I found this brilliant code on the forum which has different kind of buttons, but when i add more buttons it dosen't work properly(as in two three relays turn on/off at the same time) i was wondering if anyone can tell me how to add more buttons for relays, i dont mind using an sd card also if u can just show me how to extract the get request to turn on/off the relays
THanks a lot!
Here's the code
//zoomkat 8-04-12
//simple button GET server code to control servo and arduino pins 5, 6, and 7
//for use with IDE 1.0
//open serial monitor to see what the arduino receives
//use ' instead of " in the html
//address will look like http://192.168.1.102:84 when submited
//for use with W5100 based ethernet shields
///note that the below bug fix may be required
// http://code.google.com/p/arduino/issues/detail?id=605
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
byte ip[] = { 192, 168, 1, 102 }; // ip in lan
byte gateway[] = { 192, 168, 1, 1 }; // internet access via router
byte subnet[] = { 255, 255, 255, 0 }; //subnet mask
EthernetServer server(84); //server port
String readString;
void setup(){
pinMode(5, OUTPUT); //pin selected to control
pinMode(6, OUTPUT); //pin selected to control
pinMode(7, OUTPUT); //pin selected to control
pinMode(8, OUTPUT); //pin selected to control
//start Ethernet
Ethernet.begin(mac, ip, gateway, gateway, subnet);
server.begin();
//enable serial data print
Serial.println("server multi pin button test 1.0"); // so I can keep track of what is loaded
void loop(){
// Create a client connection
if (client) {
while (client.connected()) {
if (client.available()) {
char c = client.read();
//read char by char HTTP request
if (readString.length() < 100) {
//store characters to string
readString += c;
//Serial.print(c);
//if HTTP request has ended
if (c == '\n') {
Serial.println(readString); //print to serial monitor for debuging
client.println("HTTP/1.1 200 OK"); //send new page
client.println("Content-Type: text/html");
client.println();
client.println("<HTML>");
client.println("<HEAD>");
client.println("<TITLE>Arduino GET test page</TITLE>");
client.println("</HEAD>");
client.println("<BODY>");
client.println("<H1>Zoomkat's simple Arduino button</H1>");
// For simple testing, pin 5, 6, 7, and 8 are used in buttons
// DIY buttons
client.println("<a href=/?on2 >ON</a>");
client.println("<a href=/?off3 >OFF</a>");
client.println(" <a href=/?off357 >ALL OFF</a>
// mousedown buttons
client.println("<input type=button value=ON onmousedown=location.href='/?on4'>");
client.println("<input type=button value=OFF onmousedown=location.href='/?off5'>");
client.println(" <input type=button value='ALL OFF' onmousedown=location.href='/?off3579'>
// mousedown radio buttons
client.println("<input type=radio onmousedown=location.href='/?on6'>ON</>");
client.println("<input type=radio onmousedown=location.href='/?off7'>OFF</>");
client.println(" <input type=radio onmousedown=location.href='/?off3579'>ALL OFF</>
// custom buttons
client.print("<input type=submit value=ON style=width:100px;height:45px onClick=location.href='/?on8'>");
client.print("<input type=submit value=OFF style=width:100px;height:45px onClick=location.href='/?off9'>");
client.print(" <input type=submit value='ALL OFF' style=width:100px;height:45px onClick=location.href='/?off3579'>");
client.println("</BODY>");
client.println("</HTML>");
delay(1);
//stopping client
client.stop();
///////////////////// control arduino pin
if(readString.indexOf('2') >0)//checks for 2
digitalWrite(5, HIGH); // set pin 5 high
Serial.println("Led 5 On");
if(readString.indexOf('3') >0)//checks for 3
digitalWrite(5, LOW); // set pin 5 low
Serial.println("Led 5 Off");
if(readString.indexOf('4') >0)//checks for 4
digitalWrite(6, HIGH); // set pin 6 high
Serial.println("Led 6 On");
if(readString.indexOf('5') >0)//checks for 5
digitalWrite(6, LOW); // set pin 6 low
Serial.println("Led 6 Off");
if(readString.indexOf('6') >0)//checks for 6
digitalWrite(7, HIGH); // set pin 7 high
Serial.println("Led 7 On");
if(readString.indexOf('7') >0)//checks for 7
digitalWrite(7, LOW); // set pin 7 low
Serial.println("Led 7 Off");
if(readString.indexOf('8') >0)//checks for 8
digitalWrite(8, HIGH); // set pin 8 high
Serial.println("Led 8 On");
if(readString.indexOf('9') >0)//checks for 9
digitalWrite(8, LOW); // set pin 8 low
Serial.println("Led 8 Off");
//clearing string for next read
readString="";
