freeRTOS task without a loop?
void fReadBattery( void * parameter )
  const float r1 = 50500.0f; // R1 in ohm, 50K
  const float r2 = 10000.0f; // R2 in ohm, 10k potentiometer
  const TickType_t xFrequency = 1000; //delay for mS
  float    adcValue = 0.0f;
  float    Vbatt = 0.0f;
  int      printCount = 0;
  float    vRefScale = (3.3f / 4096.0f) * ((r1 + r2) / r2);
  uint64_t TimePastKalman  = esp_timer_get_time(); // used by the Kalman filter UpdateProcessNoise, time since last kalman calculation
  SimpleKalmanFilter KF_ADC_b( 1.0f, 1.0f, .01f );
  TickType_t xLastWakeTime = xTaskGetTickCount();
  //for (;;)
    adc1_get_raw(ADC1_CHANNEL_0); //read and discard
    adcValue = float( adc1_get_raw(ADC1_CHANNEL_0) ); //take a raw ADC reading
    KF_ADC_b.setProcessNoise( (esp_timer_get_time() - TimePastKalman) / 1000000.0f ); //get time, in microsecods, since last readings
    adcValue = KF_ADC_b.updateEstimate( adcValue ); // apply simple Kalman filter
    Vbatt = adcValue * vRefScale;
    xSemaphoreTake( sema_CalculatedVoltage, portMAX_DELAY );
    CalculatedVoltage = Vbatt;
    xSemaphoreGive( sema_CalculatedVoltage );
      printCount++;
      if ( printCount == 3 )
      //log_i( "Vbatt %f", Vbatt );
      printCount = 0;
    TimePastKalman = esp_timer_get_time(); // time of update complete
    vTaskDelayUntil( &xLastWakeTime, xFrequency );
    //log_i( "fReadBattery %d",  uxTaskGetStackHighWaterMark( NULL ) );
  vTaskDelete( NULL );
How to setup that task to be self-running and not being continously called by another task without using a loop in the task?
Huh? What do you mean by "self-running?" A FreeRTOS task has to be an infinite loop. It will run for its timeslice and then will be interrupted by the task scheduler when another task needs to run. This is all done automatically without you having to do anything else.
You have commented out the code that makes it work properly:
//for (;;)
if you modify FreeRTOSConfig.h to set configUSE_TIMERS to 1 then you could use xTimerCreate() and set it to auto-reload.
the call back will be executed with the period you choose for example use pdMS_TO_TICKS(1000) to run the callback every second
Ah a timer being used as a loop. I c.
Did I misunderstand what OP was asking? We seem to have approached the problem differently.
I know, someone indicated it can be done. Me, I don't think it can be done without some sort of looping thingy. Thus, I posted in Bar Sport.
probably a moot point
see What does this code do: for (;;); - #40 for context :slight_smile:
I did not see where "someone indicated it can be done"...
anyway...
two options:
  • use goto and you don't have a iteration statement
  • use a software timer with auto reload
:slight_smile:
An ESP32 runs freeRTOS.
freeRTOS is a multitasking multi processing OS on the ESP32.
Using '''for(;;)``` sets up a multi tasking task under freeRTOS. Typically some kind of task control event is used so the task does not hog all the system resources and allows other tasks to be ran in a timely fashion.
here is a ESP32 freeRTOS multithreading program for you to look over.
   Chappie Weather upgrade/addition
   process wind speed direction and rain fall.
