Free offline pinout/wiring/calculator reference (web + Android) — feedback wanted
Hi all — I built an offline reference app for Arduino/ESP32/Pico work, and the pinout section is up as free web pages: Arduino, ESP32 & Raspberry Pi Pico Pinouts | Robot Maker Toolkit
Each board page has every pin with its capabilities and the gotchas (strapping pins, input-only GPIOs, 5V tolerance, PWM/I2C/SPI). All pin/voltage data was cross-checked against manufacturer datasheets and validated against each chip's capability map, because wrong data here damages hardware.
The full app (55+ sensor wiring diagrams, shield maps, copy-ready sketches, and a set of maker calculators, all offline) is on Google Play — free with a small optional unlock: https://play.google.com/store/apps/details?id=com.infinitx.maker.toolkit
I'd really value corrections from this crowd. If you spot a wrong pin, address, or voltage, tell me and I'll fix it fast. Boards/modules you'd want added are welcome too.
Thanks for sharing,
I prefer the graphical pin out diagrams myself but I like the "Watch out column" !
Some feedback for the UNO R3 (in random order),
  • pin 10 is labeled as SPI-SS.
    Although this is most often used as SS, this is not hardwired
  • pin A4 and A5 are also digital
  • analog pins can be accessed as D14-D19 as digital pin
  • missing AREF
  • missing IOREF
  • missing RESET
  • all pins can do PinChange Interrupt - PCINT
  • ICSP connector is not mentioned.
  • maybe explain the LED indicators too
my 2 cents,
Thanks Rob, good catches, all of them. Pushed fixes to the UNO page: A4/A5 marked digital with the D14-D19 aliases, AREF/IOREF/RESET added, the D10 note now says SS is convention (but keep it an output in master mode), and PCINT, the ICSP headers and the LEDs are in the notes under the table. Nano page got the same treatment, it was missing a few pins too. App picks it up next release.
Point taken on graphical diagrams, the table is all it has for now.
Uno/Nano do not prefix digital pins with "D"... for example, this sketch...
int pin = D14; // with "D" prefix
void setup() { /* empty function */ }
void loop() { /* empty function */ }
... yields this result...
Compilation error: 'D14' was not declared in this scope
... while this sketch...
int pin = 14; // no "D" prefix
void setup() { /* empty function*/ }
void loop() { /* empty function */}
Sketch uses 444 bytes (1%) of program storage space. Maximum is 30720 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
Also, make columns columnar.
Thanks for sharing!
You're right, D14 isn't defined on the AVR boards, it's 14 or A0. The chip now says "pin 14 in code" and the note under the table spells it out. Columns fixed too, the tags were wrapping because the watch-out column was hogging the width. Thanks for the screenshot, made it obvious.
Sometimes floating column size is needed. Depends on desired result. Thank you for accepting constructive remarks kindly.
I spent years making documents and correcting formatting, charts, drawings and tables. The speed of software app development made documents lose details to the point of becoming unusable. Even images that were clear and large then, are now tiny and grainy. Standards get pushed aside for proprietary methods. Look for ways to make your work last through future software changes.
Point taken on longevity. The pages are plain HTML tables with no framework behind them, so they should outlast whatever generated them. Thanks again for the review, the UNO page is better for it.
