FREERTOS Guru mediation error, esp32
I am attempting to use FREERTOS. Using 2.09. I have tried various examples, all blow up in, I think the same way. Currently using an ESP32 DEVKIT, although I am really trying to use the C3. So getting down to simplest possible program:
TaskHandle_t Task1;
  Serial.print("setup() is running on core ");
  Serial.println(xPortGetCoreID());
  xTaskCreatePinnedToCore(Task1code,"Task1",20000,NULL,1,&Task1,1);
  Serial.println("Past xTaskCreate...????");
void Task1code( void * parameter ){
  Serial.print("Task1 is running on core ");
  Serial.print( "Task1 Stack WATERMARK " );
  Serial.println( uxTaskGetStackHighWaterMark(NULL) );
  delay(10000);
  //Serial.print("loop() is running on core ");
  //Serial.println(xPortGetCoreID());
  //delay(10000);
All compiles and loads, no problemo.
I get:
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:1
load:0x3fff0030,len:1184
load:0x40078000,len:13220
ho 0 tail 12 room 4
load:0x40080400,len:3028
entry 0x400805e4
setup() is running on core 1
Past xTaskCreate...????Task1 is running on core 1
19328
Guru Meditation Error: Core 1 panic'ed (IllegalInstruction). Exception was unhandled.
Memory dump at 0x400d12c8: 9565fb59 00f01d00 32006136
Core 1 register dump:
PC : 0x400d12cd PS : 0x00060330 A0 : 0x00000000 A1 : 0x3ffc83c0
A2 : 0x3ffc24cc A3 : 0x00000000 A4 : 0x00000000 A5 : 0x00000000
A6 : 0x00000000 A7 : 0x00000000 A8 : 0x800d12cd A9 : 0x3ffc83a0
A10 : 0x00007530 A11 : 0x00000005 A12 : 0x0000000a A13 : 0x00000004
A14 : 0x3ffb8a28 A15 : 0x80000001 SAR : 0x00000000 EXCCAUSE: 0x00000000
EXCVADDR: 0x00000000 LBEG : 0x400862c1 LEND : 0x400862d1 LCOUNT : 0xfffffffe
Backtrace: 0x400d12ca:0x3ffc83c0
Apparently it creates the task, hits it one time, then blows up. The stack size seems to use most of what I put in there--doesn't make a difference.
Obviously, I am doing something wrong, simply wrong. I am primarily a hardware guy, tend to go down rabbit holes on this kind of stuff.
HELP?
And, thanks in advance.
A task should NEVER return. It should be an infinite loop. There's an example in the Arduino IDE:
Of course.
Dumb de dumb dumb.
Thanks so much.
Made the change, things now starting to make sense.