#include "esp32/ulp.h"
//#include "ulptool.h"
#include "driver/rtc_io.h"
#include <WiFi.h>
#include <PubSubClient.h>
#include "certs.h"
#include "sdkconfig.h"
#include "esp_system.h"
#include "freertos/FreeRTOS.h"
#include "freertos/task.h"
#include "freertos/timers.h"
#include "freertos/event_groups.h"
#include <driver/pcnt.h>
#include <driver/adc.h>
#include <SimpleKalmanFilter.h>
#include <ESP32Time.h>
ESP32Time rtc;
WiFiClient wifiClient;
PubSubClient MQTTclient(mqtt_server, mqtt_port, wifiClient);
float CalculatedVoltage = 0.0f;
float kph = 0.0f;
float rain  = 0.0f;
   PCNT PCNT_UNIT_0, PCNT_CHANNEL_0 GPIO_NUM_15 = pulse input pin
   PCNT PCNT_UNIT_1, PCNT_CHANNEL_0 GPIO_NUM_4 = pulse input pin
pcnt_unit_t pcnt_unit00 = PCNT_UNIT_0; //pcnt unit 0 channel 0
pcnt_unit_t pcnt_unit10 = PCNT_UNIT_1; //pcnt unit 1 channel 0
hw_timer_t * timer = NULL;
#define evtAnemometer  ( 1 << 0 )
#define evtRainFall    ( 1 << 1 )
#define evtParseMQTT   ( 1 << 2 )
EventGroupHandle_t eg;
#define OneMinuteGroup ( evtAnemometer | evtRainFall )
QueueHandle_t xQ_Message; // payload and topic queue of MQTT payload and topic
const int payloadSize = 100;
struct stu_message
  char payload [payloadSize] = {'\0'};
  String topic ;
} x_message;
SemaphoreHandle_t sema_MQTT_KeepAlive; // used to stop all other MQTT thing do's
SemaphoreHandle_t sema_mqttOK; // protect the mqttOK variable.
SemaphoreHandle_t sema_CalculatedVoltage; // protects the CalculatedVoltage variable.
int mqttOK = 0; // stores a count value that is used to cause an esp reset
volatile bool TimeSet = false;
   Topic topicOK has been subscribed to, the mqtt broker sends out "OK" messages if the client receives an OK message the mqttOK value is set back to zero.
   If the mqttOK count reaches a set point the ESP32 will reset.
void IRAM_ATTR mqttCallback(char* topic, byte * payload, unsigned int length)
  memset( x_message.payload, '\0', payloadSize ); // clear payload char buffer
  x_message.topic = ""; //clear topic string buffer
  x_message.topic = topic; //store new topic
  int i = 0; // extract payload
  for ( i; i < length; i++)
    x_message.payload[i] = (char)payload[i];
  x_message.payload[i] = '\0';
  xQueueOverwrite( xQ_Message, (void *) &x_message );// send data to queue
} // void mqttCallback(char* topic, byte* payload, unsigned int length)
// interrupt service routine for WiFi events put into IRAM
void IRAM_ATTR WiFiEvent(WiFiEvent_t event)
  switch (event) {
    case SYSTEM_EVENT_STA_CONNECTED:
    case SYSTEM_EVENT_STA_DISCONNECTED:
      log_i("Disconnected from WiFi access point");
    case SYSTEM_EVENT_AP_STADISCONNECTED:
      log_i("WiFi client disconnected");
    default: break;
} // void IRAM_ATTR WiFiEvent(WiFiEvent_t event)
void IRAM_ATTR onTimer()
  BaseType_t xHigherPriorityTaskWoken;
  xEventGroupSetBitsFromISR(eg, OneMinuteGroup, &xHigherPriorityTaskWoken);
} // void IRAM_ATTR onTimer()
  eg = xEventGroupCreate(); // get an event group handle
  x_message.topic.reserve(100);
  adc1_config_width(ADC_WIDTH_12Bit);
  adc1_config_channel_atten(ADC1_CHANNEL_6, ADC_ATTEN_DB_11);// using GPIO 34 wind direction
  adc1_config_channel_atten(ADC1_CHANNEL_3, ADC_ATTEN_DB_11);// using GPIO 39 current
  adc1_config_channel_atten(ADC1_CHANNEL_0, ADC_ATTEN_DB_11);// using GPIO 36 battery volts
  // hardware timer 4 set for one minute alarm
  timer = timerBegin( 3, 80, true );
  timerAttachInterrupt( timer, &onTimer, true );
  timerAlarmWrite(timer, 60000000, true);
  timerAlarmEnable(timer);
  /* Initialize PCNT's counter */
  int PCNT_H_LIM_VAL         = 3000;
  int PCNT_L_LIM_VAL         = -10;
  // 1st PCNT counter
  // Anemometer
  pcnt_config_t pcnt_config  = {};
  pcnt_config.pulse_gpio_num = GPIO_NUM_15;// Set PCNT input signal and control GPIOs
  pcnt_config.ctrl_gpio_num  = PCNT_PIN_NOT_USED;
  pcnt_config.channel        = PCNT_CHANNEL_0;
  pcnt_config.unit           = PCNT_UNIT_0;
  // What to do on the positive / negative edge of pulse input?
