Solder suckers... $0.51 @ Amazon, I bought 3...
Doc
Here...http://www.amazon.com/Parts-Express-Solder-Sucker--desoldering/dp/B0002KRAAG/ref=sr_1_1?ie=UTF8&qid=1345777210&sr=8-1&keywords=solder+suckers
and Still $0.51 Ea...
Doc
link?
Get to Amazon and search for solder suckers... It's the first link of about 30 different items...
Doc
You gotta pay for shipping which is like $4.99
These are $0.99 USD Free Shipping from Hong Kong:
but of course, you have to wait.
exactly how do solder suckers work? I've never used them, I've always used solder wick.
Are they one time use? If not, where does the solder go, like how does it not break the thing?
funkyguy4000:
No, you use it repeatedly. The solder is sucked and it is collected as a thin mesh, that crumbles easily. Then you just discard it. But you sort of need 3 hands to use these gadgets.
I prefer the solder wick.
I like solder wick my self and sometimes you need 3 hands to use it as well, the only drawback is the bad stuff is really hard on PCB's and the good stuff is expensive. Personally I like the shield braid from RG316 (teflon RG174) and that wax type rosin flux you can buy at radio shack (Part # 64-022). I strip the Kevlar jacket off and just push toe center conductor out... works great and I usually always have some scrap co-ax.
That having been said a solder sucker is a great tool Especially a Vacuum commercial type.... and Now hot air rework stations are a requirement for really serious techie work anyway.
At $0.51 Ea (Yes I have Prime so shipping is free) because at that price when they become full I can leave all that toxic lead inside of it and discard it properly... and just grab a new one. Amazon Prime is great, second day shipping is free... IMO
Doc
Amazon Prime.
Yes it is fantastic.
I usually gather up free shipping things up to $25 (qualyfing) in order to get free shipping from Amazon.
But, question, Doc, if you are on Prime, do you also get free shipping from Amazon Marketplace purchases?
Yes the partner shipping is usually as fast as prime. I was told that the devices would be here no later than Sept. 9th... and they came in the mail today from a Wednesday order. If I buy from Amazon directly as I did with the solder suckers.When I go to an 'affiliate'store then the store rules are in force...
I never usually do that... the difference in cost (savings?) is eaten up by the shipping charges from the 'Affiliate' store and or the shipping time. My feeling is that the usual small change saved isn't worth giving up the Amazon guarantee.
Doc
Have to ask... why did you buy three of them?
In my experience, both pump solder suckers and solder wicks are effective tools to remove solder. However, there are specific situations where one works better than the other. For example, the suckers will remove solder faster when working on through-hole parts (once the solder around the lead is molten), but when dealing with SMD pads using wicks is the faster method.
Oh and funkyguy4000, all the solder suckers I've used have had at least one way to get the collected solder out of the sucker. It looks like the design Doc linked to in the original post is the type where you can unscrew part of the lower cylinder to remove the old solder.
Buying Three of them... @ $0.51??? Why not? and Free ()for me) shipping too. I covered that reason rather well too I thought... in a previous post.
When one gets full rather than having to deal with the toxic waste...
Just toss the whole thing and get a clean one...
3 are likely going to be all I will ever need as I am retired and no longer doing production electronics... So I bought 3...{Edit, Was 33} kinda like Christmas... real early.
Doc
Docedison:
What, you haven't switched to lead free solder? I only use lead free solder on my personal projects. Sure copper, tin, silver, and flux aren't the healthiest substances, but their are much less toxic in non-vaporeous form than lead in any physical state (of course I still have fans and such to deal with the fumes). The higher melting temperature takes some getting used to, but I'll take that over insanity and the other possible effects of lead-poisoning any day.
Son, I have been using lead based solders for 50 years with no ill effects, I've had my blood checked several times for poisoning for Lead, Mercury and Cadmium among others and has slight levels of lead and mercury... Never toxic and never enough to do more than show up in a mass spectrometer measurement of my blood. Lead isn't nearly as toxic as you might think... for young children it's a REAL Problem a VERY Serious Neurological Issue but for a mature human it isn't much more dangerous than eating fish... (Just don't eat a lot of fish frequently_). I just don't put it or my fingers in my mouth and I wash my hands well after using it. The Dangers are really from landfills more than unit toxicity. The stuff will very slowly become chemically involved usually with a mild acid or a mild base and slowly becomes water soluble where it enters the food-chain and it will cause serious neurological damage to unformed nervous systems... Children both pre and post natal. It isn't as dangerous as it is claimed however it does require respect and some reasonable care in it's handling.. Especially from things like solder suckers as they contain oxides of lead and those are readily soluble, That's why I made the joke about discarding them when full... the dust from that type of device is somewhat more reactive then plain solder. I would be more concerned with the effects of the new family of "Organic" Fluxes... some contain phosphorus and it doesn't take much beyond the right combination of metals and contaminants to make some fairly toxic chemicals... (there are a lot of poisons made from phosphorus) a Fan is a good remedy for that though... or better a soldering hood. BE careful but not fearful of solder... and I HATE that lead free crap, every joint looks to me like a 'cold' solder joint...
