup )---*/
void loop() /*----( LOOP: RUNS CONSTANTLY )----*/
int chk = DHT11.read(DHT11PIN);
Serial.print("Read sensor: ");
switch (chk)
case 0: Serial.println("OK"); break;
case -1: Serial.println("Checksum error"); break;
case -2: Serial.println("Time out error"); break;
default: Serial.println("Unknown error"); break;
//TEMPERATURE
lcd.setCursor(0, 1);
lcd.print((char)223);
lcd.print("C:");
lcd.print((float)DHT11.temperature, 0);
Serial.print("Temperature (oC): ");
Serial.println((float)DHT11.temperature, 2);
lcd.print(" H=");
lcd.print((float)DHT11.humidity, 0);
lcd.print("%");
Serial.print("Humidity (%): ");
Serial.println((float)DHT11.humidity, 2);
Serial.print("Temperature (K): ");
Serial.println(Kelvin(DHT11.temperature), 2);
Serial.print("Dew Point (oC): ");
Serial.println(dewPoint(DHT11.temperature, DHT11.humidity));
Serial.print("Dew PointFast (oC): ");
Serial.println(dewPointFast(DHT11.temperature, DHT11.humidity));
delay(2000);
//TIMER
char *s;
s = TimeToString(millis()/1000);
lcd.setCursor(0,4);
lcd.print(s);
delay(456);
}/* --(end main loop )-- */
/*-----( Declare User-written Functions )-----*/
// t is time in seconds = millis()/1000;
char * TimeToString(unsigned long t)
static char str[12];
long h = t / 3600;
long d = h / 24;
t = t % 3600;
int m = t / 60;
int s = t % 60;
sprintf(str, "%02ld:%02ld:%02d:%02d", d, h, m, s);
return str;
//Celsius to Fahrenheit conversion
double Fahrenheit(double celsius)
return 1.8 * celsius + 32;
//Celsius to Kelvin conversion
double Kelvin(double celsius)
return celsius + 273.15;
// dewPoint function NOAA
// reference: http://wahiduddin.net/calc/density_algorithms.htm
double dewPoint(double celsius, double humidity)
double A0= 373.15/(273.15 + celsius);
double SUM = -7.90298 * (A0-1);
SUM += 5.02808 * log10(A0);
SUM += -1.3816e-7 * (pow(10, (11.344*(1-1/A0)))-1) ;
SUM += 8.1328e-3 * (pow(10,(-3.49149*(A0-1)))-1) ;
SUM += log10(1013.246);
double VP = pow(10, SUM-3) * humidity;
double T = log(VP/0.61078); // temp var
return (241.88 * T) / (17.558-T);
// delta max = 0.6544 wrt dewPoint()
// 5x faster than dewPoint()
// reference: http://en.wikipedia.org/wiki/Dew_point
double dewPointFast(double celsius, double humidity)
double a = 17.271;
double b = 237.7;
double temp = (a * celsius) / (b + celsius) + log(humidity/100);
double Td = (b * temp) / (a - temp);
return Td;
/* ( THE END ) */
The serial.print is just so I can collect data to analyse later.