  pcnt_config.pos_mode       = PCNT_COUNT_INC;   // Count up on the positive edge
  pcnt_config.neg_mode       = PCNT_COUNT_DIS;   // Count down disable
  // What to do when control input is low or high?
  pcnt_config.lctrl_mode     = PCNT_MODE_KEEP; // Keep the primary counter mode if low
  pcnt_config.hctrl_mode     = PCNT_MODE_KEEP;    // Keep the primary counter mode if high
  // Set the maximum and minimum limit values to watch
  pcnt_config.counter_h_lim  = PCNT_H_LIM_VAL;
  pcnt_config.counter_l_lim  = PCNT_L_LIM_VAL;
  pcnt_unit_config(&pcnt_config); // Initialize PCNT unit
  // 12.5ns is one APB_CLK cycle 12.5*500, debounce time
  pcnt_set_filter_value( PCNT_UNIT_0, 500); //Configure and enable the input filter, debounce
  pcnt_filter_enable( PCNT_UNIT_0 );
  pcnt_counter_pause( PCNT_UNIT_0 );
  pcnt_counter_clear( PCNT_UNIT_0 );
  pcnt_counter_resume( PCNT_UNIT_0); // start the show
  // setup 2nd PCNT
  pcnt_config = {};
  pcnt_config.pulse_gpio_num = GPIO_NUM_4;
  pcnt_config.unit           = PCNT_UNIT_1;
  pcnt_set_filter_value( PCNT_UNIT_1, 500 );
  pcnt_filter_enable  ( PCNT_UNIT_1 );
  pcnt_counter_pause  ( PCNT_UNIT_1 );
  pcnt_counter_clear  ( PCNT_UNIT_1 );
  pcnt_counter_resume ( PCNT_UNIT_1 );
  xQ_Message = xQueueCreate( 1, sizeof(stu_message) );
  sema_CalculatedVoltage = xSemaphoreCreateBinary();
  sema_mqttOK = xSemaphoreCreateBinary();
  xSemaphoreGive( sema_mqttOK );
  sema_MQTT_KeepAlive = xSemaphoreCreateBinary();
  xTaskCreatePinnedToCore( MQTTkeepalive, "MQTTkeepalive", 10000, NULL, 5, NULL, 1 );
  xTaskCreatePinnedToCore( fparseMQTT, "fparseMQTT", 10000, NULL, 5, NULL, 1 ); // assign all to core 1, WiFi in use.
  xTaskCreatePinnedToCore( fReadBattery, "fReadBattery", 4000, NULL, 3, NULL, 1 );
  xTaskCreatePinnedToCore( fReadCurrent, "fReadCurrent", 4000, NULL, 3, NULL, 1 );
  xTaskCreatePinnedToCore( fWindDirection, "fWindDirection", 10000, NULL, 4, NULL, 1 );
  xTaskCreatePinnedToCore( fAnemometer, "fAnemometer", 10000, NULL, 4, NULL, 1 );
  xTaskCreatePinnedToCore( fRainFall, "fRainFall", 10000, NULL, 4, NULL, 1 );
  xTaskCreatePinnedToCore( fmqttWatchDog, "fmqttWatchDog", 3000, NULL, 3, NULL, 1 ); // assign all to core 1
} //void setup()
static void init_ulp_program()
// not sharing this code.
