Freenove Line Follower
For a project I bought a Freenove Line follower robot (see link).
When uploading the Track Line code the robot goes much to fast. My idea is to pause the robot every ±1 meter or that he takes a break every ± 3 seconds.
I tried to put a delay in the code but nothing happens.
This is the code:
#define PIN_SERVO      2
#define PIN_DIRECTION_LEFT  4
#define PIN_DIRECTION_RIGHT 3
#define PIN_MOTOR_PWM_LEFT  6
#define PIN_MOTOR_PWM_RIGHT 5
#define PIN_SONIC_TRIG    7
#define PIN_SONIC_ECHO    8
#define PIN_IRREMOTE_RECV 9
#define PIN_SPI_CE      9
#define PIN_SPI_CSN     10
#define PIN_SPI_MOSI    11
#define PIN_SPI_MISO    12
#define PIN_SPI_SCK     13
#define PIN_BATTERY     A0
#define PIN_BUZZER      A0
#define PIN_TRACKING_LEFT A1
#define PIN_TRACKING_CENTER A2
#define PIN_TRACKING_RIGHT  A3
#define MOTOR_PWM_DEAD    10
#define TK_STOP_SPEED          0
#define TK_FORWARD_SPEED        (90 + tk_VoltageCompensationToSpeed    )
//define different speed levels
int tk_VoltageCompensationToSpeed;  //define Voltage Speed Compensation
#define TK_TURN_SPEED_LV4       (160 + tk_VoltageCompensationToSpeed   )
#define TK_TURN_SPEED_LV3       (130 + tk_VoltageCompensationToSpeed   )
#define TK_TURN_SPEED_LV2       (-120 + tk_VoltageCompensationToSpeed  )
#define TK_TURN_SPEED_LV1       (-140 + tk_VoltageCompensationToSpeed  )
float batteryVoltage = 0;
bool isBuzzered = false;
  pinsSetup(); //set up pins
  getTrackingSensorVal();//Calculate Voltage speed Compensation
  u8 trackingSensorVal = 0;
  trackingSensorVal = getTrackingSensorVal(); //get sensor value
  switch (trackingSensorVal)
    case 0:   //000
      motorRun(TK_FORWARD_SPEED, TK_FORWARD_SPEED); //car move forward
    case 7:   //111
      motorRun(TK_STOP_SPEED, TK_STOP_SPEED); //car stop
    case 1:   //001
      motorRun(TK_TURN_SPEED_LV4, TK_TURN_SPEED_LV1); //car turn
    case 3:   //011
      motorRun(TK_TURN_SPEED_LV3, TK_TURN_SPEED_LV2); //car turn right
    case 2:   //010
    case 5:   //101
    case 6:   //110
      motorRun(TK_TURN_SPEED_LV2, TK_TURN_SPEED_LV3); //car turn left
    case 4:   //100
      motorRun(TK_TURN_SPEED_LV1, TK_TURN_SPEED_LV4); //car turn right
    default:
void tk_CalculateVoltageCompensation() {
  getBatteryVoltage();
  float voltageOffset = 7 - batteryVoltage;
  tk_VoltageCompensationToSpeed = 30 * voltageOffset;
//when black line on one side is detected, the value of the side will be 0, or the value is 1
u8 getTrackingSensorVal() {
  trackingSensorVal = (digitalRead(PIN_TRACKING_LEFT) == 1 ? 1 : 0) << 2 | (digitalRead(PIN_TRACKING_CENTER) == 1 ? 1 : 0) << 1 | (digitalRead(PIN_TRACKING_RIGHT) == 1 ? 1 : 0) << 0;
  return trackingSensorVal;
void pinsSetup() {
  //define motor pin
  pinMode(PIN_DIRECTION_LEFT, OUTPUT);
  pinMode(PIN_MOTOR_PWM_LEFT, OUTPUT);
  pinMode(PIN_DIRECTION_RIGHT, OUTPUT);
  pinMode(PIN_MOTOR_PWM_RIGHT, OUTPUT);
  //define ultrasonic moduel pin
  pinMode(PIN_SONIC_TRIG, OUTPUT);
  pinMode(PIN_SONIC_ECHO, INPUT);
  //define tracking sensor pin
  pinMode(PIN_TRACKING_LEFT, INPUT);
  pinMode(PIN_TRACKING_RIGHT, INPUT);
  pinMode(PIN_TRACKING_CENTER, INPUT);
  setBuzzer(false);
void motorRun(int speedl, int speedr) {
  int dirL = 0, dirR = 0;
  if (speedl > 0) {
    dirL = 0;
  else {
    dirL = 1;
    speedl = -speedl;
  if (speedr > 0) {
    dirR = 1;
  else {
    dirR = 0;
    speedr = -speedr;
  speedl = constrain(speedl, 0, 255); // speedl absolute value should be within 0~255
  speedr = constrain(speedr, 0, 255); // speedr absolute value should be within 0~255
  digitalWrite(PIN_DIRECTION_LEFT, dirL);
  digitalWrite(PIN_DIRECTION_RIGHT, dirR);
  analogWrite(PIN_MOTOR_PWM_LEFT, speedl);
  analogWrite(PIN_MOTOR_PWM_RIGHT, speedr);
bool getBatteryVoltage() {
  if (!isBuzzered) {
    pinMode(PIN_BATTERY, INPUT);
    int batteryADC = analogRead(PIN_BATTERY);
    if (batteryADC < 614)    // 3V/12V ,Voltage read: <2.1V/8.4V
      batteryVoltage = batteryADC / 1023.0 * 5.0 * 4;
      return true;
  return false;
void setBuzzer(bool flag) {
  isBuzzered = flag;
  pinMode(PIN_BUZZER, flag);
  digitalWrite(PIN_BUZZER, flag);
void alarm(u8 beat, u8 repeat) {
  beat = constrain(beat, 1, 9);
  repeat = constrain(repeat, 1, 255);
  for (int j = 0; j < repeat; j++) {
    for (int i = 0; i < beat; i++) {
      setBuzzer(true);
      delay(100);
      setBuzzer(false);
      delay(100);
void resetCarAction() {
  motorRun(0, 0);
  setBuzzer(false);
Thanks a lot.
Did you try lowering the 255s on these lines?
I am trying it tomorrow. let you know .Thanks!