IMO...
Edit: 8/26/12 Doc
Doc
I tend to use the jack pump design instead of the bulb. Most of the time braid is still required or at least a steel sewing needle to push the left over solder out of the hole. Some people have excellent luck with the bulb style with the iron attached. I always just end up burning myself with those.
Docedison:
Well I'm glad that you haven't had any issues, and I know there must be millions of people with similar histories working with lead solder that never got lead poisoning in any form. I have used 60/40 solder for over a decade before any real alternatives were available. It's a well established fact that lead solder can be worked with safely if proper precautions are taken.
However, as you mentioned, there should also be concern about what happens after the useful life of a device. That is the real reason I choose not to use lead solder. Even if I don't dispose of anything I've soldered (not a realistic situation), I'm not going to live forever so eventually someone is going to throw it away and then it will most likely end-up in a landfill somewhere. Therefore, if there's no lead in the solder then there is no lead to possibily leech into the surrounding soil and groundwater. I know you stated that the possibilities of that are low, but a non-existent chance is lower still.
As for the new types of flux for lead-free solder, I'll agree that phosphorus has it's own problems. However, as mentioned I always have adequate ventilation. As far as long term enviornmental and health concerns, it's much less of a problem than lead as there are many biologically useful molecules incorporating phosphorus so the potential is high for even harmful compounds to be metabolized into something innocous by microbial activity (which isn't the case for lead). In addition I avoid it whenever feasible; and if for some reason a MSDS for the solder and/or flux is unavailable I just take my money elsewhere.
I'm not making any personal judgements about anyone else if they continue to use lead solder. I was just mentioning why I decided to stop personal use of lead solder and, for me at least, the transition wasn't a significant issue.
The Don Quixote of solder... I am not being negative here but I should think that MY Lifetime contribution to world waste... Wouldn't add a speck to the backside of a fly... compared to ... China in the 1700's... for example. I fully agree in EVERY respect the bans on solder for ANY NATION... But I am not so conceited as to believe for a minute that any contribution to either side of the argument is going to do anything except.. Lip Service... Much better in my way of thinking to conserve your resources for things that really matter. I purchase a pound of solder about every 5 years... and here is an example of why I consider the "Ban" to be a total waste of time for the private, non commercial "Limited" use of solder... In this world there are MANY Stained Glass windows and More being built by the day... What is done for the runoff from the lead used to create those Majestic creations to the Glory of... Were I Sony, Mitsubishi... any of the giant's it would be of some concern, Some Great Concern. However my use of solder, if continued unabated until I died of lead poisoning wouldn't be enough to make any difference whatsoever and it does make a great deal of difference to me, That ersatz stuff crystallizes and breaks where lead based solders don't. I repair equipment today as a hobby and the number one failure on most laptops is bad solder... when you finally get to the hardware level. 2. the whole movement is based on bad science distorted all out of proportion to the real effects... Yeah there is a great deal of money spent on re-mediating the "Solder (Lead)" Problem... Damn shame 10% of that money wasn't spent on dealing with Carbon Pollution... and I would be willing to bet that atmospheric warming is a whole lot more likely to be the cause of your eventual demise... than a case of lead poisoning... for that matter there is about 20% of the lead based solder used to make a color television today... compared to even 20 years ago. I believe in Ecology with ALL my HEART, however I Believe that "Tree Huggers are getting in the way of REAL ECOLOGICAL PROGRESS... Simply by being a nuisance.
There was a man who a Very long time ago, That made one important observation... Fight the Battles you can win... Sun Tzu... The Art of War.
Doc
Let the War Begin...
Docedison:
Well as far as I'm concerned, there are worse people to be compared to.
In any event, I'm not trying to imply that someone is a bad person or attempting to make anyone feel guilty if they don't switch to lead free solder. If I in any way seemed to be doing that earlier in the thread I'm sincerely sorry!
You are quite right that any individual's usage of lead solder is miniscule relative to commercial and industrial scale. However, if I want my contribution to this particular type of waste to be as small as possible, and I find the alternatives workable; why is this a problem for you? I never advocated any bans on lead solder use or do more than bring up the fact that there are lead free solders and that I find them a realistic alternative. Again, if something I intended as a mere suggestion seemed like something more I apologize for not communicating my intentions correctly in my original reply. Yet if that isn't the case, I don't understand how my personal choice to use lead free solder should agitate you in any significant way.
Just for the record, this isn't the only such choice I made. For example, when I started my current job I found a place to live where I could walk regularly to work and other common destinations like the local grocery store. Oh I know that everything I do still doesn't add up to the rest of the world, and it doesn't make me some sort of martyr either! I just want to have a decent life while being as responsible as I realistically can, and if I'm not trying to control anyone else's life what's wrong with that?