void fWindDirection( void *pvParameters )
// read the wind direction sensor, return heading in degrees
  SimpleKalmanFilter KF_ADC( 1.0f, 1.0f, .01f );
  const TickType_t xFrequency = 100; //delay for mS
  float    high = 0.0f;
  float    low = 2000.0f;
  float    ADscale = 3.3f / 4096.0f;
  int      count = 0;
  String   windDirection;
  String   MQTTinfo = "";
  windDirection.reserve(20);
  MQTTinfo.reserve( 150 );
  while ( !MQTTclient.connected() )
    vTaskDelay( 250 );
  for (;;)
    windDirection = "";
    adcValue = float( adc1_get_raw(ADC1_CHANNEL_6) ); //take a raw ADC reading
    KF_ADC.setProcessNoise( (esp_timer_get_time() - TimePastKalman) / 1000000.0f ); //get time, in microsecods, since last readings
    adcValue = KF_ADC.updateEstimate( adcValue ); // apply simple Kalman filter
    adcValue = adcValue * ADscale;
    if ( (adcValue >= 0.0f) & (adcValue <= .25f )  )
      // log_i( " n" );
      windDirection.concat( "N" );
    if ( (adcValue > .25f) & (adcValue <= .6f ) )
      //  log_i( " e" );
      windDirection.concat( "E" );
    if ( (adcValue > 2.0f) & ( adcValue < 3.3f) )
      //   log_i( " s" );
      windDirection.concat( "S");
    if ( (adcValue >= 1.7f) & (adcValue < 2.0f ) )
      // log_i( " w" );
      windDirection.concat( "W" );
    if ( count >= 30 )
      MQTTinfo.concat( String(kph, 2) );
      MQTTinfo.concat( ",");
      MQTTinfo.concat( windDirection );
      MQTTinfo.concat( String(rain, 2) );
      xSemaphoreTake( sema_MQTT_KeepAlive, portMAX_DELAY );
      MQTTclient.publish( topicWSWDRF, MQTTinfo.c_str() );
      xSemaphoreGive( sema_MQTT_KeepAlive );
      count = 0;
    count++;
    MQTTinfo = "";
  vTaskDelete ( NULL );
// read rainfall
void fRainFall( void *pvParemeters )
  int16_t click = 0; //count tipping bucket clicks
  pcnt_counter_pause( PCNT_UNIT_1 );
  pcnt_counter_clear( PCNT_UNIT_1 );
  pcnt_counter_resume( PCNT_UNIT_1 );
  for  (;;)
    xEventGroupWaitBits (eg, evtRainFall, pdTRUE, pdTRUE, portMAX_DELAY);
    if ( (rtc.getHour(true) == 23) && (rtc.getMinute() == 59) )
      rain = 0.0f;
      pcnt_get_counter_value( PCNT_UNIT_1, &click );
      if ( click != 0 )
        rain = rain + (0.2794f * (float)click);// 0.2794mm of rain per click
        log_i( "count %d, rain rain = %f mm", click, rain );
      click = 0;
void fAnemometer( void *pvParameters )
  int16_t count = 0;
  pcnt_counter_clear(PCNT_UNIT_0);
  pcnt_counter_resume(PCNT_UNIT_0);
  for (;;)
    xEventGroupWaitBits (eg, evtAnemometer, pdTRUE, pdTRUE, portMAX_DELAY);
    pcnt_get_counter_value( PCNT_UNIT_0, &count);
    kph = 2.4f * ((float)count / 60.0f);// A wind speed of 2.4km/h causes the switch to close once per second
    //log_i( "%f", kph );
    pcnt_counter_resume( PCNT_UNIT_0 );
void fmqttWatchDog( void * paramater )
  int UpdateImeTrigger = 86400; //seconds in a day
  int UpdateTimeInterval = 86300; // 1st time update in 100 counts
  int maxNonMQTTresponse = 60;
  for (;;)
    vTaskDelay( 1000 );
    if ( mqttOK >= maxNonMQTTresponse )
      ESP.restart();
    xSemaphoreTake( sema_mqttOK, portMAX_DELAY );
    mqttOK++;
    UpdateTimeInterval++; // trigger new time get
    if ( UpdateTimeInterval >= UpdateImeTrigger )
      TimeSet = false; // sets doneTime to false to get an updated time after a days count of seconds
      UpdateTimeInterval = 0;
void fparseMQTT( void *pvParameters )
