Hi all
Was wondering how can I integrate these 2 sensors and then push the data to an external hosted server so that I can monitor them wherever I am
Sensor 1
Humidity and Temperature Sensor Module - DHT22
Sensor 2
Arduino
I have read these pages
http://forum.arduino.cc/index.php?topic=257202.0
I have both sensors working in the examples, but I am confused on how to merge the 2 examples together.
DHT22 Code
#include <dht.h>
dht DHT;
#define DHT22_PIN 5
struct
uint32_t total;
uint32_t ok;
uint32_t crc_error;
uint32_t time_out;
uint32_t connect;
uint32_t ack_l;
uint32_t ack_h;
uint32_t unknown;
} stat = { 0,0,0,0,0,0,0,0};
Serial.println("dht22_test.ino");
Serial.print("LIBRARY VERSION: ");
Serial.println(DHT_LIB_VERSION);
Serial.println("Type,\tstatus,\tHumidity (%),\tTemperature (C)\tTime (us)");
// READ DATA
Serial.print("DHT22, \t");
uint32_t start = micros();
int chk = DHT.read22(DHT22_PIN);
uint32_t stop = micros();
stat.total++;
switch (chk)
case DHTLIB_OK:
stat.ok++;
Serial.print("OK,\t");
case DHTLIB_ERROR_CHECKSUM:
stat.crc_error++;
Serial.print("Checksum error,\t");
case DHTLIB_ERROR_TIMEOUT:
stat.time_out++;
Serial.print("Time out error,\t");
case DHTLIB_ERROR_CONNECT:
stat.connect++;
Serial.print("Connect error,\t");
case DHTLIB_ERROR_ACK_L:
stat.ack_l++;
Serial.print("Ack Low error,\t");
case DHTLIB_ERROR_ACK_H:
stat.ack_h++;
Serial.print("Ack High error,\t");
default:
stat.unknown++;
Serial.print("Unknown error,\t");
// DISPLAY DATA
Serial.print(DHT.humidity, 1);
Serial.print(",\t");
Serial.print(DHT.temperature, 1);
Serial.print(stop - start);
if (stat.total % 20 == 0)
Serial.println("\nTOT\tOK\tCRC\tTO\tUNK");
Serial.print(stat.total);
Serial.print("\t");
Serial.print(stat.ok);
Serial.print("\t");
Serial.print(stat.crc_error);
Serial.print("\t");
Serial.print(stat.time_out);
Serial.print("\t");
Serial.print(stat.connect);
Serial.print("\t");
Serial.print(stat.ack_l);
Serial.print("\t");
Serial.print(stat.ack_h);
Serial.print("\t");
Serial.print(stat.unknown);
Serial.println("\n");
delay(2000);
IRTemp
#include "IRTemp.h"
static const byte PIN_DATA = 2; // Choose any pins you like for these
static const byte PIN_CLOCK = 3;
static const byte PIN_ACQUIRE = 4;
static const TempUnit SCALE=CELSIUS; // Options are CELSIUS, FAHRENHEIT
IRTemp irTemp(PIN_ACQUIRE, PIN_CLOCK, PIN_DATA);
void setup(void) {
Serial.println("IRTemp example");
Serial.println("~~~~~~~~~~~~~~");
void loop(void) {
float irTemperature = irTemp.getIRTemperature(SCALE);
printTemperature("IR", irTemperature);
float ambientTemperature = irTemp.getAmbientTemperature(SCALE);
printTemperature("Ambient", ambientTemperature);
void printTemperature(
char *type,
float temperature) {
Serial.print(type);
Serial.print(" temperature: ");
if (isnan(temperature)) {
Serial.println("Failed");
else {
Serial.print(temperature);
Serial.println(SCALE == FAHRENHEIT ? " F" : " C");
Is it a matter of grouping all the revenant parts together i.e. void setup, void loop then the rest?
I have the add_data.php, dbconnect.php and review_data.php from the tweaking4all.com guide, all on my hosted server and I can see the review_data.php file rendered
Any help would be great
Cheers