  struct stu_message px_message;
  for (;;)
    if ( xQueueReceive(xQ_Message, &px_message, portMAX_DELAY) == pdTRUE )
      // parse the time from the OK message and update MCU time
      if ( String(px_message.topic) == topicOK )
        if ( !TimeSet)
          String temp = "";
          temp =  px_message.payload[0];
          temp += px_message.payload[1];
          temp += px_message.payload[2];
          temp += px_message.payload[3];
          int year =  temp.toInt();
          temp = "";
          temp =  px_message.payload[5];
          temp += px_message.payload[6];
          int month =  temp.toInt();
          temp =  "";
          temp =  px_message.payload[8];
          temp += px_message.payload[9];
          int day =  temp.toInt();
          temp = "";
          temp = px_message.payload[11];
          temp += px_message.payload[12];
          int hour =  temp.toInt();
          temp = "";
          temp = px_message.payload[14];
          temp += px_message.payload[15];
          int min =  temp.toInt();
          rtc.setTime( 0, min, hour, day, month, year );
          log_i( "rtc  %s ", rtc.getTime() );
          TimeSet = true;
    } //if ( xQueueReceive(xQ_Message, &px_message, portMAX_DELAY) == pdTRUE )
    mqttOK = 0;
} // void fparseMQTT( void *pvParameters )#include <ESP32Time.h>
void fReadCurrent( void * parameter )
  const float mVperAmp        = 185.0f;
  float    ADbits             = 4096.0f;
  float    ref_voltage        = 3.3f;
  float    mA                 = 0.0f;
  float    Voltage            = 0.0f;
  float    Power              = 0.0f;
  float    offSET             = 0.0f;
  int      printCount         = 0;
  SimpleKalmanFilter KF_I( 1.0f, 1.0f, .01f );
     185mv/A = 5 AMP MODULE
     100mv/A = 20 amp module
     66mv/A = 30 amp module
  String powerInfo = "";
  powerInfo.reserve( 150 );
    vTaskDelay( 250 );
  for (;;)
    adc1_get_raw(ADC1_CHANNEL_3); // read once discard reading
    adcValue = ( (float)adc1_get_raw(ADC1_CHANNEL_3) );
    //log_i( "adcValue I = %f", adcValue );
    Voltage = ( (adcValue * ref_voltage) / ADbits ) + offSET; // Gets you mV
    mA = Voltage / mVperAmp; // get amps
    KF_I.setProcessNoise( (esp_timer_get_time() - TimePastKalman) / 1000000.0f ); //get time, in microsecods, since last readings
    mA = KF_I.updateEstimate( mA ); // apply simple Kalman filter
    printCount++;
    if ( printCount == 60 )
      xSemaphoreTake( sema_CalculatedVoltage, portMAX_DELAY);
      Power = CalculatedVoltage * mA;
      //log_i( "Voltage=%f mA=%f Power=%f", CalculatedVoltage, mA, Power );
      printCount = 0;
      powerInfo.concat( String(CalculatedVoltage, 2) );
      powerInfo.concat( ",");
      powerInfo.concat( String(mA, 4) );
      powerInfo.concat( String(Power, 4) );
      MQTTclient.publish( topicPower, powerInfo.c_str() );
      powerInfo = "";
} //void fReadCurrent( void * parameter )
  float    Vbatt = 0.0f;
  int      printCount = 0;
  for (;;)
      printCount++;
      printCount = 0;
void MQTTkeepalive( void *pvParameters )
  xSemaphoreGive( sema_MQTT_KeepAlive ); // found keep alive can mess with a publish, stop keep alive during publish
  // setting must be set before a mqtt connection is made
  MQTTclient.setKeepAlive( 90 ); // setting keep alive to 90 seconds makes for a very reliable connection, must be set before the 1st connection is made.
  for (;;)
    //check for a is-connected and if the WiFi 'thinks' its connected, found checking on both is more realible than just a single check
    if ( (wifiClient.connected()) && (WiFi.status() == WL_CONNECTED) )
      xSemaphoreTake( sema_MQTT_KeepAlive, portMAX_DELAY ); // whiles MQTTlient.loop() is running no other mqtt operations should be in process
      MQTTclient.loop();
    else {
      log_i( "MQTT keep alive found MQTT status %s WiFi status %s", String(wifiClient.connected()), String(WiFi.status()) );
      if ( !(wifiClient.connected()) || !(WiFi.status() == WL_CONNECTED) )
        connectToWiFi();
      connectToMQTT();
    vTaskDelay( 250 ); //task runs approx every 250 mS
void connectToWiFi()
  int TryCount = 0;
  while ( WiFi.status() != WL_CONNECTED )
    TryCount++;
    WiFi.disconnect();
    WiFi.begin( SSID, PASSWORD );
    vTaskDelay( 4000 );
    if ( TryCount == 10 )
      ESP.restart();
  WiFi.onEvent( WiFiEvent );
} // void connectToWiFi()
void connectToMQTT()
  MQTTclient.setKeepAlive( 90 ); // needs be made before connecting
  byte mac[5];
  WiFi.macAddress(mac);
  String clientID = String(mac[0]) + String(mac[4]) ; // use mac address to create clientID
    // boolean connect(const char* id, const char* user, const char* pass, const char* willTopic, uint8_t willQos, boolean willRetain, const char* willMessage);
    MQTTclient.connect( clientID.c_str(), mqtt_username, mqtt_password, NULL , 1, true, NULL );
    vTaskDelay( 250 );
  MQTTclient.setCallback( mqttCallback );
  MQTTclient.subscribe( topicOK );
} // void connectToMQTT()
void loop() {}
Notice the code in loop()?
No, it does not. xTaskCreatePinnedToCore sets up the tasks and for(;;) { .. } is used to run the code in the task forever. In ESP32 for(;;) { .. } does what in Arduino/AVR is done with loop() { .. }.
And this has no relation to for(;;); which is equivalent to a halt instruction.
cool.
How do you set up a multitasking task under freeRTOS with an ESP32 without using for(;;) or while(1)?
I use xTaskCreatPinnedToCore to declare a task under freeRTOS.
for(;;) { .. } has nothing to do with setting up a task, it is solemnly used as a loop within the context of a previously created task.
Oi! so I do not need for(;;;) or while(1) in a repeating task. I did not know that.
So why I remove. for(;;) from this task.
  float    Vbatt = 0.0f;
  int      printCount = 0;
      printCount++;
      printCount = 0;
it no longer properly runs, how do you setup a task to run repeatedly without using a loop of some sort?
Please show me a repeating freeRTOS task that does not have a for(;;) or a while(1) and is not being constantly being recreated.
As I have already tried to explain, for(;;) { .. } is repeating/looping the code in the task, but for(;;) { .. } has nothing to do with setting up the task it is looping. If for(;;) { .. } is about setting up a task, why do you not put it in setup()?
that's not exactly what @Danois90 said - he was discussing setting up the task, not running it (what the task does)
so you are both saying the same thing, just lost in translation
Plese show me a repeating task without using for(;;) and while(1).
read post #15 again... You are saying the same thing
the format of a task is
voiding something( void *mmmm)
for(;;)
Can you show me a repeating task that is not setup that way? I'd really like to see one to learn how to setup a task without using the for(;;) and while(1). @Danois90 is saying that a repeating task is not setup with a loop but all it needs is for the task to just be created. I'd just like to know or learn how he sets up a task without a loop.
Please show me, @Danois90 , a repeating task that has been setup without a loop.
@Danois90 has wrote that a self repeating task is NOT setup with a loop. I'd like to know how.
We all agree that if you don't want the task to die after the function terminates you need some sort of iteration statement
now to your question
well, I'm happy to provide an example, but that's not the point.
void vTaskCode( void * pvParameters )
  NOFORLOOP:
    /* Task code goes here. */
  goto NOFORLOOP;
:rofl: :slight_smile:
I think you guys are arguing about the word "setup". To setup the task, you use xTaskCreate().
As one can see creates a task not seup a task
BaseType_t xTaskCreatePinnedToCore(TaskFunction_t pvTaskCode, const char *const pcName, const uint32_t usStackDepth, void *const pvParameters, UBaseType_t uxPriority, TaskHandle_t *const pvCreatedTask, const BaseType_t xCoreID)
Create a new task with a specified affinity.
This function is similar to xTaskCreate, but allows setting task affinity in SMP system.
Setup and create are 2 differing terms, no?
